Reload this Page >
TF FW190 GIANT ARF
TF FW190 GIANT ARF
Old 09-14-2013, 03:55 AM
  #2051
doolittles
I am done with TOP FLITE MODELS at one time i have all of them . i started to buy the giant scales you get ( NO ) support from top flite they said to go to another for help and supplies to finish there model ! i had e-mail them they stop replying .
So i am done with Top-flites model Doolittles
Old 09-14-2013, 07:53 AM
  #2052
MX240
MX240's Avatar
OK,
I've been buying TF models since the late fifties (control line) and have always been treated well.
Guess that will mean more of their planes for the rest of us
Old 09-14-2013, 08:51 AM
  #2053
doolittles
Cool
I Also have been doing this for 50 years ! So you can have them . Thanks
Old 09-20-2013, 06:51 AM
  #2054
mike day
were did you get that pilot looks awsome?
Old 09-20-2013, 07:08 AM
  #2055
motor12
motor12's Avatar
If you're referring to Motor12's pilot, thanks. It's an Aces of Iron product. It comes unpainted. My wife painted this guy (Gunther) by following the basic instructions on the Aces of Iron site.
Old 09-20-2013, 08:25 AM
  #2056
MX240
MX240's Avatar
I used Futaba 3305's and S9153's on the flaps.
Those flaps hanging down on final will kill a lesser servo I have found. Need servo torque.
Old 09-22-2013, 09:18 PM
  #2057
sparky4lawndart
My Feedback: (10)
sparky4lawndart's Avatar
Anyone have any ideas on preventing ground looping?
Old 09-23-2013, 01:30 AM
  #2058
kwik
kwik's Avatar
Folks, I have received the Robart Pneumatic version of the main gear.
They are supposed to be mounted using 6 screws on each. Unfortunately I cannot find these screws now, so I need to order them from my favourite nuts and bolts supplier.
So, could anyone please tell me what the inch-dimension is on these screws?
Please ? It would help me a lot, since we are normally using metric stuff on a daily basis.
Old 09-23-2013, 03:10 AM
  #2059
dasintex
My Feedback: (10)
dasintex's Avatar
Gyro on the Rudder/Tail Wheel; I use them on all my tail dragging Warbirds, work great, eliminates ground looping, do a search on RCU Airplane Gyro, Rudder Gyro, etc; tons of info.
Old 09-23-2013, 08:27 AM
  #2060
SteveD-RCU
SteveD-RCU's Avatar
Still working on mine,I finally got a coat of primer on it,I still haven't decided on a powerplant yet.I'm considering a Saito300 converted to ignition,DA-50,or the yet to be released 450 gasser.I got the sliding canopy idea from Ram..thanks for those pics
ID:	1924188   Click image for larger version
ID:	1924189   Click image for larger version
Old 09-23-2013, 08:30 AM
  #2061
SrTelemaster150
SrTelemaster150's Avatar
Originally Posted by SteveD-RCU
Still working on mine,I finally got a coat of primer on it,I still haven't decided on a powerplant yet.I'm considering a Saito300 converted to ignition,DA-50,or the yet to be released 450 gasser.I got the sliding canopy idea fro Ram..thanks for those pics
Saito 300T is a sweetheart W/CDI.
http://www.youtube.com/watch?v=vdmLu13UJzs
Old 09-23-2013, 11:27 AM
  #2062
Ramstein44
My Feedback: (157)
Ramstein44's Avatar
Loving it Steve!! I sold mine but I plan to do another here soon. I figured a real sweet way of making the canopy slide pneumatic and I made templates for the main Sierra gear. Installing a G62, sierra gear and a few modifications. Not too complicated.
Going with this scheme..
Old 09-23-2013, 12:02 PM
  #2063
SWORDSN
My Feedback: (13)
On my TF P40 and P47 they were packed with the included hardware. It is listed as a #6 screw. Be sure to use the 1/2 inch long screw directly over the air cylinder.The other 5 are 3/4 inch long
Old 09-23-2013, 12:40 PM
  #2064
kwik
kwik's Avatar
Yes, but I cannot order screws , unless I know the dimension.
The length is of no interest. I can measure that. But thanks for the heads up on the one above the cylinder.
Do you know the dimension? In that case could you please tell me?
I don't know what #6 means. I do understand 4-40, or 2-56. Or 5/32, or 1/4, and so on.
My guess is that it is 4-40 ?
Here is where I normally order nuts and bolts, but it isnt easy for us mm-guys ;
http://www.modelfixings.co.uk/unf_cap_screws.htm
10-32, 0-80, 4-48 .....makes my head spin....( no 4-40....)
I don't have any inch screws in my inventory, so I can check. Plenty of mm screws, but no inch stuff.
Old 09-23-2013, 01:07 PM
  #2065
kwik
kwik's Avatar
I found the answer in the place I allways check last. In the manual; The dimension is 6-32 x 3/4"
Old 09-23-2013, 03:18 PM
  #2066
CCFPILOT
If the 109 is anything like the TF P51 or the TF P47, then the should be sheet metal screws. They both use #6 sheet metal screws. Here's a link. http://www3.towerhobbies.com/cgi-bin...?&I=LXK009&P=7 to #6x3/4.
Old 09-23-2013, 04:41 PM
  #2067
SWORDSN
My Feedback: (13)
Yes but remember 1/2 over the cylinder!
Old 09-23-2013, 06:18 PM
  #2068
SteveD-RCU
SteveD-RCU's Avatar
I'm going to convert mine soon and see how that goes..I just ordered a puller&/seperator for the driver..
Old 09-23-2013, 06:24 PM
  #2069
SteveD-RCU
SteveD-RCU's Avatar
Thats an awesome scheme Ram..looking forward to it..
Old 09-23-2013, 09:41 PM
  #2070
kwik
kwik's Avatar
That makes me worried. Manuals aren't allways correct......
There are blind nuts on the Fw-190 for the gear. Is it blind nuts on the TF-P-51 and P-47 too ?
Or perhaps just wood'en holes?
If they have blind nuts too, then I'd better order those #6 screws too, just to be sure.
But the #6 screws looks like they are supposed to be used for wood? It really is a good idea.
Use them first, until you rip them out, then go for inserts.
Old 09-24-2013, 05:54 AM
  #2071
Ramstein44
My Feedback: (157)
Ramstein44's Avatar
I don't use the majority of the hardware these ARF's come with. Most of the time it's cheap, so it's best to play it safe and do it right the first time.. I definitely go with blind nuts. JMO. On my meister FW190, the gears mounting holes were enlarged to fit small nylon bolts with blind nuts so if the gear rip out, the mounts won't go with them.
Old 09-24-2013, 06:26 AM
  #2072
BJ64
BJ64's Avatar
How much is involved in getting a sliding canopy happening?
That would be kewl
BJ
Old 09-24-2013, 06:31 AM
  #2073
OldScaleGuy
OldScaleGuy's Avatar
A fellow modeler maidened his TF Fw190 this past Sunday. He completely refinished it with a lot of detail and weathering, it looks great and flew perfectly with a DLE-55.
Old 09-24-2013, 06:35 AM
  #2074
Ramstein44
My Feedback: (157)
Ramstein44's Avatar
That would be kewl
BJ
After we move here soon, I'll show you.. unless someone beats me to it but every method is different.
Old 09-24-2013, 06:43 AM
  #2075
BJ64
BJ64's Avatar
You've done a few of them.... so I'll stick with what you suggest
BJ
