TF FW190 GIANT ARF
#3151
My Feedback: (8)
http://youtu.be/YFPrW6Ls29E
Ok. So I picked this up from a fellow flyer, and I came across one thing that doesn't look right on the retracts. Which one is right?? Take a look
is this adjustable? Fixable? I hate to mess with settings since they open and close well.
#3155
My Feedback: (10)
hey guys... Tim Johnson had his camera at the flightline sunday and put this up for me... it even makes it look like I know what I'm doing...
https://www.facebook.com/photo.php?v...type=2&theater
#3156
There is a modification to help prevent bent pins. It involves adding a second plastic block to support the pins better. As far as I have been able to gather, this is also a problem W/the pneumatics as they are mechanically the same.
#3157
Wrong material was used in the pin in the first production batches, that is all.
#3160
My Feedback: (14)
I have tried contacting Robart to BUY a couple of these plastic blocks - but they dont even have the courtesy to answer emails -( ERIC - do you read this at all ) so does any one know if they are even still available ?
Im thinking of making a couple out of ply - which should do the job ....
would now like to add Joe at Robart; very promptly too - has sent me the two new support blocks, I have them fitted and hope they do the job - along with binning the stock foamy wheels and adding 5" Dubro ones ...Thanks Joe :-)
#3161
I suggest you go back in this thread and read about it, then you will know what to do.
A direct mail to [email protected] with part numbers in the mail, address, everything needed.
#3163
My Feedback: (14)
Thanks for that - I will try Joe - the address for the email I was using was sales@robart - which should have got some action ....and the part list above is great - but I have no idea what the correct part no is to order out of the 6 parts
#3164
My Feedback: (10)
Okay... my ARF Flyin Axis brethren...
Had 5 great flights today all greased landings and go to pull the wing off the fuse (packing up at noon) and I see a bunch on cracks under the monokote on the bottom of the right wing panel (center section to the root)... Any of you seen this?
#3165
Sparky, do you mean cracks in the balsa skin? No, havent seen that.
Doesnt sound good!! Perhaps you need to cut it open and have look inside.
Perhaps you've had a hard landing earlier on?
#3167
My Feedback: (10)
well.. I got a txt from one of my flight line buddy who apparently failed to mention that he "may" have heard a crack in the balsa when he offered to put my plane on it's wheels early today... I have a pic but it just shows a crack near the center section along one of the sheeting balsa...
#3170
My Feedback: (45)
#3171
Another note on the bent pins on Robart Retracts. Yes, you can add a second block with the electric retracts to strengthen the joint, but I don't see how you could do it with the air retracts. The connection from the air cylinder rod is much different than the electric version, and I don't see a way to make it work. By the way, the last time I talked to Robart they mentioned that all of the new trunions (that's the part with the pin) have the dual pin on them. The air retracts come with a single pin.
We have had some success bending the pins back, but every time you do that it likely makes them weaker.
Had some fun at the Owatonna Warbird event this past weekend. Got a bit close flying formation with the two 190's when we were trying to avoid another aircraft that lifted off into our pattern (as in we had a Mid Air collision). Good news is we got both planes down ok and only need some minor repairs. Landed mine with half an elevator and no rudder. The other plane had half of one side of the prop broke off. It caused a bunch of screws to vibrate loose, but didn't break the firewall. Here's a couple of photos.
#3172
My Feedback: (10)
That's such a bummer... I actually have a right side horizontal stab on the shelf... I would've sent it to you but it look like you got the left side like me...
#3174
Dave,
I hate to chime in on this thread, but I'm trying to get your plans for your 1/4 scale DVI? I understand it's quite the airplane. Please let me know "how " to get in touch with you. I could possibly use CAD or a hard copy.
Ray
Ray
#3175
My Feedback: (10)
Where is a Source to get more realistic Machine Guns for my Top Flite FW190; I can live with the ones provided for the wings but would like to change the ones they provided for the Gun Hood; I know someone had a Lathe and they used and Machined the ones that came with their TF FW190 to be more scale like, I don't have a Lathe, wish I did, hey good excuse to get one.......nay, the wife would have a coronary.
Thanks.
Thanks.
