Tamiya IS-2 build
I finally got round to tidying my hobby room, so the time was right for building the IS-2.
Only modifications so far have been to add bearings to the road wheels. All gone together very well, makes a change from my usual projects! Assembling the tub: http://i32.photobucket.com/albums/d1...psnyxui0fc.jpg http://i32.photobucket.com/albums/d1...pssittbk7c.jpg http://i32.photobucket.com/albums/d1...pskqpkpwqm.jpg Close up of the cast texture: http://i32.photobucket.com/albums/d1...psbyastcpu.jpg Return rollers: http://i32.photobucket.com/albums/d1...pspw4uk9xm.jpg Lower hull finished: http://i32.photobucket.com/albums/d1...pshrkgkm74.jpg http://i32.photobucket.com/albums/d1...psedgquzjm.jpg Upper hull: http://i32.photobucket.com/albums/d1...psigkeprru.jpg Lovely cast texture on the hull http://i32.photobucket.com/albums/d1...ps7h6acdhp.jpg Weld lines: http://i32.photobucket.com/albums/d1...psjea2rdia.jpg |
Looking good!
Dang Tom... now I know where all your tank money went! (lol) :rolleyes:
Looking good! Jeff |
The casting detail on this kit is just crazy cool. Nasty looking grinding marks rough texture. Ugly weld beads. It's Russian and Tamiya sold the look!!! You may not have to spend to much time on this kit like you have in the past Tom???:cool:
Originally Posted by MAUS45
(Post 12044532)
1 Attachment(s)
Don't forget to counterweigh that monster canon in the rear of the turret. And it's not a bad idea to drill out an access hole underneath the overhang for the rear TBU base screw in case you need to get at it after assembly.
Love the JS-2 and yes Tamiya did a great job on cast texture, but c'mon Tom, you know you'll need to ugly it up further with some casting marks, tie down clips and the hideous cut offs on the cupola... http://www.rcuniverse.com/forum/atta...mentid=2098786 |
Ausf, loving the detail on yours, have you a build I can shamelessly get steal ideas from?!
A wee bit more progress, have done the turret basics. Fitting a tbu so have hidden the emitter in the HUGE muzzle break. Hulls had all the detail I don't need to pre paint added. Next week the lower hull goes off to guido Henn for an improved idler system that should help the front end rigidity http://i32.photobucket.com/albums/d1...psd8znwgkt.jpg http://i32.photobucket.com/albums/d1...psz56iwayr.jpg http://i32.photobucket.com/albums/d1...psprqqihyc.jpg Some more progress, trying to smooth the turret seams, about 5 layers of Mr surfacer so far, to ably a couple more required. Also added magnetic hub caps for the sprockets http://i32.photobucket.com/albums/d1...psrqo9qvbg.jpg http://i32.photobucket.com/albums/d1...psqf6z0wb8.jpg http://i32.photobucket.com/albums/d1...psuaybr5mc.jpg http://i32.photobucket.com/albums/d1...ps5i5ppynb.jpg http://i32.photobucket.com/albums/d1...psgxdqiplf.jpg |
I don't know why the thread ended, but this is what I have in terms of a build:
http://www.rcuniverse.com/forum/rc-t...under-way.html Edit, found more: http://www.rcuniverse.com/forum/rc-t...king-ugly.html http://www.rcuniverse.com/forum/rc-t...technique.html And here's the figure you locked down on (although yours is different colors of resin): http://www.rcuniverse.com/forum/rc-t...ct-teaser.html |
Tom, Have to watch out the hinge of the commander cupola is too weak, mine one already broken..
considering to make a metal one for it. but struggling in the working travel lock at the moment. LOL Carson L |
Carson has a point there. My commanders hatch as already broken. The hinge points are very weak.
Been a long time since I made progress on this but got my ammo modulation set through so time to get cracking.
First was a coat of Tamiya fine surface primer to all the photo etch and metal parts. Then a base coat of gunship grey to serve as the metal coat. http://i32.photobucket.com/albums/d1...ps6mnvpkcu.jpg http://i32.photobucket.com/albums/d1...psyiv4bypi.jpg Next after it had cured a coat of hairspray ready for the 4bo base. The mig set has four colours, dark base, base, light base and highlights. Dark base: http://i32.photobucket.com/albums/d1...psgfhtqind.jpg Base: http://i32.photobucket.com/albums/d1...psfhyllmzq.jpg Light base and highlights http://i32.photobucket.com/albums/d1...psfmwwaoki.jpg After this I added some of the dark base as streaks and post shading. Final result with chipping http://i32.photobucket.com/albums/d1...psrg9cocq7.jpg http://i32.photobucket.com/albums/d1...psc1ipkp5m.jpg http://i32.photobucket.com/albums/d1...psjxoahe18.jpg http://i32.photobucket.com/albums/d1...ps2ijrj10a.jpg http://i32.photobucket.com/albums/d1...psa7j3waqu.jpg That's all for now |
What's for dinner?
rex |
| All times are GMT -8. The time now is 05:15 PM. |
