Zero engine
Can any one suggest a radial engine to suit a CM Pro/Hobbyking A6M Zero. It is suggested for a 40-50- CC Gas engine. The model is 2100 w.s., wt.is 6.5 Kg approx. I have had a look at the Saito FA-325R5D (53cc) glow 5 cylinder radial but it would be pretty tight in the cowl, which is 220 inside diameter and the Saito engine is 205 diameter, not including any onboard glow fittings or any other anclliaries. Any suggestions as to what I could use would be greatly appreciated. I would preder to use a radial if one the right size is available, or otherwise a twin cylinder
Hi Greg. Sorry for the difficulty with dimensions. Australia changed to the metric system in the mid 60's, so I tend to use them most of the time, although I prefer imperial dimensions as that is what I grew up with. See changes below, imperial dimensions in brackets.
Can any one suggest a radial engine to suit a CM Pro/Hobbyking A6M Zero. It is suggested for a 40-50- CC(3.25c.i.) Gas engine. The model is 2100 w.s.(83 inch), wt.is 6.5 Kg (14.33 pounds) approx. I have had a look at the Saito 53cc (3,25 c.i.) glow 5 cylinder radial but it would be pretty tight in the cowl, which is 230 inside diameter and the Saito engine is 225 diameter, not including any onboard glow fittings or any other anclliaries. Any suggestions as to what I could use would be greatly appreciated.
Thanks, Ian
Thanks, Ian
My Feedback: (101)
try the ASP 400 radial. There is a thread dedicated to this motor . There is a guy flying one in a tFGS P47. They have their quality issues on some of the older models but they have a loyal following , the cost is low and tey appear to be easy to work and learn on. Check it out
