Reload this Page >
FW-190 D9 1/5 by fokkerc.com
Old 12-09-2014, 11:11 AM
  #151
proteus_X3
My Feedback: (16)
Rumen,
incredible work my friend, looking foreword too your next update .Have you set a price point yet?I 'm also very interested in a Dora model Cheers: Rich
Old 12-09-2014, 11:20 AM
  #152
fokke
fokke's Avatar
Тhnak you so much for the good evaluation of my work
It is too early to think about the prices, I have so much work to finish especially with the composite model D 9 11 13
soon more pics with progress
Old 12-09-2014, 12:42 PM
  #153
proteus_X3
My Feedback: (16)
No worries my friend,maybe TA-152 is on the horizon
Old 12-09-2014, 08:28 PM
  #154
Nordicz
My Feedback: (7)
Rumen,
Very nice, I love the work you are doing not only on this project but on the others. I fell in love with the D9 years ago so I am very anxious to see your final outcome.
Z
Old 12-10-2014, 01:12 PM
  #155
vertical grimmace
vertical grimmace's Avatar
Bump
Old 12-10-2014, 10:44 PM
  #156
fokke
fokke's Avatar
Thanks Nordicz , I am in love in D9 to
Vertical grimmace , what you mean with Bump ?
Old 12-11-2014, 03:07 AM
  #157
fokke
fokke's Avatar
Hi again, I I started assembling the wings.
https://www.youtube.com/watch?v=jfby...ature=youtu.be
https://www.youtube.com/watch?v=jfbyLlCOtZs&feature=youtu.be
Old 12-11-2014, 08:31 AM
  #158
vertical grimmace
Very nice! I like the square stock on the leading edge. That ensures it is straight. Well, provided the stick is straight! looks like a good design.
Old 12-12-2014, 10:20 AM
  #159
fokke
fokke's Avatar
Yes , that was the idea, there is 10 mm z20mm balsa , I hope to be a good design. My idea is to cover with composite sandwich - herex and glass
Old 12-14-2014, 05:17 AM
  #160
fokke
fokke's Avatar
Hi guys, this is the material who I think to use for coverng of my wings. This is 2mm hard crust in the midle and glass fabrik on up and down as a sandwich
Old 12-17-2014, 02:16 PM
  #161
ticketec
So like flite skin but thicker?
  #162
ticketec
Old 12-17-2014, 10:16 PM
  #163
fokke
fokke's Avatar
No it is not , this material is not only glass , have Airex in the middle , so this is completely different from flite skin
Airex is : http://shop1.r-g.de/item/520101
Regards
Old 12-18-2014, 12:19 PM
  #164
proteus_X3
My Feedback: (16)
Regards
Interesting Characteristics on data sheet:,my question is how does it bond to other materials and how easily will form around compound curves and bends .Rich
Cross-linked rigid expanded PVC foam
Decay resistingGood thermal insulation
Self-extinguishing, good behaviour in fire
Low resin absorption
Good compatibility with styrene
Applications:
Ship and boat building: Decks, bulkhead walls, superstructures, interiors, hull parts
Rail and road vehicles: Supporting structures, interior parts, floors, dividing walls, etc.
Industrial components: Construction of wind driven turbines, containers, covers, sports aircraft and glider construction
Approval permits/tests: Germanischer Lloyd, fire testing in accordance with DIN 5510 (rail vehicles).
This material can be easily post-cured up to 65 °C without deforming. Ther****rming can be done at temperatures > 115 °C.
Tolerances: thickness ± 0.5 mm (T = 1.2 mm: +/- 0,2 mm), length and width ± 50 mm, density 72-92 kg/m³
Nominal density: 80 kg/m³
Due to the production method it comes to a different distribution of density at the ingot, from which the sheets are manufactured. Border areas exhibit a higher density compared to the core. With increasing density the porosity of the material will decrease at the same time, which could result in a lower resin uptake (depending on the process used).
Important information about foam boards
Smaller transport damage to the edges can not usually be avoided despite elaborate packaging.
close
Old 12-18-2014, 12:26 PM
  #165
fokke
fokke's Avatar
havve a very good bond , it is made spetialy for composite sandwiche as Herex and Nomex
Old 12-18-2014, 12:28 PM
  #166
fokke
fokke's Avatar
Have a very good bond , it is made spetialy for composite sandwiche as Herex and Nomex
Old 12-19-2014, 08:34 AM
  #167
invertmast
My Feedback: (23)
invertmast's Avatar
Airex is what the majority of European model manufacturers use in their composite models.
Old 12-19-2014, 08:38 AM
  #168
vertical grimmace
This looks like it is shaping to be a great model. Any idea on when they may become available as kits?
Old 12-19-2014, 09:09 AM
  #169
fokke
fokke's Avatar
Еxactly, Thomas is right, this material is used in many builders of models
Vertical ( I don't know your name ) in this topic I make two models, the first is a composite of D version, the second is wooden kit A8 version in 1/4 and 1/5 scale , of which model you're talking ?
Regards
Rumen
Old 12-19-2014, 09:13 AM
  #170
proteus_X3
My Feedback: (16)
Rumen,
Thanks you for the updates,looking forward too the 1/5 scale Dora kit when completed ,Merry Christmas. Cheers: Rich
Old 12-19-2014, 10:33 AM
  #171
vertical grimmace
Regards
Rumen
Rumen, I am Rich Perry. You are a friend of mine on FB as well. I would be interested in the D9. 1/5th scale
Old 12-19-2014, 11:54 AM
  #172
fokke
fokke's Avatar
Oh yes Rich, off course we are friends in FB . I think I"ll need 3-4 months for all because I have to build all plugs , then all molds and wood construction. I will use some fragments form A8 wood construction for the composite fuselage and wings That's why I made A8 wings and main fuselage before the Doras
Merry Christmas Rich-proteus and all you guys !
Rumen
Old 12-23-2014, 01:13 PM
  #173
fokke
fokke's Avatar
Hi guys, today I made wood cowl for A8 )) Yes wood cowl , not composite, I want to try how will be if the cowl is from wood , what weight will be and other questions which I have in my mind )
Ok this is the project
Old 12-24-2014, 12:37 AM
  #174
vik
vik's Avatar
Rumen I have to admire your Corel skils to make all designs in 2D
One question - would you consider to make the Dora wood fuse option? When you have the Anton basically done.
Viktor
Old 12-24-2014, 12:47 AM
  #175
fokke
fokke's Avatar
Thanks Vik
I don't know yet , I want to come back on my work of composite plug firstly, this will happen when I finish with all stuf with Anton version. I consider to make the all canopy section for Anton to be copmposite . To make this section from Dora mold
Rumen
