help with ofna truggy
i have had an ofna x1 crt truggy for a few years. i had not run it for a few years, but i am getting back into it. i have found out that ofna is no longer making parts for this vehicle. so i am looking for an alternative manufacturer for parts that fit. if anyone has any advice it would help alot.
thank you
thank you
The only parts you'll find made by other manufacturers are some aftermarket upgrades like hinge pin holders, maybe shock towers and chassis braces. Those items are going to be hard to find as the truggy has been out of production for years. The replacement t parts you need like suspension arms, diff parts have no aftermarket alternatives and so you'll have to find old stock. Lookup part numbers then google those numbers to find where to order them.
AK
hello
I have used parts from the jamming/hungnor/ofna truggies, all are the same!!! I have x-1 and x-2, the only parts that really don't cross over are the diffs. but you can use them it you get the whole diffs. the center diff is smaller. I find a lot of parts on ebay scavers lists. most are over priced, but you can talk them down.
