ESM FW D-9
Old 09-27-2016, 05:08 AM
  #3051
zrooster
I'm finally gettin started on the assembly of mine (bought it already completed, so just engine, servos, batts and receiver) and wanted to see if I could pick the brains of those running the XYZ 53.
I copied somebody's mount idea:
But, wanted to see if someone could give me your distance from firewall to engine mount flange and firewall to hub.
Also, any cooling issues on the XYZ, and how much weight (if any) did you add to the nose (understand this depends on a lot of variables...just looking for a ballpark)?
Any help would be much appreciated.
Old 09-28-2016, 09:14 PM
  #3052
STICK MODE
STICK MODE's Avatar
[QUOTE=zrooster;12261976]I'm finally gettin started on the assembly of mine (bought it already completed, so just engine, servos, batts and receiver) and wanted to see if I could pick the brains of those running the XYZ 53.
Any help would be much appreciated.[/QUOTE
pm me and ill give you my email i will pull my cowl of and show you how to mount your motor the spacer that's required and a better way to mount your cowl allowing air for cooling. Has your xyz got the normal plugs or the smaller ones? the smaller ones are better for clearance.
Regards Frank
Old 09-29-2016, 02:00 AM
  #3053
zrooster
Thanks! PM coming.
Old 09-29-2016, 03:21 AM
  #3054
HoundDog
My Feedback: (49)
HoundDog's Avatar
[QUOTE=STICK MODE;12262549]
Regards Frank
PLZ Show us all. Thanks.
Old 09-29-2016, 12:20 PM
  #3055
STICK MODE
STICK MODE's Avatar
Give me a few days and ill post photos
Old 09-29-2016, 12:24 PM
  #3056
STICK MODE
STICK MODE's Avatar
[QUOTE=HoundDog;12262575]
Old 09-29-2016, 04:29 PM
  #3057
zrooster
[QUOTE=STICK MODE;12262702]
Thanks again!
Old 10-14-2016, 05:11 PM
  #3058
zrooster
Ran mine today! I want to thank Charles for the great work he did on the plane before I got it from him and Frank for all the info he sent me.
You may notice I've got the stock plugs/caps on the engine. I wanted to run it in stock form first as a baseline, to make sure everything was working before I put anything aftermarket on there.
The XYZ 53 ran great...very smooth with a nice sound to her!
ID:	2185708   Click image for larger version
Old 12-15-2016, 07:36 PM
  #3059
deadstick79
deadstick79's Avatar
do y'all know if there's a forum for the 74.5" ESM Corsair?
Dan
Old 12-15-2016, 11:12 PM
  #3060
Chad Veich
My Feedback: (60)
Dan
https://www.rcgroups.com/forums/show...span-Model-ARF
Old 12-16-2016, 03:04 AM
  #3061
Katniss
Katniss's Avatar
There's a much longer thread here on rcuniverse. Type in esm corsair in the search function. I'm on my phone, otherwise I'd link it for you
Old 12-16-2016, 09:43 AM
  #3062
Ramstein44
My Feedback: (157)
Ramstein44's Avatar
Man, she looks great. Have you flown her yet.
Old 02-13-2017, 09:30 AM
  #3063
zrooster
Sorry, didn't see your comment until now. She's beautiful! You did a great job! Maiden tomorrow, unless I run into any major issues. Should be a great day! Forecast is sunny and 75 with winds ~4-5mph.
Old 02-14-2017, 06:36 PM
  #3064
zrooster
Great maiden today! Here are some stills:
Video link and description to follow
Name:	DSC_0587 (1024x681).jpg
ID:	2201107   Click image for larger version
Name:	DSC_0589 (1024x681).jpg
Old 02-14-2017, 06:49 PM
  #3065
zrooster
Here's the video. Alibis: I had up elevator trim when a lot of down elevator trim was needed for level flight, so it lifted off early...hard to tell, because my cameraman was zoomed in too close...looks a bit more exciting than it should, but BL, lifted off a bit earlier than I normally would. For the landing, little late flare into a slight balloon...good salvage of a bad approach... I used half flaps, but didn't need them with the 5-7mph winds, she's definitely a floater...as you can see, final touch down was lightly on one main and then the other...was still flying well into the rollout.
The middle part is pretty boring...just trimming and feeling her out. The XYZ twin provided more than enough power...she flew well...level flight easily attained with about 1/3 throttle. CG was good...touch nose heavy, the way I like it. I added 44oz of lead to the nose...attached to the firewall and cowling. Left the gear down as I do for all my maidens...one less thing to go wrong. Got a few adjustments to make before the next flight, but VERY happy.
Look forward to the next flight...gear UP this time!
https://www.youtube.com/watch?v=tLZRzhL6fxg&feature=em-share_video_user
Old 02-14-2017, 07:00 PM
  #3066
Ramstein44
My Feedback: (157)
Ramstein44's Avatar
Nice..
Old 02-15-2017, 02:28 AM
  #3067
Dowmer
Dowmer's Avatar
Rooster, what's the all up weight? Congrats on the maiden.
Old 02-15-2017, 03:40 AM
  #3068
zrooster
Thanks! I'll have to check, but suspect it's around 26lb.
Old 02-15-2017, 03:53 AM
  #3069
Dowmer
Dowmer's Avatar
Thanks, I'd be curious. Mine is close to 27 with the Sierra gear and lots of scale details and full cockpit. I only needed about 20oz in the nose for mine though and it is a bit nose heavy. Ramstein (aka Charles) and I both dolled up our ESM D9s
Strange that hat I had the same issue on my maiden with it needing lots of down elevator and an early T/ O. Makes me wonder if the horizontal stabilizer incidence is a bit down from the factory.
Old 02-15-2017, 05:51 AM
  #3070
zrooster
Now im curious! I must be more in the 28lb range, then. I balanced at 145, vice 155...may be why I needed more weight to balance. Didn't feel excessively nose heavy, though.
I think you may be right on the stab incidence...the elevator was dead even when I set the plane up, and then I gave it about 3-5 clicks nose up trim for the maiden. I ended up with my trim near the top of the scale...whole s-ton of nose down trim, and it was pretty close to hands off at lower power settings.
Old 03-10-2017, 02:52 PM
  #3071
zrooster
Just got back from a trip, and weighed in today. Not the most precise method...put the nose on a bathroom scale, and tried to just support laterally... All up weight without fuel was right at 26lb. Do you have a pilot figure in yours? That might account for some of the difference...
Old 03-10-2017, 04:35 PM
  #3072
Dowmer
Dowmer's Avatar
Rooster,
i have a full size pilot. That adds some, especially since he sits behind the CG. That would require more nose weight.
Your pkane at 26 will fly real nice. Actually quite a floater.
Old 03-10-2017, 05:17 PM
  #3073
zrooster
Rooster,
Checks! It was definitely a floater on the maiden!
By the way, did you put a video on YouTube dealing with some elevator flutter?
Old 03-10-2017, 06:05 PM
  #3074
Dowmer
Dowmer's Avatar
Ya, that was me. I nearly lost it but was able to land it before it completely came apart. I also posted videos on my working cowl flaps.
Old 03-11-2017, 06:18 AM
  #3075
zrooster
Yeah, saw those too. Thought that was a really cool mod!
