FiberClassics P-51 now Comp-ARF P-51
#1752
RE: FiberClassics P-51 now Comp-ARF P-51
Peter,
I converted a scale drawing to get the centerline (measured from the wing root). The center line of pylon is 20 11/16" from wing root and 7/16" in front of the panel line (near leading edge).
Charlie
Charlie
#1753
That looks awesome chisep51.
Well I decided in order to not touch the clearcoat,[8D] I put it in my trailer. Just slid it in, so it will have ample time to cure so I dont touch it. Hard to resist the temptation, so I will leave in here here for a while.
Craig
Craig
#1756
I was a bit surprised to see that myself, but also because I didn't think a DLE 55 was enough to fly a CompARF Mustang.
#1757
His plane was really light and it flew well with the DLE 55.
It was a surprise for me too.... But I'm looking for a bigger engine on mine.
I was expecting to see Ralf Rosen's engine (RR-258) but it wasn't there.
Matt Lupri's P-51 was there too. Really nice P-51.
#1758
Craig that is a great job you are doing.
I have to admit that now I'm lost, I do not know from what thread I start. This or Doss Mustang. After a night working and several of thens of pages ...I am lost.
Guys ...please help me out Criaig where did you get this kit and what are the specs, Is this made of Doss plans?
I am brain dead...sorry.
Adrian
#1759
Adrian
I think it is 1/4.4, it is a Composite ARF.
Should be able to google them. It is an ARF, however still tons of work that is needed to finish it.
The tread is awsome. Lots of pages to scroll through and get ideas on how to do things. It was a great help as the instructions were not the greatest.
Next week I will put it together to have a look, and will take a few pics in the back yard [8D]
Spent the last couple of days going over my Corsair for the new flying season.
Craig
Craig
#1762
A few more.
Pretty happy on hw it has turned out. Still need to do the main gear doors and a few other items.
Craig
Craig
#1764
Thanks Chad.
I just wanted to make sure the clearcoat was completely cured. It was hard not to put it together and wait so long.
Well its off to the basement for more work, think I will make a coffee, sit outside and just look at it for a while. I am pretty happy with it, few minor things to correct for my next project.
Craig
Craig
#1765
RI
Absolutely stunning craig-is she going to stay as "restored" condition, or is she going to get some weathering? also How bout a cockpit and pilot? What are your plans?
#1767
I think currently it will remain as a restored P-51. After normal flight, wear and tear, dirt etc, it should weather up nicely.
Still not decided on engine, so that is still yet to come.
Cockpit is almost complete, have not installed it as of yet.
Craig
Craig
#1768
Hello everyone, Nice aircraft Craig!!! I have enjoyed reading threads, lots of good pics and information. I will bepurchasing a CARF P51 and was glad to find the building threads.
Vince
Vince
#1769
MN
Nice looking bird , but looking@ your cockpit pictures the one showing the left quadrant the part that will have the trim tab controls add to it is from a P-51 B model the correct platform for those controls is flat on top not rounded like what you pesently have mounted. I am not trying to be critical but more accurate.
Rick F
Rick F
#1770
just found a pic with the retracts going up, its just running great now altered the C/G a little back and its flying nice, that 3w 70 red head engine is running very good now great performance got around 20 flights in her now
#1771
Hello
to all of you how is already flying with your carf p.51, do any one have any problems with flutter in the elevator, or has any one of you balanced the elevators in the ballance tab?
Kind regards
Jan, Denmark
Kind regards
Jan, Denmark
#1773
Jan, I have not had a flutter problem with mine and did not add weight to the tabs on the ele.; however, I did not use hinge pins, was concerned with weight/speed of plane and possable flexing of hinge points (even using alum/brass rods for extensions and strength. I made hard points with wire inserted full length of control surface. Incidentally, I posted pic on this thread about year ago and the current Comp Arf p51 kits as well as jet kits are now using the same system. I have balanced the ele/rudder on my new bird, figured it couldn't hurt. The other possible cause of flutter is to insure you lock the servo mount to both the top and bottom of the horiz. stabs as well as wing survo mounts. Doesn't take much give in in the control mount to start flutter.
Charlie
Charlie
#1774
Hi Edhamp,
It has been a while that we worked on the Mustang,it's time that we move up a little bit...
On page 53 Isee that you use the same canopy rails as Imade, but can you tell me how exactly you fixed them on the fuselage ?
Thanks for your feedback,
Regards from Belgium,
Erwin De Backer
