ESM ZERO BUILD
My Feedback: (37)
RE: ESM ZERO BUILD
Your zero is looking great!
I crunched my World Model zero awhile back and kind missed how well it flew. 80" wing span, 19lbs with a Zenoah G45 in it was a perfect match, no CG weight needed and the motor ran flawlessly. The one thing I disliked about the WM zero was the shiny olive drab paint scheme. Can you confirm the ESM 80" wingspan and the cowl diameter? Thanks!
RE: ESM ZERO BUILD
ORIGINAL: fw190
...Can you confirm the ESM 80" wingspan and the cowl diameter? Thanks!
Cowling vertical 8.75", horizontal is 8" since it's oblong shaped.
Engine mount 5.75 horizontal, 6.75" vertical
RE: ESM ZERO BUILD
ORIGINAL: Flyin Hwn
Cowl diameter? I have a G-62 looking for a home
Cowling vertical diameter is 8.75" inches horizontal is 8". Since it's all oblong shaped.
How about a picture of the wheel wells
Sorry for all the questions but TBM site lacks necessary info
Mahalo
Mark
Mahalo
Mark
#33
My Feedback: (37)
RE: ESM ZERO BUILD
ORIGINAL: carrera mike
Wingspan is 88.7''.
Cowling vertical diameter is 8.75'' inches horizontal is 8''. Since it's all oblong shaped.
Engine mount 5.75 horizontal, 6.75'' vertical
ORIGINAL: fw190
...Can you confirm the ESM 80'' wingspan and the cowl diameter? Thanks!
Thanks for the info!
#36
RE: ESM ZERO BUILD
If it were me, I would ditch the pull pull on the elevator. You might reconsider the way you've got the wire actually attached to tiller bar also. By pulling the wire through the loop you've created several pinch points on the wire at the tiller connection point. I believe the side to side movement of either the rudder or the elevator with this set up will also grind the wire at the tiller bar connections eventually.
Why not just run a Carbon fiber rod back for the elevator connection? I've done this on all of my ESM planes and it's worked out fine.
Casey
Casey
#37
My Feedback: (157)
RE: ESM ZERO BUILD
+1. I've never like the wire setups they've chosen to use but worse case, get some of this stuff if you want to use the pull pull system..
http://www.donshobbyshop.com/product.aspx?cat=3#DHS Pull-Pull HD+ System (20 to 45 lbs.)
I personally like using a carbon fiber control rod for my setups if possible.
#38
RE: ESM ZERO BUILD
Hello to everyone there, i have one question about control rods. I'm currently building CMPro Zero 50cc and i placed 2 servos, one for each elevator halfs, in front and want to use two carbon tube as control rod for that purpose . Carbon tube has inner diameter 3mm and 5mm outer. On both ends of this i will insert and epoxy 3mmthread steel rod for metal clevis and ball links. My question is this carbon tube(3/5mm) strong enough or i need to insert into 3mm carbon rod for strength?
Can someone post some pictures of this setup(how you sort this out)....
I intend to do something like this but i will have 2 rods for each elevator half...what do you mean?
#40
RE: ESM ZERO BUILD
ORIGINAL: glazier808
Casey
Casey
Thanks Casey & Reimsetin! I myself dont like this factory setup. I was planning to copy my Aeroworks Edge setup, but definitely open for ideas. Do you have any pictures you could share pls. Ive been in aviation maintenance for 27 yrs now and we sure do not want any flight control linkages chaffing on anything.
Mike
#43
RE: ESM ZERO BUILD
ORIGINAL: disljenko
#44
RE: ESM ZERO BUILD
some work done in the last couple of nights. Im only able to put in couple of hours nightly coming from a full 10 hour work-day
You could see the forward rake thats already set by the factory for the landing.
Factory electric retracts with working sruts coming in tomorrow
#45
RE: ESM ZERO BUILD
Tail Section. nothing permanent yet, Tail wheel shown is the one that came in the box. The optional factory retracts came with better tail wheel
#47
RE: ESM ZERO BUILD
dry fit the optional factory electric retracts. Although seem like that the plastic tire/wheel that came in the box looks better sizewise than the alum looking ones that came with the optional fit retracts.
#49
RE: ESM ZERO BUILD
can you put a bigger wheel size on those offset struts or they wont fit;
thanks.
