Reload this Page >
Top Flite Giant Scale Spitfire ARF
Old 11-07-2014, 09:44 AM
  #401
ForcesR
Originally Posted by JeffH
So the giant scale does not have the small, flat center section where the gear mounts? It just has a two piece wing with a center dihedral brace and the dihedral is set from the wing centerline?
JeffH; correct you are!
Old 11-07-2014, 10:50 AM
  #402
ForcesR
Originally Posted by ForcesR
Lifer; that is an excellent idea! I would never have thought of doing it that way; it's a lot less work and less complicated than the way I would do the wing dihedral change. That's what I like about these forums, someone always comes up with an easier way to do things. I will use this method to change the wing dihedral when I get my hands on the TF giant Spitfire.
Roger.
I have been sitting here thinking, why do I usually pick the difficult and most work intensive solution in modifying, building or repairing of RC aircraft? I believe the answer to my question has to do with the way I have been trained in my 35+ years in the aircraft industry.
We have to follow strict airworthiness engineering rules, regulations and policies in repairing, overhauling and the modifying of aircraft. The strict adherence to engineering rules, regulations and policies is due to safety concerns, as everyone knows, full size aircraft carry human beings and aircraft fly over inhabited dwellings, so safety is "Paramount".
I will have to train myself to think differently when building, repairing, or the modifying of RC aircraft. Although safety is still a concern, taking shortcuts to accomplish a given task is permitted and acceptable. The end result usually turns out the same; you have an airworthy, safe flying RC aircraft.
Roger
Old 11-07-2014, 02:06 PM
  #403
SpitfireMkII
My Feedback: (8)
Roger, it was a combination of 21 Merlins and Griffons plus three Hurricanes. Quite awesome for sure. Highly recommend A Duxford visit to every Spitfire/Warbird nut.
Old 11-07-2014, 02:10 PM
  #404
Shaun Evans
Shaun Evans's Avatar
Hi,
I got the Spit in today. If anyone was considering getting the Hobby King gear for their Spit, those gear are a drop-in fit. I mean they're literally a drop-in. The mounting holes even line up with the pre-installed blind nuts on the back of the gear plates. The axle lands dead center in the well, too. The strut cover fits flush over it as though it was made for these gear! What luck considering I don't really care for the Robarts AND these are less than half the price (and come with a scale tail wheel strut). I never thought I'd advocate a HK item, but these gear held 110 psi for 30 hours so I'm installing them.
Old 11-07-2014, 02:54 PM
  #405
Lifer
Lifer's Avatar
I have no experience with the HK gear but read a thread on their similar-sized AT-6 and they indicated that the metal in the gear was soft enough to break, not bend but break. I have had zero problems with Robart gears except for a few leaks in the valve and the plastic tee's. And, like many others have experienced, Robart does not answer their emails.
Old 11-07-2014, 03:11 PM
  #406
Shaun Evans
Hi,
I, too, am totally inexperienced with HK landing gear. I asked on one of these threads and a fellow said his were great after a season of flying. Otherwise, I'd never consider it since I pretty much think all HK stuff is junk. These I have sitting here, and I can't even remember where I got them. Part of some trade, I'm sure. For me, my issues with Robart have been their rotating gear. The cheesy frames on the 150/148 and don't get me started on the 615's. Their reputation with me is a sight better than HK, though!
ID:	2045717   Click image for larger version
ID:	2045718   Click image for larger version
Old 11-07-2014, 03:38 PM
  #407
SpitfireMkII
My Feedback: (8)
Is it just the photo or do the HK struts seem short? The wheel is not exactly centered, note the gap to the left. I only point this out because I had been considering ordering them, especially to get the tail strut.
Worked on the rudder a little today, the metal fairing will be changed, it's not actually attached yet, I'm not happy with it.
Old 11-07-2014, 04:01 PM
  #408
Shaun Evans
Hi,
They're centered. Not dead-on, but maybe 1/32" off. The shadows in the pic make it look much worse than it really is. What aren't you happy with with your rudder? Looks good to me?
Old 11-07-2014, 04:05 PM
  #409
SpitfireMkII
My Feedback: (8)
The metal fairing over the trim tab rod is too big and not shaped the way I want it.
Old 11-07-2014, 05:02 PM
  #410
Shaun Evans
Ah.
Well, I'm sure I'll be impressed with V2 as well.
Old 11-07-2014, 06:09 PM
  #411
SpitfireMkII
My Feedback: (8)
Thanks, I figured out a better way to bend the aluminum right before I left the shop. I'll see what I can do with it tomorrow.
Old 11-10-2014, 09:52 AM
  #412
Shaun Evans
Hi,
This ARF is easiest to put together so far. I've got all the servos in, the wing joined, the main gear installed (though I can't decide whether to use the HK tail unit which looks good but is connected to the bottom of the rudder via springs for steering or use the stock one with pull-pull), cowling cut for the engine/muffler and all the decals on. I did some simple panel lines with a pencil and wanted the decals on first so the lines will go over them. The box came on Friday and I should have this one ready to go by this time tomorrow.
