Reload this Page >
TOP FLITE GIANT SCALE P51 ARC
Old 06-02-2013, 09:34 PM
  #201
Chad Veich
My Feedback: (60)
Default RE: TOP FLITE GIANT SCALE P51 ARC
ORIGINAL: flyingchef
...it took me about most of the day to get all rivets imprinted on both side.
And now you just have to go back and fill them all in since Mustang wings were sanded and filled at the factory! Just funnin' you Bruno, it looks awesome.
Old 06-03-2013, 02:29 AM
  #202
pacoflyer
My Feedback: (23)
Chad,
Good catch and you are correct. That's were we get the product Bondo ,as it was created to fill the rivet holes on the P-51.
Good flying,
paul
Old 06-03-2013, 02:36 AM
  #203
JSZ
My Feedback: (73)
JSZ's Avatar
Hello, I'm in the market for a GS P-51 arc wing. If you have one or know we're I can get one I would appreciate it. Last resort will be to get the arf wing which I'm trying to avoid. Thanks
Old 06-03-2013, 05:24 AM
  #204
v6goose
v6goose's Avatar
Looking really good, congrats.
Did you use the Aerotech kit for your inner doors and actuator covers etc?
Cheers
Goose
Old 06-03-2013, 09:29 AM
  #205
flyingchef
My Feedback: (93)
flyingchef's Avatar
The only section on the mustang that is filled with Bondo is the leading edge near the wing root. Some wing sections were primed with zinc-chromate yellow filler then painted silver resulting (in some airplanes)that a slight rivets indentation was still visible. I am finishing my model as "Lil' Margaret', the wing was painted but doesn't seems to be filled, also instead of polishing the plane I give it a dull look.
After applying the rivets on my wing I sanded with 220 grids to reduce the effect, once painted with automotive silver I'm looking to get the same effect.
The inner and outer gear doors are from aerotech, BVM cylinders.
ID:	1888553   Click image for larger version
ID:	1888554   Click image for larger version
Old 06-03-2013, 11:40 AM
  #206
vatechguy3
can you post some details about your elevator linkage arrangement?
there have been some issues with the giant scale TF corsair and some deadplay at high speeds.
thanks
tony
Old 06-03-2013, 11:46 AM
  #207
Chad Veich
My Feedback: (60)
It's a moot point since you are duplicating a restored airplane Bruno but a vast amount of the Mustang's wing was filled at the factory. I doubt that most restored aircraft duplicate this feature. Here is a diagram from Aj-Press showing the process.
Blue areas - two layers filler polished for a smooth surface and then painted.
Green areas - one layer of filler polished for a smooth surface and then painted.
Yellow areas - silver paint (on bare metal aircraft of course)
White areas - bare metal
[/URL]
Old 06-03-2013, 03:50 PM
  #208
flyingchef
My Feedback: (93)
flyingchef's Avatar
You are correct Chad, I have seen this reference as well. I would assume that any gain of speed is an advantage especially when you have someone doing the shooting on your tail. I read sometime ago that a mile or two an hour could make the difference in a dog-fight.
Thank you for the info, I will get ready for all questions I will get at the flying field about the rivets on the wing. Can always blame it on the French!
Old 06-03-2013, 04:03 PM
  #209
flyingchef
My Feedback: (93)
flyingchef's Avatar
Tony,
I use the stock setup to actuate my elevator with an exception is that I added an extra support for the rod sleeves. The best way is to test by pushing your elevator against the control while holding the servo arm still, if the elevator move then you need to add some support for the control rod.
Central Hobbies sells some nice Carbon fiber rods with titanium ends, those are my favorite to use on elevator control.
http://www.centralhobbies.com/contro...e/pushrod.html
Old 06-03-2013, 04:08 PM
  #210
flyingchef
My Feedback: (93)
flyingchef's Avatar
Wing with star&bar partially painted.
Old 06-03-2013, 07:16 PM
  #211
Chad Veich
My Feedback: (60)
Hard to believe we are looking at something that started out as a Top Flite ARC! I'd love to bash one of these into a "Ghalloping Ghost" tribute, or maybe "Voodoo". Ooh, Bob Hoover's "Old Yeller" would be cool too, or how about... (I need to work on staying focused!)
