Need help setting carb screws...!!
Hello, I just received my first nitro gas car "Exceed-RC Truggy 1/10th Mutant". I don't know anything about this but I read the manual completed. I did everything what manual says and I get the engine started.
I don't if what happend next is a problem or not so that I decided to open this new topic. After the engine get started, the car expels oil, fuel or whatever thru the exhaust pipe. While I more pull the trigger to accelerate it expels more fuel thru the pipe and the fuel tank get empty TOO FAST (Like 4-5 min).
It has a .18CXP engine and it has 3 screws. I'd like you guys help me with this problem and how to set these 3 screws NOW (During Break-In). I just have used 1 and 1/2 of fuel tanks.
I hope you can help me as soon as possible to get started in this hobby. Thanks!!!
You're supposed to keep the truggy nice and rich during break in, just get it up to about 220 to 230 degrees, and then set it at BDC (Bottom dead center) by rotating the flywheel until you feel the least resistance. Start running the truggy for three minutes, and then add a minute every time until it has about 20 to 30 minutes total runtime on it. Be sure to set the piston at BDC every time you stop the engine. Let it cool to room temperature, and then run it again, don't cool it using fluid or anything, maybe compressed air.
After you do that, or until you feel the metal pinch is gone, you can tune it to best performance, but keep it so that it smokes out of the exhaust while accelerating.
Oh, by the way, the screw that sticks straight up, around the fuel line on the carb, is the high speed needle, the needle on the end of the throttle is the low speed needle, and the screw on the side of the carb, maybe horizontal, is the idle speed screw.
PA
this is normal for break in after break in turn the HSN (high speed needle) clockwise. "NOTE: you should always have blue or grey smoke coming from the exhaust. if you dont you may damage your motor.)
I'd like to know if the fuel that comes from the exhaust pipe is due to some calibration of the carb screws? The tank get empty too fast. I hope you guys can help me with this problem.
Note: The smoke always appears but "with a continous little drops of fuel" like a drizzle...!
If you want the oil to stop coming out of the exhaust, lean the HS needle, but it won't be good for your engine, I'll tell you that.
PA
This is normal you are running very rich (which is good) after break in just lean it 1/4 increments at a time until you dont see any more performance gain then go counter clock wise 1/2 turn.
Hi guys, the car is getting better....now it expels less oil thru the pipe and the tank doesn't get empty that fast. I still have it with 2 1/2 turns and burned about 4 tanks. What should I do next? I haven't run it at FULL speed.
Now I need some help setting the 3 carb screws to normal use or should I run it more before adjust the screws and get it to fast speed?
Thanks...!
Thanks...!
I don't know eactly....like 45-55min. I haven't that BDC because I really don't know what it is.
Thanks for helping me!
Help the guy out man hes a newb....
Dude BDC is when the piston inside the engine is at its lowest point. You can tell by removing the glo plug and looking down the hole. Now spin the motor either by hand using the flywheel (large cog coin on end of engine that usually shows on the underside of the car through a slot) or slowly pulling your pulkl start if you have 1 or use your rotor tool and see the piston going up and down.... Basically to let the engine cool its best to have the opistin BDC as the bore or piston is slightly cone shaped so when its at the bottom it has a tiny amount of play or slack i.e NO piston pinch. this helps when the engine cools and shrinks slightly.
VERY rough guide to tuning.
HSN = high speed needle (located on a vertical brass tube off the carb)
LSN = low speed needle (located where the servo opens the carb slide where the rubber boot is)
MSN = mid speed needle (dont worry DO NOT touch opposite end to LSN)
tickover screw is a small screw right in the carb body usually next to the slide.
Engine MUST be up to temp fist before trying to tune.
HSN to be done first EVERY time. just lean it off so screw IN or clockwise 1/8 turn at a time do a circuit until no extra speed is found (should sound like its screaming too) or until you notice bog or something not as good as the last run. Now run the screw anti clockwise or back out 1/2 turn (that makes sure your well within the engines toelerances.
