Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Truggy
 Official HPI Hellfire Thread >
RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
Old 02-11-2006 | 11:57 PM
  #176
Default RE: Official HPI Hellfire Thread
ya ia saw that to. but i called and asked about it they said it was 619.99.
Old 02-12-2006 | 12:04 AM
  #177
not much diff at all i hav them both the hellfire handles better for me but the lightning leaves harder than the hellfire.
ORIGINAL: bib
Anyone know what the main differences are between the Hellfire and Lightning stadium?
Both look pretty similiar to me, I own the Lightning Stadium RR and love the truggy. Its a beast and I get to show up Revos/ Tmaxxes all the time
Was just wondering if there were any major differences between the two trucks
Old 02-12-2006 | 12:08 AM
  #178
not rally they both handle about the same but the lighting leaves a little bit more harder but the hellfire is much faster over all.
ORIGINAL: bib
Old 02-12-2006 | 12:17 AM
  #179
ya the hellfire is fast and you can still control it with great responses. i have one infact it is probaly the best stock truck i have ever owned.i would highly suggest this truck to you. infact i was clocked at 47MPH!!! and i was impressed with only one gear. I would deafently buy this this truck!!!!!
Old 02-12-2006 | 12:30 AM
  #180
i will have four of them available early this week PM IF INTEREST IN A PRICE
Old 02-12-2006 | 05:09 AM
  #181
hellfire is faster because of the new k 4.6 HO. thats all!!!
ORIGINAL: imobsessed
ORIGINAL: bib
Old 02-12-2006 | 10:49 PM
  #182
Nice video Zap713 seems like a really fast truck I have the Matrix & would love to race the Hellfire, would like to try the Hellfire thanks.
Old 02-13-2006 | 10:52 AM
  #183
I did bend the front rear brace last weekend, but that was after driving full tilt into a post. Oweee. But that was the only damage. Bent it back straight and no problems. Just stay away from solid, non-moving objects.
Old 02-13-2006 | 04:56 PM
  #184
wmff82's Avatar
ORIGINAL: desdad
to set the gear mesh use a small piece of note book papaer like 3/4 x 4-5 inches long fold over length wise then run the paper through the gears apply solid even presure to the gears using the head of the motor ( make sure the motor is straight ) then thighten screws--loose gear mesh seems better
started hacking away at the hellfire last night while havin a few bud lights at the shop last night. simple fix to tighten up front end.........had a titainium arm pin from a revo laying around hacked it in half and replaced front suspension pins on hell fire. stock pin .296mm lunsford revo pin .316 realy it took away like 80 % of the front end slop and no binding east fix
replaced rear hub carriers on hell fire with xray xb8 uprights.............the bearing in the stock carriers actualy was so sloppy that the back bearings fell out when turnd over. have to remove about 1/16 of inch on the back(inside) bearing set of new carrier not to hard of a job just take your time not to go to far slop gone plus more upper arm positions and another hole on bottom of carrier to help with role center....................................
i belive that replacing the shock caps and shock ends would be a great idea but not needed
this is a good truck i have had mine on display at our store and now we have four guys that are ordering one. therei s things that nneed to be improved on but is'nt there always
truck rating after replace items listed above B+
i'll try and get to the steering area of the truck later this week
Cool bro ,please keep up posted on as much info as possible as to get rid of the slop ,and anything else you find. Thanks alot for sharring it!
Old 02-13-2006 | 10:22 PM
  #185
fried front diff and front left drive shaft already.weird part is i didnt hit anything.
im super irritated with it right now.
mostly cause i have to wait for parts now.
Old 02-14-2006 | 01:26 AM
  #186
zap713's Avatar
Ya HPI diffs arn't the best. If I fry one I'll put in a mayhem diff they're bullet proof.
Old 02-14-2006 | 10:43 AM
  #187
Does anyone know of any aftermarket parts for Hellfire yet?
Old 02-14-2006 | 10:53 AM
  #188
quickster47's Avatar
I do know that Xtreme RC Racing has some carbon fiber shock towers.
Products|HPI|Hellfire
http://www.xtremercracing.com/HELLFIRE_5871.cfm
Old 02-14-2006 | 02:16 PM
  #189
KMW shocks will be available soon : Like [link=http://www.kmwracing.com/cart/product.php?productid=16143&cat=257&page=1]these[/link]
And some more [link=http://www.speedtechnitro.com/ebpage.asp?page=NewProducts]Carbon Fiber[/link]
Old 02-14-2006 | 09:20 PM
  #190
Thanks guys.
Old 02-14-2006 | 09:51 PM
  #191
is there a part # for the mayhem diff's?
