New Hangar 9 30cc Spitfire! Build Thread, i got mine!
#301
+1 on the rearward C/G. mine is electric and upon landing just loved to go on its nose with the forward recommended C/G. i cant remember the exact C/G measurement for mine but it was at the rearward limits and the model is still well mannered in flight and keeps the tail down much better when landing.
#304
Roger
#305
Jeff, post a few photos of your FG40 installation, it would be interesting to see what you did. I have the FG36 installed in my H9 Spitfire and it's an awesome combination, it looks and sounds great, I changed the CG to 130mm and it flies much better at 130mm than the CG that is called for in the assembly manual.
Roger
Roger
Warbird AL (02-04-2021)
#307
Jeff, what material are you using to hide the gap between the cowl and the removable hatch? I'm wondering why you had to use so much dead weight to meet your CG when you have the FG40 installed using the stock Saito engine mount? I have the FG36 installed in my H9 Spitfire which is basically the same as the FG40 and I only required 382.7 grams (13.5oz) to meet a CG of 130mm?
#308
I also fixed Rx. and a Dualsky VR Pro (to feed 6V power to Rx and servos from my 2S Lipo) close to the rear side of wing, in the fuselage. In the past whenever the distance between Rx. and CDI was less than 40cm, I could experience some disturbing in the control. This happened for maybe 3-4 times to my Evo 10CC gassier. Probably I am too much concerned and I plan to shift Rx. and accessories to the place recommended by the manual, which might help me reduce the dead weight as well. I will also try to adjust the dead weight for CG about 130mm, while I tried 125mm before.
If your Rx is put under the hatch and CDI is mounted similarly, did you have any issues in remote control?
#309
Jeff, looks good!
I have the FG40 as well, but in a diferent model, a Hawker Typhoon. Are you able to start the engine by hand? I am UNABLE to and have checked timing and everything...this things just totally opposed to handstarting! Its a PITA, but once its started, its a great engine, plenty of guts and sounds so much better than a garden implement engine!
#310
Jeff, looks good!
#311
Jeff, my RX is located in the area under the hatch behind the fuel tank and the electronic ignition box is attached beneath the engine box. I have never had any flight control issues due to electronic signal interference. I have to use an electric starter when the engine is cold for the first start of the day. After that first start the FG36 will hand start very easily, usually on the 2nd or 3rd hand flip as long as the engine is still warm. If I allow the engine to get cold between flights then I have to use the electric starter again.
Roger
Roger
#312
Roger
Roger
#313
Hello friends of these. beautiful Spitfire. Does anyone have a copy of the flight review, published in July 2014 of the
Model Airplane News magazine?
thanks in advance and stay healthy
Andy
Andy
#314
My Feedback: (10)
Hi, I was given a crashed H9 30cc Spitfire that I've starting rebuilding, the front end is smashed so I need a bit of info.
How long is the engine box that protrudes past the last fuselage former - please see photo
Does anyone have the engine mounting template that you can scan and post it here.
What are the dimensions of the firewall, height and width?
Thank- you, ken kalynuk, Winnipeg, Canada
#315
Ken, I can give you the info you require tomorrow Tuesday 26- Jan. I don't have a scanner to scan the template but I can give you the measurements for the template including the vertical & horizontal cross hair measurements.
Roger
Roger
#317
Good day Ken, the info you requested. The length of the LH & RH crutches (Eng box sides) extend from frame/former # 1 are as follows:
Left side - 60mm
Right side - 55mm
Height of L & R crutch at # 1 frame/former - 105mm
Height of L & R crutch at front where engine is mounted is - 87mm
Total width of engine box is - 117mm
As seen in the attached photo, the bottom of the engine box is sloped upward. The L & R crutch extends at the bottom of the engine box to the 16mm mark, then the angle extends upward to the front of the engine mount face at the 87mm mark. The top and bottom panels of the engine box are all 2.5mm thickness.
The engine mount template: Height - 91mm
The engine mount template: Width - 117mm
Using your photo of the engine mount template, the vertical cross hair line is 52mm measured from the right side. If you measure from the left side while facing the template the vertical cross hair is at 65mm.
The horizontal cross hair line measured from the top of the template down is at 51mm. If you measure from the bottom of the template up the line is at 40mm.
What engine are you planning on using in the Spitfire?
If you require any further clarification of the measurements I provided just let me know.
Roger
Left side - 60mm
Right side - 55mm
Roger
#318
My Feedback: (10)
Hi Roger, thank-you for the quick work on the firewall measurements.
I have a used DLE35 that I plan to use in the H9 Spitfire.
The H9 was going into the bonfire after the crash so I rescued it.
I seem to be collecting Spitifres, I got my Brian Taylor Mk.IX flying in 2020, it has a DLE 55RA and my Yellow Aircraft Mk. XIV is going strong on year 10, it has a DLE 55 side exhaust, my old trsuty Dynaflite Spit with a DLE 30 is on year 12.
So the Hangar 9 Spitfire will be a good everyday flyer once I complete the rebuild.
#320
Roger