Nots at this point your really only looking for the high speed end and not too worried about the acceleration.
Now you have the HSN set try the same with the LSN only trying to note the acceleration and not the top speed. get it where you like it and then back it off slightly.
I also suggest you check your glo plug regulary as well as measure the engines temp with a thermometer or the wet finger test.
If you want your engine to last then dont over tune just get it to a speed where your happy. It must always show a trail of smoke from the pipe too. Try not to hold it wide open throttle (WOT) for long periods try to keep it to a few seconds... flat out staright linning is just plain and simply boring.
Now go read lots and lots on tuning, running in, glo plugs, fuel types and any other info you can find. Its all interesting.
FL
ORIGINAL: hpi apollo
First of all, this Nitro Guide and FAQs has been worked on by I (Sean Coots) and rccardude (Eric Brown) for the past 2 months. It is not complete and will be constantly updated and altered. If someone feels that our information is incorrect, please PM Eric or I about the problem and we can come to a resolution. The FAQ guide will be changed fairly frequently with new questions sent in by anyone to I (apollo) or Eric (rccardude). More guides should be available soon too. We hope that this guide is beneficial to many, and we urge you to post a link to this guide whenever necessary. Thank you.
Nitro Engine Break In Guide:
Okay, so you just got your brand new nitro R/C, you are psyched and ready to tear up the streets, but first you must perform a proper break in procedure for your engine unless you want to be buying a new one very soon.
So to start off, you will need to correctly adjust your linkages to work properly (see Linkage Setup below) and make sure your fuel tubing is routed properly (tank pickup to carburetor nipple, pipe pressure nipple to tank pressure fitting.
First, you will need to preheat the engine by taking a hairdryer or heat gun and heating the top of the engines cooling head for about a minute or a little more. Heating the engine up relieves cylinder pinch; therefore the engine will be much easier to crank over.
Side note: Pinch will make your engine hard to turn over. This is why your engine always seems to get stuck, the reason it happens is the cylinder is smaller at the top than it is at the bottom; therefore it’s harder to push the piston through at the top. The reason for pinch is compression, since nitro’s don’t have piston rings, we have to use pinch.
Now you just need to fill the fuel tank up with proper fuel and prime the engine.
Priming Techniques:
-Tank primer: Some fuel tanks are equipped with a built in tank primer; in this case, all you have to do is press down on the priming rod and watch the fuel go to the carburetor.
-Stinger priming: If your fuel tank is not equipped with a built in primer, then just put your finger over the pipe’s stinger (most people just call it the opening in the pipe) and then turn the engine over by means of pull start or whatever. This will push the fuel to the carburetor.
-Mouth priming: While it does sound discouraging, all you have to do is remove the fuel tubing from the exhaust pipe pressure fitting and blow into it (remember not to suck in or you will be drinking hazardous fuel), this will cause the fuel to be forced through the tubing and to the carburetor.
When priming an engine, there is no need to shove excess fuel into it in hopes of it starting easier (actually the opposite of what you think), all that is required is to bring the fuel to the carburetor, no more, once you see it just barely go in then stop and that is enough. If you get good enough at priming, then your engine can start easily on the 1st pull.
Once you have these steps completed, turn on the radio transmitter (TX) and the receiver (RX) and do a quick run through, testing brakes, linkages, carburetor opening, and steering. Now place your fully charged glow igniter on the glow plug and crank the engine by pull start, roto-start, or whatever is used.
Once the engine starts, leave the glow plug igniter in place and begin to slowly drive the car around while varying the engines rpm. Now remove the igniter, if the engine immediately dies then it is running too rich. (Now is the perfect time to read the tuning article below) It is critical at this point to get your engine to a minimal operating temperature, I recommend this to be anywhere from 200*-240* for break in. At this point, it is okay to do 1 second WOT (wide open throttle, aka 100% throttle) bursts. After driving the vehicle around for 2-3 minutes, shut the engine down (read “Engine Stopping Methods” below”) Now you will need to set the engine at BDC (Bottom Dead Center, when the piston is all the way down in the cylinder), to do this, turn the flywheel (or pull starter) until you feel the least amount of resistance and then stop there. This ensures that the piston will not be stuck in the top of the cylinder while it cools. Note: during engine break in, small metal fragments can melt themselves to the glow plug therefore fouling it, so it is wise to have at least 1 spare glow plug for break in.
