RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
help
Old 07-12-2007 | 10:53 AM
Default help
ok so i might have a problem with my truggy. i recently just built the pro and i was breaking im my motor on it and when i hit a high speed then let go of the throttle the car slown down real fast and once it gets to a slower speed then it will coast like its supposed to. i think it might have somthing to do with the front diff.it goes full speed but as soon as i let go the front end slows down real fast.... no its not the breaks either
Old 07-12-2007 | 11:09 AM
JB COMP's Avatar
Default RE: help
one thing don't do high speed runs with the engine if you have less than a gallon on it, you sould be 3/4 throttle or so, and not pulling high speed runs.
when you say slows down reall fast is it like you hit the break s little?
Old 07-12-2007 | 11:50 AM
Default RE: help
yea its like the front breaks are engaged
its not high speed just when i go fast
Old 07-12-2007 | 12:14 PM
JB COMP's Avatar
Default RE: help
if it stops when you get to a slower speed then its normal, its the clutch, when you going at a high speed and let off the throttle the roating force is still strong another to keep the clutch engaged and the engine will slow the car down till it slows down to where the clutch disengages alowing the car to coast, it basicly like engine braking on a manul car.
all of mine do it to.
