Starter Box Wiring
IA
Starter Box Wiring
is this what i need to use to hook up 2 NiMH batteries for an ofna true start starter box? i now have the wiring for a gel cell
http://www.amainhobbies.com/product_...-Set-for-10244
will this wiring set also work in the ofna true start starter box (OFN10249)
IA
RE: Starter Box Wiring
someone has to no if this wiring set will work in an Ofna True Start Starter Box,
http://www.amainhobbies.com/product_...-Panel-Battery
i dont want to buy it and have it not work
VA
If your going to use those cheap arsed connectors,
that always burn up, then yes that kit should have
everything that you need. Honestly though, those
Tamiya(spelling) style connectors suck. Your best
bet is to make up your own harness using Deans
style connectors and swap the ones on your batterys
too. Or just buy batterys with Deans style connectors
already on them, if you don't have the batterys yet.
IA
well i wouldnt know where to start on replacing the tamiya connectors to deans style. and i am only 13 so i think i will just try the tamiya connectors.
MB, CANADA
when they melt together and fail your going to have to replace them anyways....Tamiya connectors are from like 1960 and shouldn't even be on the market anymore....they were NOT designed for the high current packs we run and will fail...its only a matter of time.
