Reload this Page >
Hellcat Brotherhood
Hellcat Brotherhood
Old 10-05-2014, 12:08 PM
  #326
mirce
DA 85 will be great...
I fly my first Hellcat, which was very heavy (many details - 22 kg) with Evolution 80 GX.
Model fly very nice, need little more for take off, but in the air no different between that and my second F6F.
Second Hellcat (with yellow color scheme) was 19,5 kg with Zenoah GT80...
First flight: https://www.youtube.com/watch?v=tvzU...layer_embedded
You will enjoy with your model...
Regards from Serbia
Mirce
Old 10-12-2014, 08:24 PM
  #327
heggen
Sign me up.
My Byron Hellcat came to me through an unfortunate event for its previous owner. Flying low and too far off the runway and over the edge of a soybean field, the Hellcat flew into a small rise. The two foot tall soybeans brought it to an immediate stop from wide open. Damage was limited to the wing joiners/spars being stressed and broken and the cowl was stressed and full of soybean stalks and leaves. The Robart gear were in the retract position but the frames were slightly stressed by the wing movement.
The owner was not going to fix it and was willing to sell the whole airplane as is less the receiver so I took on the project. I believe a wrecked airplane is a terrible thing to waste.
Attached are two pics of the planes current status. The G62 that was installed was full of dirt so it was disassembled and the grit was removed and then oiled and reassembled. The previous green "Supercat" paint job has been stripped down to the fiberglass on the fuse and the previous paint on the wings and tail. The wing attachment and the spars have been repaired. A few items were considered by me to be in need of upgrading. The nyrods to the elevator were removed and replaced with solid 4-40 pushrods through nylon guide tubes. The analog elevator servo was replaced with a digital servo. The stabilizer/fuselage junction was flexible so inner bracing stiffened that up. Flap hinges had broken loose so new hinge slots were made to better secure the flaps. A separate servo for each outer flap will be installed. The skins on the wing stubs off the fuselage were very flimsy so some sub ribs were installed to firm things up. The stripper has slightly damaged some of the fiberglass on the surface but a little spot putty and primer will make it like new.
I'm sure other little things will surface that will need upgrading or repair, but I believe I will have a very flyable, good looking Hellcat when all is done.
Question: I am doing the cat-mouth paint scheme. Can someone advise me as to what the correct colors should be for the fuse and wings?
ID:	2039607   Click image for larger version
Old 10-13-2014, 04:11 AM
  #328
OldScaleGuy
OldScaleGuy's Avatar
Welcome to the Brotherhood heggen. The Byron Hellcat is a great flyer and it looks like you are well on your way to having yours repaired.
1. OldScaleGuy – Seymour, IN
2. Chad Veich – Litchfield Park, AZ
3. Rbean – Easton, PA
4. Aghost – Amarillo, TX
5. GallopingGhostler – Clovis, NM
6. Redskyhawk – La Crosse, WI
7. wingspar – Redmond, WA
8. tailskid – Tolleson, AZ
9. flyweed – Conroe, TX
10. gesmale – Boerne, TX
11. dgdayton – Fletcher, NC
12. trkpony – Kingsport, TN
13. SRQflyer – Sarasota, FL
14. Ram-bro – Bennington, NE
15. Todd Jackson – West Monroe, LA
16. TXAG96 – Augusta, MI
17. doolittles – Naples, ME
18. Red_Jeepster – Shinglehouse, PA
19. RCHS1 – Stafford, TX
20. top gun reed – Lilbourn, MO
21. Bob Paris – Maui, HI
22. Capt. Dan – Crown Point, IN
23. Sparky – Nashville, IN
24. mad web tv scientist – Salem, OR
25. lightning 759 – Doncaster, UK
26. karl hibbs – Spanaway, WA
27. MAGICBOB – Lynchburg, VA
28. VF84sluggo – Gulf Breeze, FL
29. rcmichael – Greely, CO
30. Owl – Plymouth, NC
31. 2001az – Orlando, FL
32. flatsguide – Marathon, FL
33. mikmarsh – Los Angeles, CA
34. Mooten – Rossville, GA
35. roydefiant – Eden Prairie, MN
36. eiutian – California
37. Mirce – Novi Sad, Serbia
38. Prekin –Olomouc, Czech Republic
39. mike 71 – Norwalk, OH
40. Reini450 – Hennef, Germany
41. C.O. – E. Peoria, IL
42. Check6 – N. Scituate, RI
43. Falkwulf – Fort Smith, AR
44. Hinkley Bill – Hinkley, IL
45. warhwk – Auburn, WA
45. RCPROPSNAPPER – Leicester, MA
46. Oakey – Adelaide, Australia
47. Yoyocafe – Frecericksburg, VA
48. warks62 – Fresno, CA
49. hairy46 – Sinclair, WY
50. gallen – West Chester, PA
51. 760aaron62 – Wrightwood, CA
52. heggen – Wyoming, MN
Old 10-18-2014, 10:47 AM
  #329
OldScaleGuy
Finally the flaps are framed up.