Old 11-13-2014, 03:35 AM
  #413
Shaun Evans
Hi,
I ended up going with the stock tail unit since I didn't want to fiddle with installing some kind of hard-point into the base of the rudder for the steering spring arm. I never quite liked that system (with the springs) anyway. I'll find some other use for this nice-looking HK tail unit.
I did the mod with the aluminum grill on the cowl, too. It looked pretty cool and I think it'll help keep the 55 cool. For the EME on-board starter, I only had to open the cowl a tiny bit to accommodate it. All of the servos are in with all of the control surface linkages installed. I had a do-over with the tail pushrods because I guesstimated how much to cut off of the included 48" 4-40 rods, and I missed it by about 3". The dumb thing was I didn't notice it until I had done all of the bending/curving to get the drag and binding out of the rod where it exits the fuse plus installing the clevises and lock nuts. I flipped her over to solder the clevises at the servo end and noticed the rods were too short. Luckily, I had some in the GS Corsair box and borrowed those.
Name:	spit cowl grill.jpg
ID:	2047064   Click image for larger version
Old 11-13-2014, 01:49 PM
  #414
SpitfireMkII
My Feedback: (8)
Hey Shaun, you wouldn't want to sell that tailwheel would ya?
Decided to put the rudder and elevators on hold till parts arrive. Here some other bits I've been working on.
The radiator scoops are now in their "correct" location. Since it overlaps the flap servo, I made them removable. Added evergreen styrene to simulate the radiators.
Detailed the 20mm cannons and added the outer wing .303 barrels. The cannon ends are aluminum tube with a drilled out nut CA'd in place. The .303s are brass tube. Correctly sized? Who knows for sure but I think they look the part.
Although the stock dummy exhaust manifolds are acceptable, I decided I wanted them to have a little more scale appearance. These are from a guy in England. I don't have the details right now but can get them. They're going to take some fiddling to get a proper fit, the engine box and ballast will need to be relieved to allow for them to fit as you can see in the last photo.
Probably focus on the fuse for the next few shop sessions. That will include blending the cowl in a bit better and making the radio hatch behind the cockpit for my switches and retract valve.
ID:	2047172   Click image for larger version
ID:	2047173   Click image for larger version
ID:	2047177   Click image for larger version
Old 11-14-2014, 04:47 AM
  #415
ForcesR
SpitfireMKII; did you purchase the exhaust from Mike Skingle? I purchased exhausts, cannons and rear view mirror from Mike for my 89" WS ESM Spitfire, very impressed with what I received. The link is below if others are interested:
http://www.wsbudesign.f9.co.uk/acces...ns-cannons.htm
Roger
Old 11-14-2014, 09:12 PM
  #416
Shaun Evans
Spit,
Make me an offer.
Old 11-15-2014, 08:14 AM
  #417
SpitfireMkII
My Feedback: (8)
Quick test fit today to see how things line up. Usual top flite quality. Still a long way to go.
ID:	2047520   Click image for larger version
Old 11-17-2014, 08:23 PM
  #418
Katniss
Katniss's Avatar
subbed
Old 11-18-2014, 04:45 AM
  #419
Shaun Evans
Spit,
Did you get my reply re the tail strut?
Old 11-18-2014, 05:19 AM
  #420
SpitfireMkII
My Feedback: (8)
Hi Shaun, I just did this morning. Let's work through email instead of PMs. Yes I want it, let me know payment details at [email protected]
Many Thanks !
Mike
Old 11-18-2014, 09:54 AM
  #421
Katniss
Katniss's Avatar
Originally Posted by YellowAircraft
Hi,
I'm going to have to go back and look how I did it...but I do not recall running springs to the rudder at all. I think I ran pull/pull cable directly from the servo mounted up front. The rudder itself is not connected to the HK tail unit on mine.
Old 11-21-2014, 12:10 AM
  #422
Shaun Evans
Hi,
Any of you guys done a sliding canopy on your Spit? I just put one together. I didn't use brass channel but Plastruct styrene square tubing. The whole thing cost about $50 with the air cylinders and 4-5 hours to build and install.
Old 11-21-2014, 03:08 AM
  #423
SpitfireMkII
My Feedback: (8)
Did you get my messages regarding the TW strut? I'm probably not going to do the sliding canopy just to keep things simple and dependable. Might change my mind.
Old 11-22-2014, 04:54 PM
  #424
Shaun Evans
Hi,
Yeah, I did. How shall we proceed? Here's my canopy btw...
http://youtu.be/3vQ3eopMI18?list=UULzV1HEL2GMv7ReKPMp999A
Old 11-23-2014, 04:58 AM
  #425
SpitfireMkII
My Feedback: (8)
Pleas contact me through my email - [email protected] and let me know payment details.
Thanks, Mike
