NEED HELP - ID 2 fiberglass fuselages
My Feedback: (7)
NJ
I have 2 fuses I need some help IDing.
The first looks to be a DO-17P variant. It is about 68" long and has a foam core wing (which I only have a small portion of.) Fuse is epoxy. Cant find any info on it. Seems to be an uncommon model.
The second fuse is an FW 190. The fuse length is 45" as it stands in the photo. I am guessing this will be around a 72" WS. I have no other parts other than a belly pan. The rear deck stands out as it is curved up rather than flat. Might lend a clue as t who made it. There is no gun hood. Does have distinctive structure behind the firewall and below the exhaust outlets.
Any leads would be much appreciated.
GM.
GM.
