Reload this Page >
New CARF P-51D Project
Old 09-23-2021, 09:03 AM
  #251
Chris Nicastro
Chris Nicastro's Avatar
Going back to the wing posts I didn’t get to do early in this build and some people have contacted me so I’ll post some pics.
Old 09-23-2021, 09:51 AM
  #252
Chris Nicastro
Starting to get some paint on it…
I pre-shaded the panel lines and rivets before spray painting the olive drab to see if it would work. It does and it doesn’t because the spray cans can vary and so can the coverage which if it gets too heavy eliminates the pre-shading effect. The cowl doesn’t show the technique but the stabs do. At least the whole plane will be done this way and it will add some interest to the base layer of paint before I go back and add contrast and weathering.
Old 09-23-2021, 09:55 AM
  #253
Chris Nicastro
This is the position I came up with for the wing pylons, the dimensions are written on the wing and verified from the wing root center line.
Old 09-23-2021, 09:59 AM
  #254
Chris Nicastro
The pylons are removable so in the future I can make the drop feature work for scale bombs or tanks. They have plywood with blind nut strips epoxied to the inside of the skin to spread the load.
Old 09-29-2021, 12:33 AM
  #255
Chris Nicastro
Getting some paint done! Here is a test I’m doing to try preshaping the panel lines and then spraying over with the base color. I’m trying this out with Tamiya lacquer spray cans and so far it’s going ok as a basis to start with. I could leave it or push it with more weathering and contrast but we’ll see. Right now I’m more concerned with just getting the basic scheme done.
Old 10-02-2021, 12:35 AM
  #256
orthobird
awesome! I really like what you are doing. Could you show me some more pictures of how you did the rear fuselage panel with regards to how you used the screws to be able to remove and replace the lid over the tail wheel?
thank you
Chris Nicastro (10-03-2021)
Old 10-03-2021, 01:58 PM
  #257
AV8ATOR
AV8ATOR's Avatar
Chris, looks amazing keep up the good work and thank you for sharing as usual. Hopefully I will start my build one day soon.
Carlos..
Old 10-03-2021, 10:26 PM
  #258
Chris Nicastro
thank you
Here you go, I wouldn’t do it this way again just to be clear. The panel is too long and I had to reinforce the tail to be safe. There’s a lot going on here with the retract location and the plate then the panel. I wanted the exterior panel to be removable and not carry any load. The 6 screws hold it on and the air cylinders move the doors, nothing else. Originally I wanted the radio system back here but then I moved it forward so that’s the main reason I say I wouldn’t do this again. The rudder servo is way back here too.
I used 4-40 flat head Allen screws and threaded inserts for hardware.
Old 10-04-2021, 01:10 AM
  #259
orthobird
that is super nice. thank you for posting this,
Ok, I am so sorry to ask this, on the composite side, meaning the shell, did you reinforce this in any way? Where the screws go thru the composite material?
reason I am asking,
I have a CARF P51 GG, and i did not like the access thru the wing saddle only.
Mind you, my airplane is nothing scale. It is meant for speed.
this is what I have done so far. I am not done with it.
any advice would be greatly appreciated
sorry to sidereal your wonderful build thread.
Old 10-04-2021, 01:48 PM
  #260
Chris Nicastro
Ok I see what you mean. Yes I removed the foam from the composite layup and then built it back up with plywood before I drilled holes. The size of the wood inserts, let’s call them, depends on you but I make them at least 4x larger than the area of the head of the countersink screw to distribute the load. Also the thickness must be more than the depth of the CS screw head.
I usually locate a screw like a countersink screw about half the diameter of the head away from the edge of something. That puts the center of the screw far enough away from the edge to be safe as a minimum distance, more could be better. So for example; diameter of the screw head = .25 then I add 0.125 so basically the center of the screw would be .25 from the edge of the part. Flat surfaces are preferable to curvy complicated ones. Avoid getting really close to the edges so the composite material doesn’t blow out.
#1 decide where to put the screws, the corners maybe one in the middle if it’s flimsy
#2 decide the size of the plywood or whatever material, carbon fiber, you’re going to use
#3 remove the foam from the area to the skin of the hatch and epoxy them in place, use good epoxy for laminating/bonding not finishing, West Systems, Locktite Hysol
#4 hatch taped in place drill your pilot holes
#5 install the threaded inserts in the fuselage, don’t use the flanged hobby grade 4-40 use the machined brass type. In my photo I soldered inserts to washers and glued them in plywood
#6 test the screws before you counter sink the holes so the hatch is located correctly, it’s harder to do later
#7 counter sink the holes and get the depth right so the screw is flush
#8 recheck fit and look
#9 apply thin CA to the counter sink to toughen it up
#10 scuff, clean, and paint the screw heads to match the fuselage color
Try that and see maybe on a test panel and go from there.
orthobird (10-04-2021)
Old 10-04-2021, 03:55 PM
  #261
orthobird
thank you so much Chris! Yes, this is what I needed to know. I appreciate you.
