RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
engine problem
Old 08-15-2010 | 08:26 PM
Default engine problem
i have a tem orion wasp .28 and its been sittin for over a year. i kept after run oil in it. I break it out today to run it and my starter box wont turn it over so i take the motor out and try turning it over myself and its stuck like a rock. I then then tore the motor down and cleaned the inside out and it took alot of the problem away but it still feels like theres a lot more resistance than there should. What should i do? btw this engine doesnt even havebut half a tank of gas through it so im wondering if its just the newness of the engine. i ran that half tank through it when i got it and got rid of the car because i planned to get a new one and just never put it back in
Old 08-16-2010 | 07:33 AM
My Feedback: (12)
Default RE: engine problem
I would say because it is still new and young in life it has a tight pinch.......have you tried heating it up with a hair dryer to see if it loosens up a bit?</p>
Old 08-16-2010 | 08:25 AM
put some after run oil in it and work it back and forth on the tight spot for a while by hand, just get everything moving back and forth, then put it back on what ever you want it on and heat it up with a hair dryer or some kind of heat gun to around 200 or so. and it should be good to go. but you may still have to "break it loose" every now and then with a screw driver between fly wheel and chassis. just try to have it on bottom dead center when you try to crank it. it took my Alpha engine a gallon and a half to loosen up enough where i didnt have to break it loose every now and then.
Old 08-16-2010 | 08:17 PM
yeah ive got a heat gun so ille just try it tomorow. but im having one hell of a time getting the motor to line up right on my mugen mbx5t. The motor mounts arent very adjustable and the clutch bell is just like a centimeter to far forward on the spur gear. any ideas how to fix it witout buying new motor mounts
Old 08-17-2010 | 04:56 PM
ORIGINAL: Morris1
do you have a shim behing the fly wheel? if so can you take that off?
<br type="_moz" />
Old 08-17-2010 | 05:24 PM
nah i dont
Old 08-17-2010 | 10:37 PM
thats odd. maybe try a different flywheel?
Old 08-18-2010 | 12:17 AM
tried 2 already lol....this is pushin me closer and closer to selling my nitro stuff and going 1/5 scale. get tired of having nothin but problems. Maybe its just me who knows
Old 08-18-2010 | 03:39 PM
ORIGINAL: Morris1
thats weird. people run that engine in my area with no problem. any pics?
<br type="_moz" />
Old 08-18-2010 | 04:20 PM
ille try to get some pictures up on here this evening...thanks j your a big help man and have been to me since i started using this forum again
Old 08-21-2010 | 09:06 PM
hey, did you get this problem figured out?