Let the engine sit and cool down to room temperature, you can lessen the cooling time by blowing compressed air over the head or a hairdryer set to cool. DO NOT SHOCK IT COOL WITH ANY LIQUID AT ALL. Now, repeat the process, adding about 1 minute of run time to each cycle completed. Do this until the engine has run about 15-20 minutes total. Now you are ready to finish properly tuning the engine and then rip it up wherever you want.
Nitro Engine Tuning Basics:
NOTE: ALL TUNING MUST BE DONE AT OPERATING TEMPERATURE
Rich: An excessive amount of fuel entering the engine, more fuel means more oil, which
typically lowers the operating temperature. Rich=counterclockwise
Lean: An insufficient amount of fuel entering the engine, less fuel means less oil, this
causes more friction, higher temperatures, and engine damage. Lean=clockwise
High Speed Needle:
The High Speed Needle (HSN) valve is the tall valve that sticks out from the top of your carburetor. Its job is to control the main flow of fuel to the carburetor. If you lean out the HSN, the LSN (Low Speed Needle) will be automatically leaned too (think of it this way, the HSN is the garden hose faucet which controls all of what goes in, the LSN is the nozzle which controls the exact amount that comes out). The HSN mainly effects the top speed of the car. If your HSN is set too rich, the engine will typically not reach its full RPM potential. If the HSN is too lean, you can experience hesitation, overheating and flameouts (engine instantly shutting off at random or at higher RPM’s). WARNING!!!! The HSN IS NOT to be used as a thermostat. Yes tuning effects running temperature, but only half of it. In the cold, you will typically have to set your needles richer because cold air carries more oxygen, therefore with the previous settings you will be running too lean.
Low Speed Needle:
The Low Speed Needle (LSN) is used for fine adjusting the rate of fuel flowing into the engine from the HSN. If your LSN is too lean then you will have erratic idling, it might want to drive off without you, and it can suddenly shut off (flame out). A characteristic of an overly lean LSN will be a random surging and sound “angry” so to speak. It also will have sporadic RPM increases. Too rich of a LSN will make the idle sound deep and rough, at idle the RPM will slowly decrease and then shut off due to the excess fuel building up, it will also cause consistent sluggish acceleration all the way up the RPM range, and this is what makes it different from a lean bog.
The best way to test your LSN is to get your engine running at normal operating temperature, drive it around, and then let it sit and idle for 30 seconds. Once 30 seconds is over, apply a lot of throttle, if it is rich you will notice slow, gurgly acceleration, if this happens, lean the LSN out by 1/8th of a turn and then test it again, if it is lean, chances are it will flame out or have random surges. In this case you would richen the LSN up by 1/8th of a turn at a time. Your LSN will be set near optimum position when you have little to no hesitation after 30 seconds of idling.
Keep in mind that an engines tune changes day by day, every time you get our your engine and run it, you should tweak the needles a little bit (typically). One day your engine can run fine, the next day it can be running extremely lean.
NOTE: Tune the HSN first because it controls the full amount of fuel entering the carburetor, and then tune the LSN because it is a fine adjustment screw.
As a side note, if you do a lot of wide open running at WOT (Wide Open Throttle, a.k.a. full throttle) your engine will need extra lubrication and it could need to be set 1/4th turn rich to ensure proper lubrication to your engine at high RPM’s.
Here is a good little graphic that for the record I did not make, I simply found it very helpful.
