Reload this Page >
TF FW190 GIANT ARF
TF FW190 GIANT ARF
Old 05-11-2015, 08:10 AM
  #3801
RCSYNDROME
Erwin
You could also use the jtec pitts muffler with the DLE 61cc.
Available from TowerHobbies.
Old 05-11-2015, 12:53 PM
  #3802
SrTelemaster150
SrTelemaster150's Avatar
Originally Posted by RCSYNDROME
Hi all.
Have someone considered the saito 300 twin motor for this plane?
I don't know which motor to get. Dle 55, Saito 300 twin.
Hi.
If I buy the FA-300T-TDP I still have to buy the gas conversion kit.
For that amount of money I could just as well buy the Saito FG-57TS motor.
But I am confused as some people mention problems with the FG-57TS and the FG-84R motors.
Then sometimes I think to just go with the DLE 55RA.
I can also use the DLE 55 in more planes than the Saito motors if the FW-190 gets _)(*)(&^*^% lol..................
Then why did you mention the 300T in the 1st place?
Old 05-11-2015, 08:53 PM
  #3803
RCSYNDROME
Because it is available in shop.
FG 57 is not available, waiting for stock.
Old 05-12-2015, 02:26 AM
  #3804
RCSYNDROME
Got hold of a Saito fg57t for a special price because the box is damaged.
The Saito fg 57TS is the newer revised engine but they don't have stock.
Don't know if I must take the 57t for special price.
Are some of you guys using the Saito 57T.
Any problems with this older engine????
Old 05-12-2015, 04:16 AM
  #3805
SrTelemaster150
There are no internal differences between the various FG-57T engines that I am aware of. In fact, they all use FA-300T rods, crank & bearings. The only differences in the FG-57T and FA-300T rotating assemblies are the FA-180 bore size piston that is .5mm taller to compensate for the shorter FA-150 based stroke of the FA-300T crank that is utilized in the FG -57T, and the FA-180 ring.
The ignition systems on early Saito FG engines were problematic. They were not based on Hall effect triggering like the C&H or the Chinese knock off RCXEL systems. The carburetors are proprietary & rebuild kits aren't available. Saito wants to sell you a $160 carburetor when (not if) the diaphragms go south. Many buyers of early FG-30s ended up spending more to fit the engines to the C&H gas conversions in order to get reliable service.
I would investigate the ignition system on that FG-57T, & if it is not a Hall affect triggered CDI sytem, you might be money ahead to buy the FA-300T & convert it to gas.
Is the FA-300T the dual carb version? If it is, I would be interested in the carbs, manifolds & linkage to offset some of the expense to convert to gas if you decide to go that route. In the methanol versions, the dual carberators are much better as far as balancing the cylinders @ idle & midrange.
Old 05-12-2015, 04:25 AM
  #3806
SrTelemaster150
Default FG-57T Thread
HERE IS A THREAD ABOUT THE FG-57T. Post #113 through #140 on page 5 & 6 address the difficulty of obtaining service parts for the carburetor.
The C&H gas conversions use off the shelf Zama or Walbro carburetors that use readily available rebuild kits.
Old 05-12-2015, 04:33 AM
  #3807
SrTelemaster150
Default C&H FA-270/300T Gas Conversion
http://youtu.be/M9t5UOq5Eso
Old 05-12-2015, 05:53 AM
  #3808
RCSYNDROME
Yes it is the dual carb FA300TTDP brand new in box.
I can buy it at hobby shop for R10 000 South - African Rand. About 1200$
I will have to import the conversion kit as I live in South - Africa.
Old 05-12-2015, 06:48 AM
  #3809
SrTelemaster150
How much is the FG-57T & exactly which model is it? There are, I believe, 3 different versions. If you find out which version it is I can research the ignition system.
Adrian has exported conversions I believe. An e-mail to him will be promptly answered. I usually advise people to call him, but in your case, that could be expensive.
Old 05-12-2015, 08:03 AM
  #3810
RCSYNDROME
The importers left me an e mail.
They did not say which version of the FG - 57T it is. Will find out. It will be about $1260 if I convert it to dollars.
Old 05-12-2015, 09:50 AM
  #3811
HoundDog
My Feedback: (49)
HoundDog's Avatar
In My Opinion the best for GS is in this order is Gasoline, Electric, Glow. My question why would anyone but an avid massicust want to screw with Glow. It's Greasy, Messy Oily and just down right nasty. Yes that's all we had and it was cheaper. Today with the advent of much less expensive well made and easy to maintain Gasoline engines it's just a no brainier. Haven't seen many Glow style converted to gas that were worth their salt nor High Price. Now before U all go bonkers and call me a blasphemer or something it again JMHO. and just like AWHOLES every ones got one some more.
But then every one has different likes and dislikes just expressing mine as U do yours.Have an great day.
Old 05-12-2015, 11:49 AM
  #3812
SrTelemaster150
The old version is FG-57T. The new version is FG-57TS.
Old 05-12-2015, 12:01 PM
  #3813
SrTelemaster150
I agree IF Glow Ignition (GI) is employed. I also have a dim view of engines designed for GI that are converted to gasoline.
