RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
Engine
Old 10-14-2009 | 10:36 AM
Default Engine
When buying an engine what else do you need to get to complete it? Thanks for the help
Old 10-14-2009 | 11:37 AM
qaiz's Avatar
Default RE: Engine
You'd generally go for a few extra Glow Plugs suited to that engine, a flywheel, clutch, clutch bell ( If necessary ), clutch bearings ( If necessary), a pipe ( Again if needed ), a header ( if needed ), and you may need engine mounts.
Pretty sure that should set you good..
Old 10-15-2009 | 08:34 AM
Default RE: Engine
really only plugs, pipe\header for increased perfomance, and clutch bearings. You can never change your clutch bearings too often.
