RCU Forums
-   RC Tanks (https://www.rcuniverse.com/forum/rc-tanks-369/)
-   -   Using two electronic board (https://www.rcuniverse.com/forum/rc-tanks-369/11644405-using-two-electronic-board.html)
Uriwood 01-25-2018 01:43 PM
Is it possible to use 2 electric boards together in my tank. like channel 1,2 for tamiya, channel 3.4 for tk board and each power connection on I battery.
l like tamiya motor drive control. tk24's other function & sound.
.any reply appreiciate.
Dusty Steppes 01-25-2018 04:27 PM
I was thinking of doing something similar. Two Tk22s in one tank. Each with its own receiver, speaker and transmitter. Set up one board to control the hull functions and the other board to control the turret. One person could do the driving and the other person could act as the tank commander and control the turret.
Uriwood 01-25-2018 08:06 PM
I mean connecting two boards(tamiya DMD, tk24) to one receiver and using one transmitter.
Shorty54 01-26-2018 05:21 AM
I know YHR did it with a BARC and TBS mini.
He used the Tamiya DMD for drive, the BARC for turret functions, and the Benedini TBS mini for sound.
I dont know if the Clark would work. He used "Y'' cables to parallel up the BARC to DMD.
Shad
Shorty54 01-26-2018 05:26 AM
I think this has been done before, but only using 2 receivers. You bind 2 radios, one to each receiver, but you only plug in the functions you want to control to the receiver.
So the driver plugs into the the 2 drive channels and the other plugs into the other 2. The Danville guys have done it.
Shad
Dusty Steppes 01-26-2018 05:50 AM
Thanks Shad! I'll give that a try. Don't want to steal this guy's thread.
tomhugill 01-26-2018 06:00 AM
You would need to use a y connector for the reciver or two recivers but you could do it
Rad_Schuhart 01-26-2018 07:17 AM
Shad
Thats what I was going to say. I have done it.
Shorty54 01-26-2018 07:59 AM
To get back on track here to the original post, here is the thread that YHR did on the Tamiya DMD/BARC/ Benedeni.
This may help understand how it could possibly be done with a Clark board. Proceed at your own risk!
http://www.rcuniverse.com/forum/rc-t...d-options.html
Shad
Code501 01-26-2018 11:19 AM
1 Attachment(s)
TK24 requires all 4 channels in order to function properly. If you want to use the Tamiya DMD unit, you need to use a Y-cable for the throttle and steering channels. Also, VERY IMPORTANT, both units have a BEC. So when utilizing both boards you need to remove the positive wires from one unit.
So let's say, you remove the positive wires from the DMD RUDD. (Steering) and THROT. (Throttle) servo cables. This way you prevent something from going poof.
Attachment 2252262
(Image taken from the Open Panzer wiki)
Uriwood 01-26-2018 09:05 PM
Attachment 2252262
s
you mean using 2 Yconnectors, connect throttle and steering to both board?
Code501 01-27-2018 12:14 AM
Correct. But as I already mentioned, remove the positive wires from one unit to prevent something burning out.
Uriwood 01-27-2018 03:18 AM
thank you for your technical information..
Roboticus_Prime 01-27-2018 05:51 PM
This is how I eliminated the track recoil in my HL Pershing. It's the RX18 with the crystals. I just split the power and receiver cables with a Y. One board runs the motors, and the other runs the turret/sounds.
clarkmodel 01-31-2018 07:24 PM
We already have product as you mentioned, it called FTTS, all existing TK board can be graded to act as turret/chassis controller, here are details.
FTTS Series
Regards,
Clark
