ESM FW D-9
Old 01-12-2014, 01:37 AM
  #2326
snickarn
Originally Posted by thunder21
The ESM V3 retracts for the D9 came with a tailwheel, and it was unusable in it's stock form.
I ended up using the lower part with a small electric retract unit which has held up for a couple dozen flights now. It saved over half of the weight of the original unit and works very nicely.
http://www.rcuniverse.com/forum/rc-w...l#post11465354
I have done almost the same thing to mine Focke Wulf.
http://www.youtube.com/watch?v=VkVXlkHJoyk
Old 01-12-2014, 04:26 PM
  #2327
ticketec
Looks good!
I have a few busted up electric retracts sitting here at home looking for a new life, and I haven't installed the retractable tail wheel in mine yet, so might have to look into your idea
dave
Old 01-12-2014, 11:41 PM
  #2328
deadstick79
deadstick79's Avatar
Well, the retracts work! The right one hits the front well edge and I really don't want to cut into the rib and the balsa block for clearance. And that is with the stock wheels! I have Williams Bros. wheels that are even a 1/4 in. bigger! I'm thinking about putting a very thin ply spacer piece (2mm) under the retract mount on just the front. It wouldn't put the wheels back too far when deployed since the rake is severe to begin with! Ya think?
Old 01-13-2014, 12:22 AM
  #2329
thunder21
thunder21's Avatar
I had to trim the rear retract rail to get my wheels to fit. It wasn't much, just a few mm. The retract unit now sits at a slight angle.
Old 01-13-2014, 03:41 AM
  #2330
n8622t
My Feedback: (8)
Mount the flap horns at the same distance from the hinge line.... Most critical aspect of getting the same flap movement. One servo in and one out and yer good to go with a Y harness and set your control arms as close as you can on the servo shaft
Old 01-13-2014, 04:46 AM
  #2331
Dowmer
Dowmer's Avatar
Hey guys, which William Bros. Balloon style wheels do I need. There are two types of 5 1/4 inch. Which part number?
Jason
Old 01-13-2014, 05:48 AM
  #2332
HoundDog
My Feedback: (49)
HoundDog's Avatar
Why isn't the wheel concentric with the wheel well? Strut too short or ???
Old 01-13-2014, 08:17 AM
  #2333
deadstick79
Jason
eh Jason,
The wheels are actually 4-1/2" Will Bros. P/N 12100
Dan
Old 01-13-2014, 08:20 AM
  #2334
deadstick79
I had cut the rear rails as Ram, Kaloq and others had done to get the toe-out.
Dan
Old 01-13-2014, 09:06 AM
  #2335
Ramstein44
My Feedback: (157)
Ramstein44's Avatar
Jason
You want the 14500. The balloons work but are fat!!. The 14500 are better looking IMO and fit better. Here is a pic on the TF190. I've yet to get them on the ESM but working on it.
Name:	Flight FW190A 006.jpg
Old 01-13-2014, 01:25 PM
  #2336
thunder21
thunder21's Avatar
The wheels are the 5-1/4" Williams Bros Balloon style wheels. The wheel opening is much larger than stock at this point.
Full scale wheel:
ID:	1957336   Click image for larger version
Old 01-13-2014, 03:25 PM
  #2337
ticketec
Don't worry, I removed a lot more material to get the sierras in with the glennis wheels
Old 01-13-2014, 04:09 PM
  #2338
Katniss
Katniss's Avatar
Dan
I think you meant to get RID of the toe out?
Old 01-13-2014, 04:24 PM
  #2339
Dowmer
Dowmer's Avatar
Thanks everyone. Ram, those wheels look nice, I'll give them a try on the ESM bird, 14500 it is. I think the thinner profile will help getting them in the well.
Jason
Old 01-14-2014, 08:07 AM
  #2340
deadstick79
I stand corrected!
Old 01-14-2014, 08:12 AM
  #2341
deadstick79
I used the jump box inflator to fill the retract system! It only shows that it's putting in 71psi and doesn't go higher than that! If I continue, it pops the fill line out of the inflator every time!
I get three solid retracting and deploying cycles. On the fourth one the right retract goes up about 80 percent and then slows down but does finally retract all the way after about 5 seconds.
Is this acceptable behavior?
Dan
Old 01-14-2014, 08:28 AM
  #2342
vertical grimmace
vertical grimmace's Avatar
Not sure what sized tank you are using (I use the large Robart on my planes this size), but I can get around 20 retractions off of 100psi before they quit working. Now, I do not know how many you want to do during a flight, but 3 seems kinda weak. You might want to pump it up and see how many you get after it has sat for a few hours. Then you will know if it is holding pressure.
Old 01-14-2014, 09:04 AM
  #2343
deadstick79
I have the same Robart tank! My inflator claims it will do 100psi but it isn't so I'm stymied!
Old 01-14-2014, 09:12 AM
  #2344
vertical grimmace
Sounds like you need a pump.
Old 01-14-2014, 10:44 AM
  #2345
deadstick79
Mystery solved!
I was using the "football" needle to fill the system and it would only go to 71 psi. I used the "stock" end used for tires and I was able to get the 100psi and I could see the pressure valve pin extend all the way! I got and easy ten cycles but I don't have all the fitting screw caps on yet either! I think it should work out right now!
Dan
Old 01-14-2014, 02:00 PM
  #2346
HoundDog
My Feedback: (49)
HoundDog's Avatar
Robart shows only F4U Gear for ESM models. What gear are U using from robart? For about $250 U can convert to electric ...
Solves a lot of problems and they are slower and more real with out all the screwing around with the robart air bleeder valves.
Just a suggestion.
Old 01-14-2014, 03:38 PM
  #2347
Katniss
Katniss's Avatar
Electric gear are not foolproof. They can fail also or refuse to deploy... or whatever else.
I do believe that the gear Deadstick has, he mentioned this a bit ago, that he's got the Sierra retracts but is using robart valves, air lines and air tank. You do not need an air valve with bleeder needles. Robart sells air line restrictors you put in the airlines and those work very well to slow down the retract cycle of the gear. Just a suggestion
Old 01-14-2014, 04:05 PM
  #2348
deadstick79
Just a suggestion.
Kat is correct!
I do have the Sierras'. I wanted to use the ESM electric Gen3s' but they have been discontinued due to problems I believe they just couldn't solve!
Anywho, the retracts are working great now and I'm able to get 100psi using the tire type filling fitting. I was using the football pin type to fill but it wouldn't fill more than 71psi.
Problem solved!
Just got to slap the motor on put electric gear in and get the CG figured out and she should be ready to maiden ;-)
Dan
Old 01-14-2014, 04:06 PM
  #2349
STICK MODE
STICK MODE's Avatar
true
Old 01-20-2014, 08:49 AM
  #2350
70 ragtop
My Feedback: (24)
Dora has been sitting around for some time, and I hope to focus on it and get it done soon! What is the correct color for the gear struts and wheel wells, and where is a good place to buy?
Mke
