Reload this Page >
New Hangar 9 P-51 60cc
Old 06-01-2015, 04:48 PM
  #901
Acs_guitars
Acs_guitars's Avatar
Originally Posted by speedbrake
sjhanc
The H-9 spinner is 5 1/2 inches
I show the same.
Old 06-01-2015, 05:50 PM
  #902
sjhanc
sjhanc's Avatar
speedbrake, Acs_guitars,
Thanks for taking the trouble to measure it. I can make a decision on the brand I buy now.
Old 06-01-2015, 06:04 PM
  #903
Shaun Evans
Shaun Evans's Avatar
Hi,
If you're lucky enough to find any, the Airtronics 94820 mini digital is a PERFECT servo for the elevators for this bird. Perfect fit and 90 ounces at 6v. Moot for most since they're so hard to find now, but their holding power and precision is better than ANY JR/Spek product of its size I've messed with. I just found 6 on RCU and have installed two of them in this Mustang I'm finishing to sell.
Old 06-02-2015, 05:41 AM
  #904
BarracudaHockey
BarracudaHockey's Avatar
Moderator
Looks great. Like the drop tanks. I'm adding those too, and lights. Still waiting for the 5060 servos. grrrrrr
I wanted to head up that direction for the warbird fly-in at Hodges but Im going up to Champaign the following weekend and thats just too much driving
Old 06-02-2015, 12:18 PM
  #905
Shaun Evans
Hi,
For you guys still working on this bird, watch out for the rudder 'hinges'. One of them was loose and just pulled out without any effort at all.
Old 06-02-2015, 12:45 PM
  #906
marksp
My Feedback: (9)
marksp's Avatar
Yikes!
Old 06-03-2015, 05:41 PM
  #907
Shaun Evans
Hi,
Yeah, and I just noticed a pretty significant warp in the rudder. When the bottom is in the neutral position, the top has a quarter-inch of deflection at the top. I've seen this happen when the 'builder' is pressing on something too hard when covering. I wish I'd noticed before adding the control horns, because I'd have just recovered it. Pretty lousy covering on it anyway.... :/
Old 06-03-2015, 05:59 PM
  #908
Len Todd
Usually a little strategic application of heat takes warps right out of rudders.
Old 06-07-2015, 06:39 AM
  #909
nsyracuse
Thought I'd share a few pics from our local warbird event. Mine is Glamorous Glen III and my friend's is Gentlemen Jim. We put on a pretty good formation show. Still waiting on pics of them in the air together.
Nick
ID:	2101056   Click image for larger version
ID:	2101057   Click image for larger version
ID:	2101058   Click image for larger version
ID:	2101059   Click image for larger version
ID:	2101060   Click image for larger version
ID:	2101061   Click image for larger version
Old 06-07-2015, 07:36 AM
  #910
marksp
My Feedback: (9)
marksp's Avatar
Great pics!
what engine?
Cheers
Old 06-07-2015, 07:38 AM
  #911
nsyracuse
Mine is an EME-60. The gentleman Jim that I fly with is a DA-60. Power is about identical.
Old 06-07-2015, 07:41 AM
  #912
CRJDriver
My Feedback: (57)
CRJDriver's Avatar
I am a big fan of the EME line! Great value. I have a 55 in my 1/5 scale Spit - it runs like a Swiss watch!
Old 06-07-2015, 07:44 AM
  #913
Lifer
Lifer's Avatar
CRJ driver,
What prop are you using on your EME 55? I have one that will go into a Corsair this winter.
Old 06-07-2015, 07:47 AM
  #914
CRJDriver
My Feedback: (57)
CRJDriver's Avatar
Originally Posted by Lifer
CRJ driver,
I am using a Xoar 22x10. Static RPM at full throttle is about 6700 rpm. A Zinger 20x8-14 is another option for greater speed.
Old 06-07-2015, 08:08 AM
  #915
Lifer
Lifer's Avatar
Thank you!
Old 06-07-2015, 08:39 AM
  #916
marksp
My Feedback: (9)
marksp's Avatar
Looks like it fits completely under the cowl - well done!
Do you have the starter fitted as well?
Cheers
Old 06-07-2015, 09:02 AM
  #917
ForcesR
Cheers
Marksp; I don't mean to be picky, if you look more closely you can see the side mount muffler mount bolt showing where the checker board ends and below the letters GL in Glamorous Glen IIl.
