 Looking For Spare HL Pershing Links >
Old 08-06-2010 | 04:26 PM
BiggTony's Avatar
Default Looking For Spare HL Pershing Links
Hey guys,
I decided to run Heng Long T-80 metal tracks on my Tamiya Pershing. Problem being, my Tamiya Pershing now runs like a Heng Long. I was only provided 81 links per side. While that's the same count on the Tamiya plastic tracks,apparentlyit's too tight as metal. So now the tank wobble a bit as if the tracks are too tight, even when adjusting the idler. I'm not sure if this is the root of the problem, the guide teeth of the sprocket match up to the end connectors of the track. Maybe I'm being too finicky...
Anyway, hoping someone out there has 2 spares with the end cap's and pins to sell. If you do, please PM me!
Thank you
Tony<br type="_moz" />
Old 08-06-2010 | 04:35 PM
karel47's Avatar
Default RE: Looking For Spare HL Pershing Links
i just bought a pershing Track T84 from impactits only one full track but for 45&euro; shipping i couldnot let go, i get the other later on
Bought it fromAxels Modelbaushop with 4spares too
Old 08-06-2010 | 04:44 PM
BiggTony's Avatar
Yeah, I may just get the T-81's if I can't find the spares....looking at the pershing with the top off, I'm not sure if the Pershing was designed to run metal tracks with out some form of modifications. The final drive hub seems to be slanting inwards, that wasn't happening with plastic tracks.
Old 08-06-2010 | 04:47 PM
karel47's Avatar
yes that could be i add on my tiger I also one track plus, the metals were to tight otherwise
Old 08-06-2010 | 04:52 PM
karel47's Avatar
they were impact T84 tracks that i bought quite a bargain don't you think
Old 08-06-2010 | 06:56 PM
pattoncommander's Avatar
Tony, PM your address....I have some track.
Bill
Old 08-06-2010 | 07:03 PM
BiggTony's Avatar
PM sent Bill! Thanks whole bunch!
Old 08-07-2010 | 03:46 AM
karel47's Avatar
have you tried to add a link at one side i would loose them its not good the to much tension on the wheels although with ballbearings, you can put on the wheels lengten it with one or two links and wait for the other from pattoncommander for the second you'll see i works right out, goodmorning afterall
Old 08-07-2010 | 06:03 AM
karel47's Avatar
all tamiya's can run with metaltracks, no realy modifications need, its only in the mind ofthe owner what's need, the only thing i would recommed is ballbearings would add something more
Old 08-07-2010 | 09:35 AM
I have T-84s on my Pershing and also had T-80s on my Super`Pershing. Since Impact tracks are`made for Tamiys, all one has to do is Dremmel a second flat point on the sprocket hub for HL and they run great. Metal tracks , especially my T-84s, are`a bit stiff, but after a bit of running, they loosen up. I just wish I could get my T-84s to stay black, as rubber tracks don't have a silvery look. [] The winterketten I had on my Pz III never` gave any problem, other than maneuvering on grass.
Old 08-07-2010 | 10:15 AM
BiggTony's Avatar
81 Links on the TamiyaPershingusing the T-80 tracks are too tight. Inside of the roadwheel before the idler is forced up against the swing arm and has peeled away a good portion of plastic. Good thing Tamiya supplies an extra set of road wheels. I may have caused some other damage trying to run the tank with the tracks so taught, hoping to cause some relax in the tracks......hopefully it's not a bent axle....or anything else. Pershing is grounded until the links come in.
Thanks again Bill!
<br type="_moz" />
Old 08-07-2010 | 01:32 PM
karel47's Avatar
the best thing to do, when you get the spares