However, when methanol is combined with CDI, a 4-stroke engine can make as much as 40% more power than a similar sized engine of the same design burning gasoline. Methanol will allow much more aggressive tuning such as ignition advance & compression ratio. Each of these factors can be easily altered. Fuel economy is also significantly improved with CDI/methanol over GI.
My high compression FA-180 will churn out just under 4 HP if I put the nitro to it. The FG-30 gas version of the same engine makes about 2.4 HP. It can also run on a straight methanol/lube mix. Methanol can be had for a little as $5 in gallon jugs or about $100 for a 55 gallon drum.
Methanol is safer to transport & it doesn't stink like gasoline. Saito engines run much cooler on methanol/CDI compared to gasoline although they will run a little hotter with CDI than with GI when the same methanol fuel is employed.
Old 05-12-2015, 01:11 PM
  #3814
RCSYNDROME
I know the new version is the FG-57TS.
I am talking about the FG-57T.
Old 05-12-2015, 08:48 PM
  #3815
RCSYNDROME
I unpacked the kit last night.
This is a piece of &*^^%^%%$ kit.
Got two left aileron servo hatches.
Plastic exhausts were also fixed with different colour black paint or something.
I am returning this garbage.
Paid lots of money for this.
Will never ever buy TOP FLITE Arf again...
Old 05-12-2015, 10:32 PM
  #3816
kwik
kwik's Avatar
I have two FG-57 T's. Very good engines. No problems with them that you wont have with any other engine.
The ignition is very good quality too. As allways, keep the voltage within range. The voltage range is printed on the ignition box..
The ignition box is RcExl with a Saito marking on it too. But as with any other engine, make sure you stay within the voltage range.
The later engines comes with a wider voltage ramge. When the first engines came, this was in the period when many switched to A123 batteries.
I did so too. They are 7.2 volts I think, when fully charged. That burned my box, I think it was rated 4.8-6 Volts.
Now the latest ignition boxes are up to 8Volts, I think. Its printed on the box.
Another thing that has confused many, I think, is the L and H needles. I think they are finer coarsed than an ordinary Walbro.
This means that on this Walbro, you might have to turn the needles more that you are used too.
Another thing is that this fourstroke boxer behaves a bit differently than a two stroke single, when leaned.
It starts running on just one cylinder.
hehe.
Just give it a bit more petrol.
And since it has just one carb, it get is difficult to adjust it so both cylinders gets the same amount of fuel.
But rather that, than having to adjust two carbs !
Just dont get too hung up in a bit of difference between the two cylinders.Just have some oil in the crank case before first startup,
and fly it.
Old 05-13-2015, 04:03 AM
  #3817
SrTelemaster150
I can't believe they are still doing that!
I bought mine about 3 months after they 1st came out in 2013 and 2 years later they haven't addressed the issue?
  #3818
SrTelemaster150
hehe.
and fly it.
Here's the guy that knows these engines from experience.
Old 05-13-2015, 04:07 AM
  #3819
cjray
My Feedback: (25)
cjray's Avatar
Mine didn't have that issue. Maybe he received old stock.
Old 05-13-2015, 07:59 AM
  #3820
RCSYNDROME
Returned the kit. Got my money back.
Busy with esm spitfire. After that i got my esm p51d mustang and then the esm bf 109.
Waiting in line lol.
Old 05-13-2015, 09:50 AM
  #3821
Hot Rod Todd
Hot Rod Todd's Avatar
Glad you were able to return it. It might not seem like a good deal to you in South Africa, but here in the US the Top Flite kit is less expensive than an equivalent ESM kit (shipping and everything included). It may have some issues, but the hardware and ease of assembly is also far superior to any ESM kit I've seen.
We'll just keep enjoying ours!
ID:	2095687   Click image for larger version
Old 05-13-2015, 10:57 AM
  #3822
ForcesR
I would never purchase another ESM product; my 89" WS Spitfire ARF turned into a major assembly/rework project for the ailerons, flaps, elevators and engine mounting tube/cylinder etc. I know two other RC flyers who purchased ESM Spitfires in 2012 at the same time as me and they had similar major problems with their Spitfires. All three Spitfires have still not flown due to replacement parts that were ordered and still have not arrived after 2+ years. It's a real disappointment knowing we will have good looking Spitfires when assembled and flown, unfortunately no spare parts have stopped completion of assembly
Roger
Old 05-13-2015, 12:27 PM
  #3823
RCSYNDROME
Actually i got the kit for the towerhobbies price here in south africa.
Esm kits are much cheaper here. I know they have more work.
I was expecting better quality from topflite arf's.
Their quality is not what it used to be.
I like the quality of pilot arf's.
I am flying a 30% edge 540 with a gp 123cc motor. Awesomeness.....
Old 05-16-2015, 02:42 AM
  #3824
ENZ5573
My Feedback: (7)
Hi all,
Here is another Video of my TF FW190
https://www.youtube.com/watch?v=Iubtm2Nryqc
Old 05-16-2015, 03:02 AM
  #3825
LDM
My Feedback: (15)
Nice flying and plane !!
How do you like the eletric start , any complications ?
