Reload this Page >
CARF-Models P-47 Thunderbolt
Old 06-20-2016, 04:59 AM
  #826
Ragz
Ragz's Avatar
Great video. Amazing landing. Incredible sound
Old 07-15-2016, 03:28 PM
  #827
mujenpwr
Is everybody using the stock flap and aileron metal clevis linkage for their setup? Or changing to ball links ?
Thx
Joe M
Old 07-15-2016, 06:54 PM
  #828
Greg Wright
Greg Wright's Avatar
[QUOTE=mujenpwr;12235297]Is everybody using the stock flap and aileron metal clevis linkage for their setup? Or changing to ball links ?
Thx
Joe M[/QUOTE
i used all of the linkages that came in the kit. The only thing i changed was i used a ball link on the servo arm for the flaps. I ended up using a Hanger9 Aluminum arm also.
Old 07-19-2016, 12:33 PM
  #829
mujenpwr
Guys what length servo arms for ailerons and flaps? 1" or 1.25" ? Which metal arms?
Thx
Old 09-22-2016, 11:11 PM
  #830
affas
affas's Avatar
Hi, 15-20 flights now and the aileron hinges is getting sloppy....Seems like the phenol horn holes are getting bigger. Anyone else?
Flanged bearing was my first thought but not enough material enoug. Brass tube glued in? Any suggestions?
Another flight from Westwings, southern part of norway
https://www.youtube.com/watch?v=8p2XPKnG1EQ
Old 09-23-2016, 03:32 AM
  #831
Greg Wright
Affas,
I have around 50 flights on mine and i do have slop in the phenolic hinges. So my thoughts are to try and find some nylon bushings that i could glue in to stop them from getting any worse.
frankyjg2012 (05-19-2020)
Old 09-23-2016, 03:40 AM
  #832
Greg Wright
Thx
I have JR 8911's on everything and i used the Heavy duty 1" Nylon arms on the Ailerons,elevator & rudder and have had zero issues. I also used the H9 1.5" aluminum arms for the flaps.
But if i was to change the arms on the 3 main controls i would use the H9 1.5 aluminum arms and i would cut them down and use the inner most hole so i didn't loose any resolution or torque out of the servo.
Name:	Image 9-23-16 at 6.49 AM.jpg
Old 09-23-2016, 08:30 AM
  #833
affas
affas's Avatar
I was thinking brass tube with 3mm inner and 4mm outer diameter but I don`t know what is best.
Originally Posted by Greg Wright
Affas,
Old 09-23-2016, 09:38 AM
  #834
Greg Wright
Affas,
i think the nylon is a better choice. it shouldn't wear out that fast.
Old 09-23-2016, 09:40 AM
  #835
Greg Wright
I just ordered a few of these to see if they will work.
Metric Nylon Snap-in Thrust Bearing
Old 09-24-2016, 12:36 AM
  #836
Craig B.
Guys there is a very simple fix for this. Make sure the phenolic hinge is clean. Remove clean and lightly oil the hinge pin- remove excess oil. Re-insert the hinge pin into the phenolic hinge without the control surface in place. Place a drop of green zap at the junction of the hinge pin and hinge so it wicks into the hole in the phenolic hinge. Hit it with kicker. Twist the hinge pin and you will be able to remove it. Re-insert and you will have a precision fit slop free fit. The zap sets very hard and will not wear easily. Problem solved.
Old 09-24-2016, 09:49 AM
  #837
mujenpwr
Thanks for the info Greg!!!
let us know how the bushings work
Joe M
Old 09-24-2016, 04:45 PM
  #838
Greg Wright
Joe M
I will once i have them installed and get a few flights on them. If i come up with any other ideas for bushings i'll let you know. I just don't see how the CA will really cure this issue.
I know the holes on mine are pretty sloppy as is. The bushings should give them some more shock absorption.
Old 11-13-2016, 06:19 AM
  #839
Greg Wright
Well after doing some inspections of the hinges and the Aluminum pins. It was found that most of the slop was from the Aluminum wearing out on the pins them selfs and not the Phenolic hinges.