Roger
Old 06-07-2015, 09:15 AM
  #918
nsyracuse
I I do not have the starter fitted, although it doesn't need it. Easiest starting engine I've ever owned. A few flips to pop, a few more to run.
Correct, it is "almost" completely enclosed in the cowl. I had to cut a little area around the front muffler bolt. I didn't realize when i ordered the mmuffler that jtec makes one specifically for this bird that most likely requires no cutting.
I did have overheating issues after switching to the in cowl muffler. The only solution for me is to run Sunoco leaded race fuel. The leaded and higher octane burns cooler. I did not have any issues with the stock muffler hanging out in the breeze. My friend's does not overheat, but a lot of muffler side area is sticking out in the breeze. He also mentioned that he talke to h9 rep at joe nall and they implied that they had the same issue with a da-60, so I'm probably not the only one.
Roger
Old 06-07-2015, 09:17 AM
  #919
nsyracuse
It took me about 10-12 flights to diagnose the overheat issue. It would just die at about 2:30 into each flight. Luckily I learned very quickly how to nail a dead stick landing with this bird.
Old 06-07-2015, 11:47 AM
  #920
185skywagon
Can you show us a pic of cowl area / under cowl ? Do you have a baffle installed ?
Quite interested in this overheating issue and peoples solutions if there are any others
Old 06-07-2015, 01:29 PM
  #921
Len Todd
I put telemetry in all my gas planes. My first plane (existing and later put in telemetry) was running over 300 degrees F and I was able to get that down to 230 with baffles and more air outlets. Most of mine run about 225 - 250 give or take ambient air temps. Also, I use the telemetry RPM readings in the air to figure the best prop that gets the engine in the power band. There is quite a bit of difference between running on the ground and in the air. RPMs also help tune for that slightly rich sweet spot. But you can get a hand tach too for that.
Old 06-07-2015, 03:32 PM
  #922
nsyracuse
I posted pics of the muffler install awhile back. I'll try to find them again.
I too have telemetry installed (Rpm, temp, Gps). I do it on all my scale gas birds.
Yes, the baffle is installed, made 0° change when installing. Here is a rundown of what happened.
1. Airplane maidened with stock muffler and leaded racing fuel - 0 issues
2. Installed in-cowl muffler around flight #6 still with leaded racing fuel - 0 issues
3. Switched fuel to Rec-90 ethanol free gas as they finally restocked- trouble begins
deadstick 2-3 minutes into every single flight. Temps in flight were 265°-270°. I thought it was a tuning issue at first, but finally decided to fly it with the cowl off. I was able to fly an entire flight. Temps were in the 170°-175° range.
4. I ran home, installed the baffle in the cowl and headed back to the field. Same thing. Temps in the same exact range and dead stick after 2:30.
5. As I was running back through my head trying to figure out what I had changed, it finally clicked with me that I had switched fuel right before I started having trouble.
6. Ran to the nearest Sunoco, mixed up a fresh batch of their leaded race fuel, headed back to the field for another shot. Perfect flight x 3 more flights with zero overheating issues. Temps are now in the 225°-245° range.
At first, I thought it was an EME engine quirk, maybe it runs hotter than others...but h9 confirmed it unofficially that there DA overheats as well, so it must be an airframe, cowling-design issue. I think it would be a non-issue on regular gas with the muffler hanging out, but with it in, all that heat builds up and can't get out. It runs great on the higher octane-leaded fuel, so that's what I run. I may switch to avgas, as it's a little cheaper.
Old 06-08-2015, 04:36 AM
  #923
aehaas
I wonder if fuel With Ethanol runs cooler or hotter. Can one of you telemetry guys test this???
aehaas
Old 06-08-2015, 01:31 PM
  #924
fhollahan
I have the same issue with the DA-60 with the Jtec muffler completely inside the cowl. Over heats and shuts down. I have the baffle on it. Opened the cowl up more and turned the high end needle for more fuel mix. I will try the Sunoco leaded race fuel. Thanks.
Old 06-08-2015, 02:27 PM
  #925
old p47
If you go back in this thread a Horizon pilot pointed out you need to put a spoiler in front of you air exit hole to create a low pressure area to draw out the hot air. I fly in phx and have 9 flights so far. I followed his example and have no heating issues at all and we are in the hot part of the country.