Vapor Lock:
If you have ever shut off your engine or had it flame out while you are using it, and you find that it’s nearly impossible to restart, you are most likely experiencing something called “vapor lock”. Vapor lock is caused by the heat from the engine transferring to the carburetor. In turn it makes the carburetor so hot that whatever fuel that enters it boils off instantly into vapor. Hence the name “vapor lock”. A common giveaway to vapor lock is when you prime your engine; you’ll see that the fuel in your fuel line is pushed away from the carburetor. The only way to run the engine again is to cool the carburetor off enough so that it does not boil the fuel. The most common way is to let your engine sit for five minutes and then try again. Another way is to use cans of compressed CO2 or compressed air cans used for airbrushing and spray the carburetor. Or you can pull off your air filter and dump a little bit of fuel over the carburetor which will rapidly cool it. Just be careful not to get fuel on your brakes or electronics.
Air Leaks:
An air leak is when your engine has unregulated air being sucked in. By unregulated I mean it doesn’t come in through the carburetor. This causes a problem because it can suck in air causing your engine which could be tuned perfectly, to run extremely lean and cause engine damage. It could also cause your extremely rich engine to run lean and well over 300 degrees. If you have an air leak you can look forward to inconsistent tuning and idling, it will seem impossible to find a good tune. Keep in mind that even brand new engines can have air leaks. Here is a good link on How To Seal Your Engine. For the record I did not write that, I am simply posting a link to a helpful guide so moderators, please don’t delete this. Oh and a good place to get RTV silicone sealant and your local auto parts store. You can also use the stuff to seal side exhaust headers and make a gasket so you will never rip another paper gasket again.
Glow Plug Guide:
Without a glow plug, your engine won’t run, simple enough. Now without the right glow plug, your engine just won’t run properly, simple concept. But you are saying to yourself, “Well, how do I know what the proper glow plug is for me?” Well this is a fairly simple question to answer. Glow plugs work by adding compression, heat, and a catalytic reaction between the methanol in the fuel and the platinum in the coil.
Companies rate and sell their glow plugs by their “heat range”. The different general heat ranges are cold, medium, and hot. The heat range of the glow plug is what determines the exact time that the fuel/air mixture being compressed in the cylinder ignites and pushes the piston down. While this sounds like a simple thing, it is absolutely vital to your engines performance. So let’s go on to the function of each type of glow plug and their proper applications.
Hot Glow Plugs:
When you run an engine with a hot glow plug, the compressed fuel/air mixture in the cylinder ignites earlier (more advanced ignition) than a medium or a cold plug would. Hot glow plugs are normally used with low-nitro content (5-20%) fuels to advance the timing and igniter the fuel earlier. Lower nitro fuels burn slower, therefore the mixture must be ignited sooner for the engine to run properly. To hot of a glow plug for your certain nitro percentage can cause pre-detonation and permanent engine damage. An example of a hot glow plug would be the O.S. A3.
Medium Glow Plugs:
Medium glow plugs work the same way that hot glow plugs do, but the do not ignite the fuel as early (more retarded or delayed ignition). Medium glow plugs are often used in medium-nitro fuels (20-30%). An example of a medium glow plug would be the HPI R3.
Cold Glow Plugs:
Cold glow plugs are just like the other glow plugs, but instead, they are meant to be used in engines running high-nitro fuels (30%+). An example of a cold glow plug would be the HPI R5. Cold glow plugs typically have a thicker element in them than a medium or hot glow plug.
Turbo vs. Non-Turbo glow plugs:
Glow plugs come in 2 different styles, Turbo and Non-Turbo. Now before you start thinking “Oh turbo must mean fast, I need that” lets discuss the difference in them.
Turbo Glow Plugs:
Turbo glow plugs differ from standard, non-turbo plugs because they use a tapered edge to make a tight seal between the head button and the cylinder. This lets them to run without a copper washer for a gasket, and also allows them to have a smoother head button which adds a tiny bit of power. An example of a turbo glow plug would be the O.S. P3. Note that you can clearly see the tapered edge.