Old 10-19-2014, 01:10 AM
  #330
midastouch_73
My Feedback: (27)
midastouch_73's Avatar
I stumbled upon this Ziroli Hellcat barn find over a year ago. The previous owner had passed away and the plan was sold to me during the estate sale. It was almost to good to be true...Unfortunately I've been caught up with other projects in the hanger and the Hellcat found its way to the back-burner. I came across a Byrons At-6 and a Bud Nosen clipped wing p-51 after finding this Hellcat find which Have kept me busy. After I sent both the Texan And mustang out for paint I started to get bored waiting on them to return from the painter ( which was taking longer than expected). I pulled the Hellcat out of storage and started to disassemble it and assess the project...... I've been at it about a month now... Originally she was in pretty bad shape with the eyesore paint job. As you can see from the pic I was all smiles as i'm holding this thing. I count even handle the price he gave me. I forked over the cash and tossed it in the back of my truck before he changed his mind....
ID:	2041005   Click image for larger version
ID:	2041006   Click image for larger version
ID:	2041009   Click image for larger version
Old 10-19-2014, 01:20 AM
  #331
midastouch_73
My Feedback: (27)
Default Ziroli Hellcat Rebirth
Here are some pics of the process. I'm going to go with a DLE12O twin for power.
ID:	2041025   Click image for larger version
ID:	2041026   Click image for larger version
ID:	2041030   Click image for larger version
ID:	2041033   Click image for larger version
Old 10-19-2014, 01:51 AM
  #332
OldScaleGuy
midsatouch_73, that is an interesting story.
Once in a great while a good deal comes along. Looks like you will have a winner in no time.
Can we sign you up to the Brotherhood?
Small world too by the way. I lived in Corona in the mid 80's while working on the B-2 program in Pico.
If my memory serves correctly, your truck is parked just outside of a restaurant.
Old 10-19-2014, 08:47 AM
  #333
midastouch_73
My Feedback: (27)
That pic is actually from Oceanside Ca where I picked the plane up from. Corona has come a long way. More people and less cows... lol You can sign me up for the Brotherhood.... The plane is coming along. I'm Working on the Mirce finishing kit now. It's a bit time consuming but looks awesome....
ID:	2041151   Click image for larger version
ID:	2041152   Click image for larger version
ID:	2041153   Click image for larger version
ID:	2041154   Click image for larger version
ID:	2041155   Click image for larger version
ID:	2041156   Click image for larger version
ID:	2041157   Click image for larger version
ID:	2041159   Click image for larger version
Old 10-21-2014, 04:30 AM
  #334
OldScaleGuy
You are making good progress. I sure miss that Corona weather! Welcome to the Brotherhood.
53. midastouch_73 – Corona, CA
Old 10-21-2014, 11:01 AM
  #335
raptureboy
raptureboy's Avatar
Try here for scale hinging ideas. http://www.rcuniverse.com/forum/rc-w...ellcat-21.html
Old 10-21-2014, 11:44 AM
  #336
OldScaleGuy
Originally Posted by raptureboy
Very interesting. Thank you!
Old 10-28-2014, 12:05 PM
  #337
OldScaleGuy
Sheeting continues on the Hellcat. I did get ahead of myself once again. The leading edge sheeting is in place so i will have to remove some for adding a landing light and machine gun supports.
I would like to add a joint hider where the wing outer panels meet the center panel. Been kicking around some different ideas for material but would like your opinion. What i have thought of using is .010 aluminum, the problem with this is i have only found it is 10" long K&S sheets so that will leave a joint fore and aft, .010 carbon fiber strip, my only concern with that is the compatibility with paint or 1/64th plywood, flexibility may be an issue to avoid another joint, running the material with the grain or against the grain.
ID:	2042805   Click image for larger version
Old 10-30-2014, 05:55 AM
  #338
OldScaleGuy
Hellcat on all its wheels for the first time....
