shocks
shocks
at the track yesterday i noticed my car was getting chassis slap over the jumps, and i don't like this so i was wondering what kind of shocks i could get to get rid of this.
are they designed to absorb things on the chassis like STs are or not??
it's a nitrage by the way (and this one turns better than you expect)
ON, CANADA
RE: shocks
This is something that will always happen, Truggies and Buggies are designed that way.
Trying to get rid of it would place insane amounts of load on the shocks.
As far as I know, its normal.
AZ
RE: shocks
Depends on how much air you're getting too, there are 2 jumps on that track I race at that give the truck a nice slap every time. If you're slapping the chassis on small jumps, I'd go with a thicker shock oil and check the settings on your springs.
RE: shocks
ORIGINAL: qaiz
ON, CANADA
RE: shocks
Nah its normal, dont worry about it.
Mines set up so that it does slap the chassis off a jump, takes a lotta load off the drivetrain and shocks IMO.
FL
RE: shocks
ORIGINAL: rcpowerhorse
FL
RE: shocks
3-4 feet may be a problem, blown shock or leak, or too light an oil. also, do you land on the lander for the jump or on the level ground after the lander (overjumping)? if you land on the lander are you parallel with it, all 4 wheels hit at the same time? buggy/truggy chassis are designed to slap.
