ESM FW D-9
Old 06-07-2015, 06:38 AM
  #2976
snickarn
Originally Posted by Ramstein44
Dang.... how bad was the fuse?
Pretty bad unfortunately...
Old 06-07-2015, 08:26 AM
  #2977
Ramstein44
My Feedback: (157)
Ramstein44's Avatar
That's too bad. This is one of the reasons I sold mine. If it were a kit with plans, it could be fixed fairly simply but being an ARF, you have to start over which is more costly then having purchased a kit. Sure kits take time but these ARF's do to when you consider the efforts we put into them and in the efforts it took me to flip the one I had, I've built two kits...rivets, panel lines and so on.
Sorry for your loss... hate to see a wulf go in.
Old 06-07-2015, 08:31 AM
  #2978
snickarn
Thats no worry at this time, a beer or two gets over the most......
I gonna order a new one, but a kit from FokkeRc tonight..... I hope engine and retracts fit from my ESM to FokkeRC D9
Old 06-07-2015, 09:47 AM
  #2979
Ramstein44
My Feedback: (157)
Ramstein44's Avatar
Mmmm...beer...
Fokke designed his FW 190 to fit the Sierra retracts. That being said I modified my ESM for Sierra retracts so I'm pretty sure with a little effort your retracts will drop right in.
Old 06-07-2015, 10:04 AM
  #2980
deadstick79
deadstick79's Avatar
Really sorry about your Dora!
I've been putting off my maiden long enough and will finally do so soon!
Dan
Old 06-08-2015, 06:12 AM
  #2981
LDM
My Feedback: (15)
I dont know the design of the Dora from ESM guys but I do care when I see a fellow RC model lost . My ESm corsair had a week wing play spar that was supposed to be used to connect the outer wings to the center section.
If you have one in the kit form, check there ply over really well.
I made a new ply former from laminated stronger ply , the kit origonal would surely have failed under load.
Hope this helps
Old 06-22-2015, 07:13 PM
  #2982
zrooster
For those still reading... Finally had enough time at home to mess around with my XYZ 53 and get it running on my test stand. It pulled a solid 20 pounds on the fish scale using a Xoar 22x10...assuming a conservative 15% loss due to friction etc, that's a solid 23 pounds of thrust (I think probably more). Starting problems ended up being a defective ignition. Ordering a Biela 3 blade and will see what kind of performance it produces when I get back from my next trip.
ID:	2105156   Click image for larger version
ID:	2105157   Click image for larger version
Old 06-22-2015, 07:54 PM
  #2983
Katniss
Katniss's Avatar
Biela 3 blade props look nice, but tend to bog a motor down.
Old 06-22-2015, 08:35 PM
  #2984
dgiatr
dgiatr's Avatar
"zrooster" is right about biela! Nice - scale props but a very heavy load for any motor. You should be about 30% overpower if you want to swing that props...
Old 06-22-2015, 08:37 PM
  #2985
dgiatr
dgiatr's Avatar
Old 06-23-2015, 02:47 AM
  #2986
LDM
My Feedback: (15)
Bella props are incredbily assembled, light and little variance in balance blade to blade . If scaled down from two to three correctly I dont know load would be an issue .
They are some of the best props made, thicker then most but very light
Old 06-23-2015, 05:15 AM
  #2987
Katniss
Katniss's Avatar
I was running a 3 blade 20x10 biela on a 50cc spitfire..rpms weren't very good at 6400 and the plane flew like a dog. I pulled that off and put a 2 blade turnigy 20x10 and the plane flew phenomenally better.
With the biela, I was nervous making to steep of a bank turn as I was afraid I'd lose too much airspeed and the plane would stall. This is how poorly the biela props perform. They are not a light prop. I have a 20x14 on my D0-335 on the front(electric setup). I am still trying to find a decent replacement to pull that one off.
Old 06-23-2015, 07:14 AM
  #2988
zrooster
I ran a biela 4 blade on an EME35 for a different project (scaled down per the factory recommendation). It lost about 2 pounds (14lb vice the 16lb the two blade pulled) as read on the fish scale compared to the recommended 2 blade (19x8). Assuming a similar loss on the XYZ, it should be pulling about 21 pounds of actual thrust, which should be plenty for a 26 pound FW... That said, I'm going to run it on my test stand and see what it puts out with the three blade. I'll let y'all know what my results are when I get back from my next trip in mid July.
Incidentally, did manage to finally get my hands one an ESM Dora!
Old 06-24-2015, 01:41 AM
  #2989
LDM
My Feedback: (15)
everything is relavant weight is based on other three blade props, my bells prop was lighter then other carbon fiber props that I have . I am not comparing them to two blade wood props .
Bella props are thicker then most three blade but very good props in there class of three blade . You can get a more efficient three blade in the same size of a Bella --example a 20 -10-3 blade Bella is differant then most other a 20-10-3 blade props with the same specs but thinner blades that are more efficient. I have very good performance with Bella props but have undersized per manufactures suggestions. I was not looking for speed but more for scale
Old 06-24-2015, 02:50 AM
  #2990
zrooster
How did you size your props? I'm looking at going down 1-2 inches in blade length and keeping the same pitch for the 3 blade. On the 4 blade, I went down in length and pitch.