Chris Nicastro (10-04-2021)
Old 10-11-2021, 06:43 PM
  #262
Chris Nicastro
I must hate myself, I decided to paint checkers on the nose. Not just any checkers, Mustang checkers. Did you know pretty much every planes checkers are unique? The Frenesi checkers are not symmetrical either, odd numbered too. Then to complicate things further my masking set came in 1/4 scale not 1/4.4 as ordered so I couldn’t finish it. The checkers are freehand but the mask set is for the all the graphics. Tapered, custom, asymmetrical checkers!!!
Old 10-11-2021, 11:05 PM
  #263
Chris Nicastro
Some zebra stripes…
Old 10-12-2021, 06:00 AM
  #264
BobH
Default Carf P51
Nick, looking really good so far.
Chris Nicastro (10-12-2021)
Old 10-17-2021, 11:48 PM
  #265
Chris Nicastro
Making progress…
The nose paint is done except the exhaust but that’s next.
A all the stripes are painted now I’m waiting for the replacement mask set because they sent the wrong scale size.
I’ll be getting the plane assembled and balanced ready to go here very soon!
Old 10-18-2021, 12:41 AM
  #266
IFLYBVM2
My Feedback: (360)
Nice work Chris, very nice..
Chris Nicastro (10-18-2021)
Old 10-20-2021, 10:01 PM
  #267
Chris Nicastro
The wing is back together now and the outer doors are installed finally. Anybody doing this watch out for the pin alignment for the doors here. If the angles are off a little bit it turns into a nightmare and troubleshooting how it’s out of alignment. I have one that’s good and one that isn’t even after all the tweaking I did to set them up originally. So I found a happy medium position with a little bit of twist and called it good for now. Later I’ll revisit this problem and correct it.
The doors on this plane were a total disaster from new and I’ve had to cut adjust and modify them to fit like this. I spent a considerable amount of time on them and I’m still not happy with the gaps and fit but hopefully the invasion stripes distract you!
There’s another geometry problem in the flaps that I’ve double checked several times but it results in a 5mm difference in servo position relative to the wing spar. Even though the linkages are the same lengths there’s something going on with the flaps specifically. I have to verify it but I think the hinge center is not the same between the flaps. I epoxied the horns in the same location tangent to the hinge wire tube inside the flaps. Also you must keep in mind there’s nothing symmetrical about these wings or fuselage so you have to check as you go. Anyway the end result is I had to make the radio compensate on the flap throws and timing which I’m not a fan of because I like to keep things simple and direct.
Old 10-21-2021, 03:51 AM
  #268
orthobird
looks beautiful. On my CARF P51 GG, the doors are installed different than yours. I can take a picture and show you, if you would like to see.
Old 10-21-2021, 06:38 AM
  #269
Chris Nicastro
Sure I don’t mind taking a look. When I started this I just followed the template provided but now I know better!
Old 10-21-2021, 02:23 PM
  #270
Craig B.
Please post a pic. I’m always interested in other methods.
Old 10-21-2021, 02:26 PM
  #271
Craig B.
Hey Chris it’s looking fantastic mate! Thanks for taking the time to post your progress! So much good info in this thread.
Chris Nicastro (10-21-2021)
Old 10-21-2021, 02:57 PM
  #272
orthobird
I have plenty of pictures.
Let me know if you need me to make any measurements,.
THis is factory direct from CARF (thailand??)
(meaning, i did not do this, it came like this)
doors from CARF P51 GG
brass tube is removable.
bottom side, brass tube extends almost 1 inch from front and from back side of door.
door closed, showing where the brass tube enters the front of the wing.
Door open
i grabbed the edge of the brass tube with a hemostat and pulled
I was then able to grab it and pull it straight out.
this is the rear aspect of door opening. Looks like aluminum tube, slihtly bigger than the brass tube, and it has that CHINA HYSOL
this is the front edge of the glued in aluminum tube.
Hope this helps
best regards,
Cam
Old 10-25-2021, 06:46 PM
  #273
Chris Nicastro
Thanks for the photos, this was basically how mine came too.
Nose art done! I had to piece this Frenesi graphic together but it looks ok I think. The F is 1/4 scale and the rest is 1/4.4 because I started the checkers based on 1/4 scale before I figured out the mask set was too big. Disaster averted, moving on!
Old 10-28-2021, 01:40 AM
  #274
Chris Nicastro
Making progress. Now it’s the details and weathering. Here’s the paint I used
Old 10-29-2021, 10:00 PM
  #275
Chris Nicastro
Finally painted the exhaust and started to chip paint and darken panel lines and details…