Old 02-14-2006 | 10:26 PM
  #192
zap713's Avatar
I get them on ebay. You can get the whole diff for 25 bucks. It has to be the Mayhem ST for the same gear ratio and you will have to shim it a little because the case is a hair smaller. I havn't ran it with them in yet but I did try them for a fit and it looks like they'll work. What part of your diff got damaged?
Old 02-14-2006 | 11:18 PM
  #193
STARTED TO WORK ON BUDYS HELLFIRE WE PLAYED WITH DIFFS TODAY AND ENDED UP AT 7 FRONT 20 CENTER 3 REAR MUGEN OILS
FELT GOOD ON INDOOR CLAY
DRILLED OUT CONICAL PISTONS TO 1.8 REAR 50WT LOSI 1.6 STANDARDS IN FRONT 55WT LOSI OILS
SEEMED TO HANDEL MOUGELS VERY WELL WITH GOOD WEIGHT TRANSFER TO THE REAR
LSP ROD ENDS REALLY HELPED WITH THE SLOP ISSUE SWITCHED MINE TO LUNSFORD TITANIUM TURNBUCKLES FOR A LITTLE BLING
TRUCK IS REALY SOLD AFTER THE FEW LITTLE MODDS LISTED
GOT THE EXTREME CARBON KIT IN MAIL ON MONDAY TOPNOTCH STUFF 90 DOLLARS SHIPPED
GOT CENTER BRACE BOTH SHOCK TOWERS AND CENTER DIFF BRACE
WEIGHT DIFFRENCE WAS 141 GRAMS ANY ONE DO THE MATH IS THAT LIKE AN OUNCE OR TWO
ALSO TODAY ME AND MY BUD PUT A RD LOGICS PIPE ON THE 28 HO AND THAT HELPED OUT WITH USABLE POWER BAND A BUNCH
ANY BUDDY DONE THE WING KIT BY MUGEN OR COME UP WITH ANYTHING BETTER HELLFIRE W/ WING WOULD BE GOOD
NOTICED THAT MY GAS TANK SEEMED PRETTY TIGHT AND DID NOT CLOSE WITHOUT PUSHIN DOWN (I HATE LONG PITS)
HOPE TO START TRACK TEAST MY HF BY FIRST OF MONTH POWERED BY A jp MoD V-SPEC OWE YA
Old 02-15-2006 | 11:11 AM
  #194
desdad, definately interested in seeing some picks when finished and sounds like it's gonna be awesome.
Late,
-Ryan
Old 02-15-2006 | 05:04 PM
  #195
the funny thing is that i have been running 1/8 scale buggies for a little over a year now and my xb8 is stock not one upgrade unless you consider the two piece engine mount an upgrade we all call it a gift from xray
here is the indoor track that we are testin the hellfire on click on OUR TRACKS
http://www.extremerconline.com/
Old 02-15-2006 | 06:56 PM
  #196
Hey everybody,
I picked up a Hellfire about 3 weeks ago and I've been lovin' it ever since. This thing is a beast! Absolutely indestructable. Anyways, I was wondering if there was any way to put a two speed in this thing, or maybe even a three speed! Anybody tried to fit the HPI three speed Savage transmission in this? Is it at all possible?
Old 02-15-2006 | 07:02 PM
  #197
Also for anyone still looking for a hellfire at the best price I found this place... don't know there ship time but i bookmarked it for myself as well.
https://www.ssl-stormerhobbies.com/c...0&showbig=6809
Late,
-Ryan
Old 02-15-2006 | 07:19 PM
  #198
Kanza's Avatar
Just a heads up, HPI has announced part number 85520 for the Hellfire wing. Only Horizon has the actual part on their site, but it isn't in stock yet.
Old 02-15-2006 | 09:02 PM
  #199
Cool tracks desdad
Old 02-15-2006 | 11:37 PM
  #200
tor into the hell fires guts tonight -==-=-=-=--= the center diff had some fluid in it but the rear was pretty much empty now running 7-30-3 front to rear in budys hf. switched mine to that tonight. rear end feels so good when bring truck back straight after pitching it through the corners soming on to and off the straight sections of the indoor track. soon will start messin with ecentric bushings nose does like to drop come off jumps. that will be an easy fix i hope
started to install extreme cf shock towers kinda a pain to get to fit need to remove close to a 1/8 inch of plastic off the top of the diff case in order to have them fit. both long screw on top going trought the shock towers into the rear of the bulk head stripped
TONY'S SCREWS.COM has screw kit for the hellfire........this guys stuff rocks
its getting hard not to drive this thing good thing we bought two. lol
i can do the same price as listed above w/ 20 for shippin pm if interested
