Reload this Page >
New Hangar 9 30cc Spitfire! Build Thread, i got mine!
Old 06-30-2014, 07:29 PM
  #126
frisco2022
My Feedback: (16)
Hi guys, I have safety wired bolts before but these bolts are sunk in the muffler unfortunately.
Old 07-01-2014, 08:14 AM
  #127
CRG
Wedgelock (also called Nordlock) washers will take care of the muffler-loosening issue. Available from McMaster.
Old 07-01-2014, 10:40 PM
  #128
Scott Douglas
Scott Douglas's Avatar
Location: Hamilton, Scotland & La Roche Bernard, France
I finally had some time to start on mine, fitted the servos, hooked up ailerons/flaps etc and left to dry. Tailplane's also fitted so then I decided to have a look at what's going to be involved in the cockpit. Once I'd removed the balsa floor I found..... much more space than I thought I'd have!. The pilot's probably going to obscure most of it and it won't be quite full depth but it'll be hard to see!
I did something similar to my P51 using the dBalsa kit, if it turns out like this I'll be happy.....
ID:	2010525   Click image for larger version
ID:	2010526   Click image for larger version
ID:	2010527   Click image for larger version
ID:	2010528   Click image for larger version
ID:	2010529   Click image for larger version
Old 07-01-2014, 11:30 PM
  #129
v_suvorkov
Originally Posted by v_suvorkov
Can anybody help me? Please tell me e-flite retract dimensions.
I think Spit retract dimensions - the greatest secret. e-Flite sent me to Hangar9. Hangar9 said sorry, we do not have information.
Please measure it. I'm looking for electric retracts for my Brian Taylor Spitfire. I will keep secret and will not tell anyone.
Old 07-02-2014, 12:06 AM
  #130
Scott Douglas
I can't understand why eFlite don't make these available, they might sell even more!
I measured mine there, from your attachment
1.. 88mm
2.. 25mm
3.. 33mm
4.. 56mm
5.. The mounting lugs (from centre to centre).. 37mm
Old 07-02-2014, 12:56 AM
  #131
v_suvorkov
Thank you.
Old 07-12-2014, 03:16 PM
  #132
grantmNZ
My Feedback: (14)
The measurements are great - but to what parts / distances are they referring to ?
its OK found it going back a page
Old 07-12-2014, 03:17 PM
  #133
grantmNZ
My Feedback: (14)
1.. 88mm
2.. 25mm
3.. 33mm
4.. 56mm
Old 07-12-2014, 03:19 PM
  #134
grantmNZ
My Feedback: (14)
to what parts do these measurements relate to please?
1.. 88mm
2.. 25mm
3.. 33mm
4.. 56mm
Old 07-13-2014, 12:31 PM
  #135
grantmNZ
My Feedback: (14)
can you give me the oleo dimensions please too ?
1.. 88mm
2.. 25mm
3.. 33mm
4.. 56mm
5.. The mounting lugs (from centre to centre).. 37mm[/QUOTE]
Old 07-14-2014, 11:10 AM
  #136
Duplicator41
Duplicator41's Avatar
Subscribed
Cheers,
Old 07-16-2014, 01:31 PM
  #137
Ark-x400
First photos of mine, along with the Inzpan cockpit kit, ordered the cockpit kit rather than the more complete version as I know I'll have to adapt it to fit!.....
First impressions...much better than the 150 Mustang, better build, covering and overall packaging. The eFlite retracts are quality items. More to follow soon!
Scott
How well does that cockpit kit fit. Apart from removing the balsa floor was there much else you needed to do to make it fit?
Old 07-16-2014, 09:31 PM
  #138
Scott Douglas
Yeah there's going to be tons of work to make it even close to looking right. I'd suggest this model is closer to 1/5.5 scale rather than 1/5th scale.
Old 07-16-2014, 09:32 PM
  #139
Scott Douglas
Grant, they are.... from the top of the oleo leg itself to the centre line of the axle.. 16.5cm
Old 07-17-2014, 04:26 AM
  #140
BarracudaHockey
BarracudaHockey's Avatar
The Mustang is really 1/5 scale and its 89", next to it the Spitfire looks tiny and is probably nearly 1/6 scale.
Old 07-17-2014, 12:14 PM
  #141
Ark-x400
Zcott
This Spit is 1/5.5 in scale. There has been alot of discussion about that very point over on the RC Groups thread. That is why I was asking about how the cockpit kit fits because it is listed as 1/5 scale. I had also posted a question asking if anyone had used the Tys Aircraft 1/5 cockpit kit made for the Esm model which is true 1/5. One of the guys who has both Spits posted a picture of both fuselages beside each other and the difference was obvious.
Old 07-17-2014, 01:36 PM
  #142
ForcesR
Here are 3 aircraft all, are claimed to be 1/5 scale by their manufacturer. There is only one true 1/5 scale among the 3, can you guess which one? The H9 30cc Spitfire, the ESM 50cc Spitfire, or the TF P-51D Mustang?
Roger
Name:	ESM & H9 Spitfires size difference 001.JPG
ID:	2015007   Click image for larger version
Name:	Compariing Size , ESM, TF, H9 001.JPG
Old 07-17-2014, 02:40 PM
  #143
Chad Veich
My Feedback: (60)
The ESM Spitfire would be the closest. If it is indeed 89" span as advertised then it is just a hair larger than 1/5 scale. (88.4 would be exact)
Old 07-17-2014, 04:37 PM
  #144
ForcesR
Chad, yes the ESM wing span is 89" exactly as advertised, and as you confirmed slightly larger than 1/5 scale.
Roger
Old 07-21-2014, 08:04 AM
  #145
irwina
Great pictures. Where can I get a pilot like that? Thanks Art. Just about to start building mine.
Old 07-21-2014, 10:41 AM
  #146
ForcesR
Art; I got the pilot at a LHS five years ago, the only one they had. I've been searching for the same pilot figure ever since, but no luck in finding another one.
Roger
Old 07-24-2014, 10:53 AM
  #147
Scott Douglas
The powerplant arrived today...
ID:	2017137   Click image for larger version
Old 07-24-2014, 02:45 PM
  #148
ForcesR
Scott Douglas; I don't recognize that brand of engine, what is the cc and who makes it? I have a Saito FG36 that needs a home so it will be fitted into the Spitfire. I will have to modify the hatch so the 6mm space will be hidden, this is due to the cowl not extending back far enough to hide the 6mm gap, not a big deal to accomplish.
Roger
Old 07-24-2014, 03:26 PM
  #149
BobH
That pilot looks to be a Blue Box RAF Pilot. They haven't made them for some time although they do make other RAF Pilots.
Sometimes you can find one on Ebay but they don't come cheap.
Old 07-24-2014, 10:10 PM
  #150
Scott Douglas
Roger
Hi Roger
That is a Laser 180 four stroke, made by Laser Engines in the UK, specs here.. http://www.laserengines.com/product/laser-180/
Regards
Scott