Non-turbo glow plugs do not have a tapered edge to form a seal between the cylinder and the head button, Instead the use a copper washer. Non-turbo glow plugs (commonly called standard glow plugs) use a different head button than a turbo plug would. The head button is not as smooth; this in turn takes away a tiny bit of power. A good example of a standard plug would be the O.S. 8
How To Read Glow Plugs:
If you know much about 1:1 scale car racing, you will know that teams examine the spark plugs that have been used in the engine while racing, then they use a method called “spark plug reading” to determine how the engine is tuned. Well for scale model cars running 2-stroke nitro engines, there is a method of doing this. It is called “glow plug reading”. Here is a general how-to guide on reading glow plugs. (Note: this is meant for new glow plugs, it cannot be accurately done on glow plugs that have been run for a while)
1. Wire and surrounding bottom of plug wet, with like new shiny wire = rich side of optimum power
2. Wire and surrounding bottom of plug starting to dry and wire starting to gray = very close to optimum power
3. Wire and surrounding bottom of plug dry, wire totally gray but not distorted optimum power
4. Wire and surrounding bottom of pug dry, wire distorted = slightly lean "DANGER!"
5. Wire and surrounding bottom of plug dry, wire broken and distorted or burnt up = extremely lean possible engine damage!
Note: For the record I did not write this “How To Read Glow Plugs” guide and I am using it merely as a helpful guide.
Complete Nitro Fuel Guide:
Most 2-stroke glow fuel engines (with the exception of a few) run on what is commonly called “glow fuel” or “nitro fuel”. Basic glow fuel is comprised of 3 main ingredients: nitromethane, methanol, and oil. Sometimes fuel manufacturers will add friction modifiers (a.k.a. additives) to help improve the overall performance of the fuel. But I will not be going into details on additives.
Fuel Can Go Bad:
You might be asking yourself right now, “What makes my fuel go bad?” Well there are a few things that can cause this. Most of the glow fuel that you use is comprised mainly of methanol (alcohol). One of the characteristics of methanol is that it is ”hygroscopic” , this means that it will freely pull moisture from the air and absorb it since water is soluble in methanol.
Contamination with water is the main reason that fuel goes bad. Contaminated fuel often makes an engine hard to start, tune, or keep running consistently. Another enemy of glow fuel is the sun’s UV rays. These UV rays in sunlight can slowly break down the nitromethane in the fuel, especially if it is stored in sunlight for extended periods of time.
Proper Fuel Storage:
Yes, there is a proper way to do everything, even storing your own glow fuel. Ever noticed when you are almost finished off with a jug of fuel, that there is a lot of empty space in the jug? This is the perfect opportunity for condensation to form in your fuel jug and contaminate it. Below is a picture of how to store your fuel. All fuel should be kept in a cool, dark, dry area if possible.
Try to squeeze as much air out of the jug as possible, but be careful, squeezing the jug too hard can puncture an edge (like I have done) and therefore ruin the jug.
Remember these little things?
Whenever you open up a fresh gallon of fuel, make sure to put this back in the top to provide a moisture barrier.
Oil Content:
All internal combustion engines require oil to operate, if there were no oil in the fuel, our engines would just seize up and never work again. Although this is true for 2-strokes and 4-strokes alike, different methods are employed to accomplish this.
Our 2-stroke glow fuel already has it oil mixed into it. This is what makes it simple; one of the not so simple parts is the actual oil content in the fuel. Though there is not much to say about this, anywhere from 8-18% are acceptable for glow engines used in land vehicles. Fuels ranging from 8-10% in oil content are considered low-oil fuels, and are primarily intended for the experienced tuners who are trying to get the most power out of their engines while racing. For normal bashing, anywhere from 11-16% oil content is acceptable; any more than 16% oil content does little to provide extra protection.
Oil Types:
In our glow fuels, there are 2 main types of lubricants (a.k.a. oils) primarily used in them; these are castor oils and synthetic oils. The general rule of thumb is to buy a castor/synthetic blend fuel, so you get the best of both worlds.