I have replaced the pins with new ones and the slop was removed to a minimum of what it was.
Old 11-17-2016, 05:06 PM
  #840
LtMash1A
Hey, Guys. I am trying to install the aileron servos and made the tool, but the driver that seems like it would work on the screw does not when at the slight off angel required when working through the flap. So, before i cut up a bunch of screw drivers, could you tell me which kind or number to use. Thanks,
Old 11-18-2016, 05:19 AM
  #841
Greg Wright
I just used the Hex Head servo screws and a ball end wrench and was able to go thru the aileron servo opening to mount the servo's. I was about to mess around making that tool..
Old 11-18-2016, 03:16 PM
  #842
LtMash1A
Two questions, Greg. Did you thin CA the holes after threading the screws in? Like it wasn't hard enough getting them in the first time. Also, in the pneumatic kit there is one length of 4mm tubing. does that go between the air cylinder and the nipple on the strut? Does the 4mm tubing go anywhere else. Your bird looked and flew great at the Memorial . Thanks, Dave
Old 12-09-2016, 03:35 AM
  #843
f16jetman
Hi Greg maybe abit late if you haven't already done it the phenolics do need replacing with nylon bushings I am just buiding my P47 now almost finished up to the paintwork stage I am using a Moki 250 7 cylinder in her paint is the Mexican scheme the vibration with the 7 cylinder is virtually 0 compared to the 5 but the 5 has more of a growl I hope all the p47s I have been following on this post are still going strong congrtulations to everyone for sharing your build information fantastic many thanks may the p47 brotherhood live on cheerz guyz
Old 12-10-2016, 05:11 AM
  #844
Greg Wright
Hi Dave,
I did add CA to the holes but i did that before installing the screws. I don't remember off the top of my head right now, but i think i also add a piece of good quality aircraft plywood as a backer to the servo opening on either end of the servo pocket. This was just so i knew i had some good quality material for the screws to bite into. I didn't get the pneumatic kit for mine i just ordered the gear alone as i have enough of the air tanks and airhose in my shop. So i just hooked it all up with what i have. I also made sure i safety wired each connection on the gear for a non leaking system.
Old 12-10-2016, 05:12 AM
  #845
Greg Wright
Why do you say i need the bushings?
Old 12-10-2016, 05:51 PM
  #846
LtMash1A
According to the brochure, the engine mounting math is already done and just a bolt in for the M-250, but I have read otherwise. Is the best way to mount it to the dome and then slide it around on the firewall until centered, or mount the dome and then slide it around on the dome to center (not much adjustment this way), but factoring in the math on the offset/thrust etc. and not knowing how much adjustment is needed. I was going to support the fuse vertically, put the cowl on and slide the engine around until centered. Also, the directions show a template made for the carburetor/choke opening then transferred to the dome to cut out. , but in another picture, it looks like the hole in the dome is cut out to match the whole in the laminated wood backing plate.I just don't see the need for the template. Am I wrong? Dave
Old 12-10-2016, 07:11 PM
  #847
Greg Wright
Dave,
I just went by the book on the engine mounting and had no issues with it lining up in the cowl. I think the template is more for the three holes needed to mount the engine and the cutout for the carburetor.
Old 12-10-2016, 08:19 PM
  #848
LtMash1A
Dave,
That is good news. Did you use the UP3 valve for gear/door sequencing? Or best other method?
Old 12-10-2016, 08:51 PM
  #849
Greg Wright
Dave,
I used two systems with two BVM High flow valves with servos and two separate air tanks. One system is for the three gear alone and the second is for the doors. Then i used the sequencer in my DX 18 to sequence everything together.
My canopy is operated by a Firgelli actuator.
Old 01-05-2017, 02:48 AM
  #850
desertrat65
desertrat65's Avatar
Hi Guys,
I was wondering if anyone may be able to advise on the best way to attach the P47 aerial that is supplied by CARF? I am trying to work out a good way to be able to make the aerial removable when transporting the model. But still have the aerial stay in place when flying.
Any advice or photos would be greatly appreciated.
Thank you.
