RCU Forums
-   RC Tanks (https://www.rcuniverse.com/forum/rc-tanks-369/)
-   -   electrical help neened (https://www.rcuniverse.com/forum/rc-tanks-369/9509853-electrical-help-neened.html)
CHIEFSONN 02-16-2010 04:20 PM
I am in search of if someone has the wiring diagram (schematic) for the tiger I, I replaced the RX14 main board with the RX18 board awhile back then got cough up with other things,now I cant find my schematic that I made and need your help so please be a pal it's been a long time since I had a tiger up and running.
Thanks Wayne
BiggTony 02-16-2010 08:31 PM
RE: electrical help neened
Saxon posted a diagram of the RX18 board, look a few posts down in this link, not sure if this is what your looking for.
http://www.rcuniverse.com/forum/m_9451375/tm.htm
CHIEFSONN 02-17-2010 07:27 PM
no this is not what I'm looking for.I have a copy of this,with the wires being different in the same tanks , your tiger his tiger my tiger heng long does not always use red as positive never mind the other colours etc,so im interested in is this wire goes from hear to there, thanks Wayne
afv 02-18-2010 02:22 PM
Sorry, wrong info.
dyeager535 02-18-2010 02:39 PM
From Saxon's post, use the 8 pin turret connector diagram ("CN9" on the RX18 diagram itself). Wire color as you mentioned doesn't matter, as the function is determined by pin, you only need to figure out which is "pin 1" and you are good to go from there.
At least as I understand your problem.
yellowshaker 02-18-2010 06:41 PM
1 Attachment(s)
Does this help?