Old 06-24-2015, 02:57 AM
  #2991
LDM
My Feedback: (15)
[TABLE="width: 100%"]
[TR]
[TD="width: 33%"]Two Bladed[/TD]
[TD="width: 33%"]Three Bladed[/TD]
[TD="width: 34%"]Four Bladed[/TD]
[/TR]
[TR]
[TD="width: 33%"]10-6[/TD]
[TD="width: 33%"]9-6[/TD]
[TD="width: 34%"][/TD]
[/TR]
[TR]
[TD="width: 33%"]11-8[/TD]
[TD="width: 33%"]10-8[/TD]
[TD="width: 34%"]10-6[/TD]
[/TR]
[TR]
[TD="width: 33%"]12-8[/TD]
[TD="width: 34%"]11-6[/TD]
[/TR]
[TR]
[TD="width: 33%"]12-10[/TD]
[TD="width: 33%"]11-10[/TD]
[TD="width: 34%"]11-8[/TD]
[/TR]
[TR]
[TD="width: 33%"]13-10[/TD]
[TD="width: 34%"]12-8[/TD]
[/TR]
[TR]
[TD="width: 33%"]14-10[/TD]
[TD="width: 34%"]13-8[/TD]
[/TR]
[TR]
[TD="width: 33%"]14-8[/TD]
[TD="width: 33%"]13-8[/TD]
[TD="width: 34%"]13-6[/TD]
[/TR]
[TR]
[TD="width: 33%"]15-8[/TD]
[TD="width: 34%"]14-6[/TD]
[/TR]
[TR]
[TD="width: 33%"]15-10[/TD]
[TD="width: 34%"]14-8[/TD]
[/TR]
[TR]
[TD="width: 33%"]16-10[/TD]
[TD="width: 34%"]15-8[/TD]
[/TR]
[TR]
[TD="width: 33%"]18-10[/TD]
[TD="width: 34%"]16-8[/TD]
[/TR]
[TR]
[TD="width: 33%"]20-10[/TD]
[TD="width: 34%"]18-8[/TD]
[/TR]
[TR]
[TD="width: 33%"]22-10[/TD]
[TD="width: 34%"]20-8
[/TD]
[/TR]
[/TABLE]
I am not an expert so I use this chart along with an email to the engine or motor supplier .
As an example when speaking with Horsion , they had me drop one additional size vs what the number said , three years later, planes flys great still no issues so its great to get advice from the manufacture to confirm the numbers .
My theory " an expert is someone that is no longer willing to learn "
I went from an 18/10/3 to a 17/10/3 on a 3 blade conversion based on there advice on my particulr project
Old 06-25-2015, 03:42 AM
  #2992
zrooster
Thanks! That's a huge help...down side if buying Chinese engines...probably not going to get that level of customer service
Old 06-25-2015, 04:44 AM
  #2993
LDM
My Feedback: (15)
No problem , I think in your neck of the woods you can also call Graves Hobbies in Orlando and Bobs Hobbies .
Two great hobby shops when dealiing with RC planes .
Good luck
Old 06-25-2015, 06:15 AM
  #2994
zrooster
Thanks, I'll check them out!
Old 08-27-2015, 05:52 AM
  #2995
deadstick79
Finally maidened her last Sunday!
She flew like she was on rails!
First landing approach was way too fast so I came around again with half-flaps and brought her down. I had one manageable bounce and then she rolled out nice right to the very end of the runway!
Was taxing back to the pits and went to raise the flaps and hit the gears switch instead... broke the prop and my pride
I cannot believe how stable she is! Can't wait to get her back up! Will try to get some vid!
One happy camper!
Dan
Old 08-27-2015, 08:26 AM
  #2996
Dowmer
Dowmer's Avatar
Congrats Dan, the D9 is a great flier. You will be very surprised how slow the ESM planes gets with that thick wing. It's almost un-nerving.
Heres some more artistic pics of mine I did the other day. It doesn't look like an ESM plane but it is.
ID:	2116897   Click image for larger version
Old 08-27-2015, 08:14 PM
  #2997
deadstick79
Thanks Dowmer,
Man, it looks like you stole those pics from "Wings of the Luftwaffe"
Old 08-30-2015, 07:29 AM
  #2998
zrooster
It's nice to see folks are still active on here. I have one, finally, that I'm itching to get together, but for "political" reasons I have another plane that has to be completed and maidened first (my wife bought it for me). It also doesn't help that work has me gone all the time...I'll be on the road 23 days in Sep!
Hope to see more vid and pix so I can live vicariously through y'all!
Old 09-04-2015, 08:01 AM
  #2999
affas
affas's Avatar
Two Doras, one SisT and my ESM D9. Both with Saito fg 60. Great match!
https://youtu.be/2AGdihDBCco
Old 09-04-2015, 09:13 AM
  #3000
Dowmer
Dowmer's Avatar
Alf, I've seen your video with you and Ken's planes before on RCSB. Some of the best model video with a drone I've ever seen. Well done. Great looking planes.