Castor Oils:
Castor oil is derived from the bean of a castor plant (originally used as a natural laxative) and is the best lubricant you can have in a fuel. It provides the best over-lean protection that you can get, and it only keeps breaking down into a better and better lubricant as it is heated (combusted) in an engine. Finally at around 800*F if memory serves me correct, it burns, which is much higher than synthetic oils. After running fuels with high castor oil content you might notice a brown “varnish” on the engine’s internals, this “varnish” is an anti-scuff layer left behind from the castor oil, most people believe this is bad and remove it, however, this helps protect the engine (to a certain extent) in the case of an over-lean run.
Castor oil is mainly used as an EP (Extreme Pressure) additive in nitro engines because they create an excess amount of friction due to the RPM’s that they crank out. If you have ever tried to purchase pure castor oil, especially AA grade, then you have learned that it isn’t a cheap product, this is why companies use less castor oil (if any at all) in their fuel blends. It is highly encouraged that when choosing a fuel, that there be at least some castor oil content in it. I myself have run on fuel that used nothing but castor oil in it, and I can say from experience that it drastically lowers the temperatures and allows you to run leaner (which helps efficiency) without any detrimental effects. This is how some fuel brands like White Lightning are able to run such low oil content in their fuels.
Synthetic oils are typically derived from refined petroleum extracts, and are often chemically altered to be a custom friction modifier. Synthetic oils are cheaper to manufacture, therefore most fuel companies make this a majority of their oil content in a gallon of fuel. Synthetic oils are just as “slippery” as castor oil, but the main difference is that castor oil does not typically burn in the combustion process, while the synthetic oil is often completely consumed. Synthetic oils provide very little over-lean protection when being used.
Some fuel blends from Blue Thunder run full-synthetic oils in them. I have had personal experience with these and do not like them because they are not very forgiving if you run lean. However, many have had success with them; with the right needle setting you will get great protection from them as well. Just as an example, here is a picture of an O.S. 12TZ that was ran a little too lean on Blue Thunder.
Nitromethane Content:
Although our fuels are mainly methanol, we love to call them “nitro” fuels because it simply sounds better. But what is this “nitro” referring to? Well if you read this whole article, you will know that nitro is short for “nitromethane”. But why do our fuels use nitromethane?
Well for starters, nitromethane allows our engines to gain more power because it is basically liquid oxygen, so to speak. It is an oxidizer, which means that during a chemical reaction, it releases oxygen. Oxygen is what reacts with the fuel, therefore more oxygen = more fuel able to be burned. The more fuel that is able to be burned, the more power that can be made. So in a nutshell, more nitro = more power, less nitro = less power, simple enough.
The second reason that nitromethane is used in our glow fuels is that is makes tuning A LOT easier (and starting for that matter). If you have ever tried to tune an engine on zero-nitro fuel, you will realize that makes less power for starters, and that the tuning needles are a lot more sensitive to input.
Higher Nitro Content:
Raising the nitro content is a simple way to add more power, but there are also other things you must do. When you raise the nitro content in your fuel, you are capable of burning more fuel. This creates a larger “bang” in the cylinder, therefore raising the pressure. If your pressure gets too high, you will encounter pre-detonation which can cause serious damage to your engine.
When changing to high-nitro fuels, it is usually advised to add a head shim which lowers compression, and to run a slightly cooler glow plug which also helps prevent pre-detonation.
Lower Nitro Content:
Lowering the nitro content in your fuel can reduce the power output of your engine. When you lower the nitro content in your fuel, usually you should just run a hotter plug. Whenever this is not sufficient, you must also raise the compression in the engine by removing a head shim if possible.
The FAQ section should be up shortly. Both Eric and I ask that you please only link to this post and not just copy and paste our work that has taken us months to compile. Thank you
PA
slayer thats a good guide!
B/c you are running rich NORMAL FOR BREAK IN!!!!!!!!!!!!!! once break in is done lean (clockwise) it out you run times will improve and you wont feel a "drizzle" or oil/ access fuel.
Many thanks. I didn't know of that "BDC". I still don't know how to set the carb screws...I'll try to do my best but sometimes the car accelerate by its own just for screwing the Needle Valve and sometimes when I pull the trigger to full speed the car do not respond very well.
I hope you guys help me with this. Thanks.