Old 10-31-2014, 12:16 AM
  #339
midastouch_73
My Feedback: (27)
Thanks OldScaleGuy... She looks like she's coming along nicely. It's hard to stop when you see the progress.... I'm making progress myself. Should be ready for paint soon. Pretty much completed the Mirce finishing kit. Waiting on my dummy radial from Ziroli to show up so I can center the engine and modify my cowl. I'm gonna have to blister the cowl for the plug caps of the DLE 120. I started working on the cowl flaps meanwhile. Hopefully I can start putting some paint on her in the next week, I'v also gotta install a hatch somewhere for my switches and fuel....
ID:	2043591   Click image for larger version
ID:	2043592   Click image for larger version
ID:	2043593   Click image for larger version
ID:	2043596   Click image for larger version
Old 10-31-2014, 03:43 AM
  #340
OldScaleGuy
Thanks. Yours is coming along well too. The DLE-120 will haul it with no problems at all. I have a 111 in a 33% Extra, it is a great engine.
Curious. Where will you take it to fly it? When i was there we flew at a small field close to a school. It is a bit vague these days (28 years later) but it wasn't far from where i lived on Border Avenue south of the main through street.
Old 10-31-2014, 07:55 AM
  #341
midastouch_73
My Feedback: (27)
We fly at Prado airfield near the women's prison in Chino. It's about 10 minutes away.... I can't wait to see how the engine performes.. I have a Dle 111 in my ESM 85 corsair and its a gear flying plane with that combo... I'm known for over peering my warbirds but they look so impressive egg they fly... Here's a look at my corsair flying at our field.. iIt says maiden flight but it's the first two flights combined in the video...
http://youtu.be/73dhdIW1JXA
Old 10-31-2014, 10:01 AM
  #342
OldScaleGuy
Your Corsair looks great and looks like a good flyer too.
Very nice flying site, the club has come a long ways since the days of old...
Old 10-31-2014, 10:03 AM
  #343
RCHS1
RCHS1's Avatar
Here is video of a short take off 53 pound hellcat for some reason i went down wind (5mph) as well- DA100 26x10 RIPS - flys awesome
Formation flight with my Hellcat and my buddy flying my Ziroli Dauntless trying to get in some low passes between traffic
http://www.youtube.com/watch?v=zA8OR..._XTc-zvUg-THEw
Old 10-31-2014, 11:29 AM
  #344
OldScaleGuy
Nice video Bucky! Thanks for sharing.
Old 10-31-2014, 11:48 AM
  #345
midastouch_73
My Feedback: (27)
Great video... Two awesome looking planes.
Old 11-15-2014, 03:42 PM
  #346
Bob Paris
My Feedback: (13)
Aloha,
I flew my ESM F6F today at our Pu'unana flying field. She flew as expected...great, but I had a bit of engine trouble.
My engine was kind of going Brrr...Brrr...Brrr...and then when I landed, it quit. It seemed to cycle hi-low-hi-low and other then at idle, never really had solid power. My fuel is clean and new, with no alcohol 92 octane and a 30/1 mix of Royal Purple two cycle mix. This is the first time this has happened to me. I pulled the cowl and it did the same thing, and I witnessed no bubbles in the fuel line. The model sat for eight months with out being flown, but now giving me real running issues. The engine ran great before, but not now. Ive a PTE 36cc gas engine in this model. Any ideas guys....?
It was a strikingly beautiful day to fly. Cool with a 10 kt. Kona wind and lots of rainbows.
Soft Landings Always,
Bobby of Maui
Name:	F6F Rainbow 11-15-14 001.JPG
ID:	2047619   Click image for larger version
Name:	F6F Rainbow 11-15-14 003.JPG
ID:	2047620   Click image for larger version
Name:	F6F Rainbow 11-15-14 004.JPG
ID:	2047621   Click image for larger version
Name:	F6F Rainbow 11-15-14 005.JPG
ID:	2047622   Click image for larger version
Name:	F6F Rainbow 11-15-14 006.JPG
ID:	2047623   Click image for larger version
Name:	F6F Rainbow 11-15-14 014.JPG
Old 11-15-2014, 04:17 PM
  #347
midastouch_73
My Feedback: (27)
You might has air getting into the system somehow how or a clog in the line or carb... if there are bubbles either the carb trying to pull fuel and isn't getting it or the carb diaphragm could be faulty that high low thing is a sign of a fuel problems usually... just a few suggestions...
Old 11-15-2014, 04:20 PM
  #348
midastouch_73
My Feedback: (27)
That high low trying is usually a fuel problem...
Old 11-15-2014, 04:23 PM
  #349
midastouch_73
My Feedback: (27)
Also make sure your choke is opening completely
Old 11-16-2014, 03:18 AM
  #350
OldScaleGuy
You might also check the screen in the carb.
