blue box pilots?
blue box pilots?
anyone "flying" with there bluebox pilots in thre cockpits? thinking of lightening hole up a pilots body and using him in a yellow aircraft p-47 any thoughts?
AB, CANADA
RE: blue box pilots?
I'm in the process of putting on in my GSP Spitfire. The detail is amazing. I'll post pictures once the cockpit is built and the pilot is installed (it'll probably be a while though).
My Feedback: (14)
TX
I have done that to a couple of the Blue Box Pilots but I cut away about 70% of the plastic body. It takes almost nothing to keep the clothes in shape and since they are static you can cut away most of the joint and use the clothing for the pivot. Despite all that work you still only save about 3 ozs. The next one I do will have nothing but the hands and head along with the clothing tacked together and stuffed with fiberfill.
ORIGINAL: P-47 D PILOT
Hi
Yes I plan to do the same, I have this pilot shown below (similar to Blue Box - Ultimate pilot range) which weighs in quite heavy at 14 oz (Including parachute). How much do the Blue Box pilots weigh.
I am about to strip him down, hack him back to lose some weight. I intend to drill him out all over the place.
He will eventually go in my Yellow P47 cockpit I have built up round him, still needs finishing touches and fitting together.
Cheers
Lee
Cheers
Lee
My Feedback: (14)
TX
In answer to your question about Blue Box Pilot weight, my notes showed the Initial weight to be 8.25 oz.
Sculptured weight was 5.25. I would project that head and hands only with fiberfil clothes for the torso and limbs would come in just over 3 oz.
The Blue Box doll bodies are well made with thick plastic and strong joints. It makes them sturdy and long lasting, I guess, but for flying pilots we can do with a lot less structure.
Hi Guys,
Ive got some of these pilots i got of ebay for a great price.........
Can i ask with the clothing ie: equipment , masks and hats etc did u just use CA or something to keep them in place in flight ??????????
MD
I made a new body out of foam and pipe cleaners, used his head, gauntlets and boots, full uniform and stuff. Total weight is 4 ounces. The foam I used is the black type spongy stuff. He holds position ok with the pipe cleaners but I strapped him in and glued his hands to the stick and throttle to get him to look right.
S1
S1
