TF GS P47 Build - yeah another bloody one!!
#4776
Banned
RE: TF GS P47 Build - yeah another bloody one!!
got mine from ebay too, though paid about a 1/4 of tiano price
mine fits in perfectly
no cutting required
no cutting required
#4778
LA
i have a question, i have strip planked my fuse, mainly because i sheeted the stab and rudder and they look like doodoo. any ways my question is do i strip plank over the wing saddles, or do i just use filler to true it up with the planking, i ask because they almost are flush with each other without planking over them. Thanks for any response.
DINO
DINO
#4779
Dino
Don't know much about planking, but I made little temps and glued them in then used blue foam sanded to the temp's, and it seamed to have workrd well as I remember I think pete fillets about page 70+ and mine about 100 + you will just have to search but good info is in there.
Hope tis helps
Bob T
#4781
ORIGINAL: mirce
... G-45 is for sure inaff for this plane. It give realistic power for model this size and weight.
Mirce
Mirce
The combat speed of the Jug of 350mph or 648km/h would be scale speed (1/6) 230km/h!
So the G45 is not even close to low cruising speed.
[link=http://www.scaleaero.com/maneuver_realism_speed.htm]CLICK HERE FOR THE LINK[/link] and read this article about realism and scale flying.
When you see Dino at TopGun flying and he opens his Moki 250 there you see close to scale/combat speed, for that he gets points too.
Anyhow, sorry to bust your bubble...
Happy landings
G-Pete
#4783
G-Pete, I am not wrighting about speed, I just tell that G 45 have inaf power for this model. Realisam, when this our Top Flite's Jug is in the air is realy high...
I tell just my opinion and something what I have opportunity to try and see...
Dino's model on last year Top Gun fly realy scale, but for me more scale is flying Brian O'Meara's Sea Fury... And what are you think about this year flying of Andreas Gietz's Corser from Composite ARF. That airplane have also Moki 250, and what a sound.... Ofcourse speed is higher than on my Thunderbolt, but model is bigger also...
All the best from Novi Sad
Mirce
Mirce
#4784
I need help. I have been follwing this thread since the biginning. I am having trouble forming the clear wing tip covers for the lights.
I tried it on the straight balsa, but that left wood grain in the acrilic. Then I tried to monokote that wouldn't take the heat. Then I tried glassing the wing tips, tried that tonight. Still no luck.[]
I've been working on the cockpit, built it myself. what a lesson this was, lot of work.
#4786
ORIGINAL: RWHorton
It's worth it, may you buy 2 pair and keep or sell one pair...
hope this helps
G-Pete
#4787
The easiest way to do the nav lights was the way i showed pete to do them, that is glass and prime the wing so you have a nice smooth surface, and the with the help of a modeling buddy, cut a 1/2ft x 1/2ft of ploycarb or whatever your going to mold them with and heat with a hairdryer/paint stripper gun etc..
Once the plastic becomes very soft, this is were your mate comes in handy because one can support the wing so it doesn't move while the other pull the plastic over the correct location. Pretty simple operation really, and petes came out pretty good.
If you can't be bothered doing that, then the Aerotech sound like a good option too.
dave
dave
#4788
Thanks Abunch. Last night I heated up the .040 poly carb sheet prior to forming it around the wing tip, that worked better. I am trimming the it today and I'll see what it looks like. I'll post a pic if it comes out looking right.
#4792
Ok here is the wing tip lights. It took several tries before I got the poly to for with out distorting it.
Next I move on to the formation lights and landing lights.
#4796
The batteries will last the whole season. I finished the formation flying light tonight. The landing light are next.
This forum has been a great help in building this plane. Thanks guys.
#4799
Banned
got my new motor for the sea fury ordered today, a DA-85
still trying toget hold of Darrell of Sierra so I can order a new tail retract for it
#4800
MI
Nice work on the wing tip lights. I've made a couple plugs to vacuuform mine but have not done it yet. Did you just heat your plastic and pull it over the wing tip?