Old 06-03-2013, 07:34 PM
  #212
Leroy Gardner
Bruno you got to leave it to Chad, if you do something wrong he will let you know and he is always right. One thing is for sure, your rivets are a eye popper and guys will drool all over it so don't let anyone get too close. Ha,ha I did it to mine and it draws a lot of attention, you went a bit further with your rivets and they look great, very nice job indeed.
Old 06-04-2013, 05:55 AM
  #213
glazier808
glazier808's Avatar
Looks great Bruno!
That's what nice clean rivets are supposed to look like.
Leroy,
Don't hate on Chad, he doesn't always have to be right, he just knows his stuff. Big difference when trying to be helpful.
Casey
Old 06-04-2013, 09:29 AM
  #214
Leroy Gardner
ORIGINAL: glazier808
Looks great Bruno!
Leroy,
Casey
No Casey, I don't bash Chad, we have known each other for some time and he has helped me more than once, the guy is a information factory for RC and really knows his stuff and of course he will point it out. Great having him, very talented man, not opinionated in any way.
Old 06-17-2013, 08:35 AM
  #215
flyingchef
My Feedback: (93)
flyingchef's Avatar
Some more work done this weekend, I was at the Warbirds Over Denver the weekend before, great event if you haven't attended!
I finished applying the aluminum tape and added more details especially for the fuselage panel by the trailing edge wing's root.
I built up the panel then finished with aluminum tape and some #80 screws.
For the ailerons, flaps, and elevators I made some control horns out of G10, painted then silver. The connection to the servos are 4-40 ball links.
Few more small hatch details then rivets and paint, until then I cut the Star&Bar fuselage mask.
ID:	1892625   Click image for larger version
ID:	1892626   Click image for larger version
ID:	1892627   Click image for larger version
ID:	1892628   Click image for larger version
Old 06-17-2013, 08:39 AM
  #216
flyingchef
My Feedback: (93)
flyingchef's Avatar
Side panel.
ID:	1892630   Click image for larger version
ID:	1892631   Click image for larger version
Old 06-17-2013, 08:47 AM
  #217
flyingchef
My Feedback: (93)
flyingchef's Avatar
elevators.
ID:	1892640   Click image for larger version
ID:	1892641   Click image for larger version
Old 06-17-2013, 08:51 AM
  #218
flyingchef
My Feedback: (93)
flyingchef's Avatar
Paint masks.
ID:	1892650   Click image for larger version
Old 06-17-2013, 09:32 AM
  #219
Ramstein44
My Feedback: (157)
Ramstein44's Avatar
What a beauty. Awesome work there chef!
Old 06-17-2013, 11:04 AM
  #220
flyingchef
My Feedback: (93)
flyingchef's Avatar
Thanks Charles, Should be flying soon!
I looked at the fit of my DLE222 in the Sea Fury cowl, can wait to get back working on it!
Old 10-02-2013, 04:02 PM
  #221
orthobird
I am getting ready to build this airplane, and wanted to ask you all a question.
i have a Zenoah G38 EI and a Saito FG 36 4 stroke engine. will either of these engines do this airplane justice?
i would like for it to be a speed demon of sorts.
both engines will spin an 18 x 8 prop at about 7300 rpm or so.
Old 10-02-2013, 04:18 PM
  #222
ccostant
My Feedback: (38)
ccostant's Avatar
Go with a DLE55 or DA50 for speed and performance, you won't be sorry. The other engines mentioned will not be enough engine for this plane. They may get you off the ground and fly the plane but you will be disappointed.
Old 10-02-2013, 04:20 PM
  #223
orthobird
thank you so much!!
Old 10-02-2013, 04:29 PM
  #224
Thunderbolt47
My Feedback: (8)
Thunderbolt47's Avatar
Agreed.
A G-62 is a good choice too. as long as you don't mind the carb sticking out the side. Plus they are bullet proof and can be bought cheap in the market place.
Old 10-02-2013, 04:31 PM
  #225
ccostant
My Feedback: (38)
ccostant's Avatar
Yes a G62 is another good choice.
