Reload this Page >
New Hangar 9 P-51 60cc
Old 01-26-2016, 08:43 AM
  #1176
Len Todd
Originally Posted by BarracudaHockey
Nope, it's been discussed on the FG thread.
Care to share the link to the FG thread?
Old 01-26-2016, 09:50 AM
  #1177
BarracudaHockey
BarracudaHockey's Avatar
The landing gear discussion is towards the bottom of this page
http://www.flyinggiants.com/forums/s...t=89977&page=3
Old 01-26-2016, 11:28 AM
  #1178
rslstft
My Feedback: (10)
rslstft's Avatar
On the inner door issue of them staying open after you power on the receiver - just toggle the retract switch quickly for gear up then right back to gear down and the doors will close without the gear cycling. I do this after I start the engine and it looks like a full size with the hydraulic pressure building!
Old 01-26-2016, 01:27 PM
  #1179
CaptRKO
CaptRKO's Avatar
I'll give that a try....and THAT would be scale!
Old 01-27-2016, 07:24 AM
  #1180
Zman39
Zman39's Avatar
Anyone with a DLE 55 know if bolt patters match up or modification needed?
Old 01-27-2016, 09:15 AM
  #1181
CaptRKO
CaptRKO's Avatar
I was told the DA50 and DLE 55 are the same pattern.....I will be checking soon as I am almost to the engine install.
Old 01-27-2016, 09:17 AM
  #1182
CaptRKO
CaptRKO's Avatar
RE STABS:
Anyone just epoxy glue one half of the stab tube into one side of either stab? Seems like they over thought this one through .....I am thinking one half gets a glued stab tube and the other half gets the bolt through the tube. (still want it removable to access the servos)
Thoughts?
Old 01-27-2016, 04:21 PM
  #1183
CaptRKO
CaptRKO's Avatar
Anyone have pics of a DLE-55RA install?
I know someone had pics but I searched this thread and can't find it again.....somebody keep pipping in how it will fit no problem ....but he keeps showing a Top Flite ARF kit and not the H9....two different birds!
It looks like I will have to remove some of the firewall to get the muffler to fit...so I need pics!
Also the Bolt pattern does not match up with a DA-50 which I thought it did.....so I need to make my own bolt patter holes on the firewall.
So any pointers from the DLE-55RA crowd? OR should I trade it in on a Evolution 62?
Also anyone know the kit tank size? I am going to replace it with something else....its essentially worthless anyway.
Old 01-27-2016, 08:23 PM
  #1184
ForcesR
Capt RKO; see link below post # 246 DLE 55ra with Jtec muffler and post # 250 with stock DLE muffler.
~http://www.rcgroups.com/forums/showt...138992&page=17
Old 01-27-2016, 08:33 PM
  #1185
gibb
My Feedback: (7)
I used the stock muffler. I had t grind some of the firewall and then glassed it for strength. The engine standoffs were shortened but I don't remember how much. Maybe 3/8". MV
Old 01-27-2016, 08:34 PM
  #1186
gibb
My Feedback: (7)
Old 01-27-2016, 09:32 PM
  #1187
CaptRKO
CaptRKO's Avatar
ForcesR and Gibb....THANK YOU! I am ordering the Jtech exhaust as we speak......saved me from a lot of sanding!
Old 01-27-2016, 10:02 PM
  #1188
quist
My Feedback: (198)
quist's Avatar
The 55RA runs very good in the H9 Mustang. It wasn't that hard to modify the firewall.
Old 01-27-2016, 11:45 PM
  #1189
marksp
My Feedback: (9)
marksp's Avatar
JTec fits without firewall grinding, but takes a good long while to get. I think they are made to order, FYI.
Old 01-28-2016, 06:32 AM
  #1190
CaptRKO
CaptRKO's Avatar
Great.....
and it said it would be here by Wednesday. :{
Old 01-28-2016, 06:42 AM
  #1191
ForcesR
Great.....
Mine arrived within 7 days after the order was placed. Capt RKO, I believe you will receive yours by Wednesday as was stated
Roger
Old 01-28-2016, 06:58 AM
  #1192
CaptRKO
CaptRKO's Avatar
Roger
I jut checked with Jtech (awesome folks by the way) and it will be about 2 weeks so I cancelled the order for now)
Old 01-28-2016, 11:37 AM
  #1193
CaptRKO
CaptRKO's Avatar
I gave up on the DLE-55RA....I refuse to cut and glass the firewall for a damn muffler!
I have a NIB Evolution 62GX from the LHS that took the DLE-55RA in trade....plus a little $$. I guess I have used everything called out in the manual for the plane (100% stock) so we will see if it flies well.
Lets see some 62GX install pics????
Old 01-28-2016, 12:48 PM
  #1194
Len Todd
I put in a DA 60 and the JTech Muffler. There is about 1/4" clearance from the firewall. The muffler's can is above the firewall. The DA 60 has side exhaust.
My question is: How close to the wood can the muffler be? How close is too close?
Old 01-28-2016, 01:27 PM
  #1195
marksp
My Feedback: (9)
marksp's Avatar
I gave up on the DLE-55RA....I refuse to cut and glass the firewall for a damn muffler! I have a NIB Evolution 62GX from the LHS that took the DLE-55RA in trade.
Right on! I prolly would've done same if 62GX was available when I discovered I had to wait a month for the JTec and pull my hair out trying to source bloody stand-offs!
Cheers
Old 01-28-2016, 03:22 PM
  #1196
CaptRKO
CaptRKO's Avatar
Cheers
Just went through all the same frustrations.......oh and the Fuel tank in the kit is junk! At least the 60cc Corsair was pre plumbed....again not surprised at this since the whole kit is a D- minus at best. What is Horizon thinking?
Old 01-28-2016, 03:49 PM
  #1197
Len Todd
Don't want to bash hh too much. Otherwise they typically drop the model and next thing you know there are no parts available.
Old 01-28-2016, 03:51 PM
  #1198
alb1661
I just mounted my DA 50 with 2 1/2" standoffs that gave a 1/16" clearance on the spinner backplate. I am also using a J-tech muffler that will be enclosed without any holes in the bottom cowl.
I think this is the first time in the build that I did not have to make any mod's. It is a challenging ARF. Read the instructions a couple of times and dry fit everything.
Have fun
Steve
Old 01-28-2016, 05:39 PM
  #1199
CaptRKO
CaptRKO's Avatar
HH.....one thing you can say is they do have EXCELLENT CUSTOMER SERVICE. Sadly when compared to other ARF's in the line at HH....this one doesn't live up to the others...JMHO. I will still shop with Horizon Hobby (HH) ....but I can tell they must have switched vendors overseas, you can notice the hardware is very cheap and not like the Corsair.
I will be ordering a 2nd Corsair soon. Just wish this Mustang would have "fell together like the other kits" Still considering the 3.1m Sukhoi...already built the Beast 100cc, 60E, Extra 300 100cc, 60cc, Corsair 60cc, etc....
I did hear today about the P3 Biplane recall.....so I think some changes are underway.
Old 01-30-2016, 08:27 PM
  #1200
CaptRKO
CaptRKO's Avatar
62GX users.....you will have to remove some of the engine box to get the muffler to fit. Also I had to remove some of the cowl on the side due to the muffler not clearing the cowl.
