 need cheap multi function unit >
Old 02-25-2010 | 10:34 PM
Default need cheap multi function unit
Hello everyone, I am looking for some sort of cheap multi function unit to replace two mechanical speed controls on my vinatge Kyosho Blizzard. Not really a tank per say like most of you run but it does have tracks and twin motors. After doing some prior research, the recommendation was a Sabertooth. I'd really like to find something cheaper and thats where I see alot of people use the Heng Long RX-18. I have really no knowledge of what will or won't work so I would like some recommendations. If I do choose the Heng Long, can I still use my Futaba radio or will I have to purchase the Heng Long radio. Thanks!
Old 02-26-2010 | 02:02 PM
Default RE: need cheap multi function unit
In my opinion, avoid Hennie Long because you will have only rudimentary proportional & possibility of burning RC board out on high current. My 2 cents.
Old 02-26-2010 | 02:40 PM
Have you tried a v tale mixer they are cheap and you get one stick control with 2 escs. I have not used on tracks but it works well in boats.
Old 02-26-2010 | 07:43 PM
YHR's Avatar
YHR
It all depends on the amp draw. The RX 18 is good and inexpensive' you just need ot be cautious of the amps you are pumping through it.
