Reload this Page >
NEW Legend Models 79.5" F8F Bearcat!
Old 10-26-2016, 01:05 PM
  #151
Lifer
Lifer's Avatar
Well, the engine has a hypnotic sound, but not much power. Too bad. I know that the DLE 55 side-exhaust will do the job with a 4-blade in any case.
Old 10-26-2016, 01:14 PM
  #152
JohnVH
My Feedback: (38)
JohnVH's Avatar
typical of a radial.
Old 10-26-2016, 05:50 PM
  #153
radfordc
My Feedback: (14)
radfordc's Avatar
My favorite maneuver now is "taxi for takeoff"....
Old 10-27-2016, 05:18 AM
  #154
SWORDSN
My Feedback: (13)
radfordc,What do you think the weight of the F8F with FG60 will be?
Old 10-27-2016, 06:45 AM
  #155
radfordc
My Feedback: (14)
radfordc's Avatar
Should be under 20 lbs. Guys who are using a 30cc engine are adding several pounds of lead to the nose to get the CG right.
Old 10-27-2016, 06:55 AM
  #156
radfordc
My Feedback: (14)
radfordc's Avatar
I completed the engine installation today. The cowl mounting blocks are a weak point and need reinforcement. I added 1/16" ply around them as shown. I had half the blocks break during cowl fitting. If one breaks in the air the cowl will likely be destroyed.
ID:	2187743   Click image for larger version
Old 11-06-2016, 12:14 PM
  #157
radfordc
My Feedback: (14)
radfordc's Avatar
I flew the Bearcat today and it is everything I hoped it would be. The first flight was with the 4 blade prop. This flight was cut short due to the engine going over redline temperature. I have the alarm set for 150C (300F) and the engine reached about 155C max. I'm not sure if it would have continued to get hotter if I had continued the flight. I may try it again and see if the temp stabilizes below 160C.
The next 3 flights were with a 22x10 wood prop and the max temp reached was 148C, with the average temp around 140C. The plane performed very well as you would expect. Smooth and stable with nice aerobatic capability. The Saito radial provides just the right speed and power for great flying fun.
The only glitch today was a hinge on one of the inner gear doors pulled out.
ID:	2189158   Click image for larger version
ID:	2189159   Click image for larger version
ID:	2189160   Click image for larger version
ID:	2189161   Click image for larger version
Old 11-06-2016, 01:43 PM
  #158
Lifer
Lifer's Avatar
Good job!
Shannon successfully maidened his T.F. Mustang today. Thought you'd like to know.
Old 11-06-2016, 06:26 PM
  #159
JohnVH
My Feedback: (38)
JohnVH's Avatar
Awesome!
Old 11-06-2016, 06:53 PM
  #160
radfordc
My Feedback: (14)
radfordc's Avatar
Video :
https://youtu.be/S-5BL6ZS9k4
Old 11-06-2016, 07:01 PM
  #161
radfordc
My Feedback: (14)
radfordc's Avatar
Good job!
Good deal....great day for flying!
Old 11-07-2016, 09:06 AM
  #162
JohnVH
My Feedback: (38)
JohnVH's Avatar
awesome!
Old 11-16-2016, 11:11 AM
  #163
radfordc
My Feedback: (14)
radfordc's Avatar
I have ten flights on the Bearcat and I love this plane! It flys as good as or better than my Top Flite giant scale P-47 and P-51. The Saito engine is the perfect match for this plane and gives plenty of speed and power for big warbird style aerobatics. The plane does every maneuver that you would expect a warbird to perform and a few more to boot. Everyone who sees it fly is awed.
The plane provides remarkable value....good construction and assembly, a beautiful cockpit with detailed instruments and pilot, and a great covering job; and the optional retracts are working flawlessly. Nothing bad to say for a $600 warbird.
Old 11-19-2016, 11:31 AM
  #164
swk550
My Feedback: (76)
swk550's Avatar
Default Saito 60cc three cylinder
After receiving the Bearcat and estimating 3# or more nose weight, I've decided my Hacker Q80-14xs motor will not be enough to fly the way I am used to. I like the weight an sound of the Saito 60cc three cylinder.
Old 12-06-2016, 04:52 AM
  #165
swk550
My Feedback: (76)
swk550's Avatar
Default modifications
I have installed pull-pull rudder cables, 1/16" carbon fiber elevator rush rods and epoxy in control horns with ball linkages. I probably saved maybe 2oz tail weight but hope to have solid control surfaces. Sorry, some of the pictures are somewhat fuzzy. I used some 12" and 24" long drill rods for modifications to the bulk heads for installation of cable guide tubes. I made a new rudder control horn and used extra hinges with the rod.
ID:	2192400   Click image for larger version
ID:	2192401   Click image for larger version
ID:	2192402   Click image for larger version
ID:	2192405   Click image for larger version
ID:	2192406   Click image for larger version
ID:	2192407   Click image for larger version
Old 12-06-2016, 05:57 AM
  #166
Lifer
Lifer's Avatar
'll be assembling one of these for a friend this winter. I'd like to study the assembly manual but cannot find it online. Requested a pdf from JB Hobbies but they never bothered to reply. Can anybody help? I like to do my homework first!
Old 12-06-2016, 01:53 PM
  #167
oriole
My Feedback: (19)
oriole's Avatar
See post #19 in this thread for link to Manual.
Oriole
Old 12-06-2016, 02:17 PM
  #168
Lifer
Lifer's Avatar
Thank you!
Old 06-13-2017, 06:47 AM
  #169
radfordc
My Feedback: (14)
radfordc's Avatar
My first Bearcat was completely destroyed a few months ago (plane and engine both total loss). After licking my wounds I decided that this was a plane that I really wanted so I ordered another one and a new FG60. Here is the "Bearcat Part Deux" ready to go.
ID:	2219860   Click image for larger version
Old 06-13-2017, 06:49 AM
  #170
radfordc
My Feedback: (14)
radfordc's Avatar
Here is what the first one looked like....
ID:	2219862   Click image for larger version
Old 06-13-2017, 09:04 AM
  #171
Lifer
Lifer's Avatar
I kinda thought you might......
Old 06-13-2017, 01:24 PM
  #172
radfordc
My Feedback: (14)
radfordc's Avatar
I'm bringing it to the Show-me-Warbirds this weekend
Old 06-13-2017, 03:22 PM
  #173
Lifer
Lifer's Avatar
Good to hear!
Where did you buy the new one?
Old 06-14-2017, 02:19 PM
  #174
radfordc
My Feedback: (14)
radfordc's Avatar
From VQ Warbirds https://vqwarbirds.com/
Old 07-27-2017, 08:52 AM
  #175
JohnVH
My Feedback: (38)
JohnVH's Avatar
Another great flight!
