Top Flite Giant Zero 86" Span.
#406
My Feedback: (25)
Where are all the Zero fliers!?
Finally have several flights on mine, I do notice a tendency to ground loop if you don't 3 point the landing. Anyone have any advice about this tendency with this plane?
Bad day for video, but it's the day the camera and a person that could handle it showed up.
https://www.youtube.com/watch?v=ROLbQazr91I
#408
I thought you did a good job with your video! Ground loops are a risk with all taildraggers, but in my experience, a little toe-in helps with the issue. Some will argue to the contrary, of course. I always go for 2-point landings as the higher airspeed over the vertical stabilizer is strongest that way.
Good job on your model in any case.
#410
[QUOTE=dionysusbacchus;12275681]Where are all the Zero fliers!?
Thanks for the video, I enjoyed it. Your Zero looks great. Where are all the Zero fliers? Well, this one is saving up for a replacement.
You'll probably see less and less posts on this forum in the future. My local stockist (who I hope to buy my replacement from) has recently communicated with Hobbico and they have sais they are not going to be producing the Giant Zero, P-47 and whatever else anymore.
Such a shame, I don't know the reasons, I can only surmise that there isn't enough profit in making reasonable quality large scale warbirds. Hard to believe!!
#412
Make of it as you will. The dealer I communicated with is a stockist of Topflite models, the only one I know of in this country. I have no reason to doubt his word, he is in direct contact with Hobbico. Maybe someone in the U.S can refute this?
It would be great if the information was false.
#418
SO TRUE !!!
I have three kits (and/or engines) of things that are great. Especially some of my older Control Line and F3A stuff from the 80's.
Anyway my ZERO is finally finished (except for some decals and weathering, which is still work in progress).
Here are the details:
Saito FG-60R3 (standard - no modifications, just some extra precautions with my 40+ years of RC experience)
Fiala 21x10 three-blade prop
JETI DC-24
Duralite Gemini (original)
PowerBox Spark 7.4V
Standard Robart Retracts (pneumatic)
1/5th Scale Japanese Pilot from Warbird Pilots (had to cut off his parachute seat pack)
Total Weight 27 lbs (no additional weight at all)
CG is 175mm (and elevator is neutral, inverted requires little down elevator input, landing are so sweet and nicely balanced)
JETI DC-24
PowerBox Spark 7.4V
#419
My Feedback: (46)
SO TRUE !!!
JETI DC-24
PowerBox Spark 7.4V
JETI DC-24
PowerBox Spark 7.4V
#420
Thanks George, plus kit manufactures tend to suggest CG on the forward limits (for obvious reasons), but this never suits my flying style and setup.
Here is a link to one of my Zero flights, video is not great but the sound is excellent.
https://www.youtube.com/watch?v=jrn2mxVqQWM
Enjoy, Darryl Tarr
(BVM Field Rep)
Enjoy, Darryl Tarr
(BVM Field Rep)
#422
(Lifer), I still fly Control Line so if you want a buyer for the Ringmaster Kit, then please let me know.
Here are some additional photos of my ZERO (baffling, and stock exhaust stacks).
