What is best 'House Paint' to use? And, anything special used for Airbrush thinning?
My Feedback: (90)
OK, the title pretty much asks it all. I did a "house paint" search here and only came up with a few matches, none of them answering my questions.
I am finally ready to apply a tri-color paint job to my 'glassed, electric powered Hanger 9 Corsair ARF. I think it was 'RichardL' who recommended Benjamin (spelling? has he really been jammin?) Moore paints, but I forgot whether or not he specified indoor or outdoor paints. Ideally, the paint should not require thick/ heavy coats, and should spread very evenly in a thin layer. Durability/ resistance to cracking and dings are also important. Fuel proofing won't be necessary on this one, but I do plan to use the left over paint (should be PLENTY) on other fuel powered Corsairs.
Also, is there any special thinner/ airbrush agent that I would benefit by using?
BTW, I will be using a Miller hobby air compressor and air brush kit. I also have a Pashe airbrush, but find the Miller easier to use.
SO, please offer your advice.
My Feedback: (24)
RE: What is best 'House Paint' to use? And, anything special used for Airbrush thinning?
Actually, the best paint to use is Behr exterior latex house paint from Home Depot. This paint is easy to airbrush and has great coverage. Home Depot has a computerized color matching system and does a great job at color matching. I just use straight water as thinner, but some others are using windshield washer fluid.
My Feedback: (102)
I use the any Exterior latex from Home depot. But I only use the flat latex. I like flat because I put several coats of each color. I sand between every other coat with 1200- 1500 grit sand paper. You can really get a smooth paint job. I always clear coat with a Perfect stain finish. Or lately I have been useing a poly urethane out of a can from Home depot to clear coat it. This plane is all latex and clear coated with polyurethane. The rear half of the plane is fabric also...I also thin with water...30-40%
ty
ty
I have used Behr (Bear) flat latex, but I found that by adding Flowtrol to the paint it allows the paint to flow and lay down really nicely. Also add about 20% water and spray at the lowest pressure you ca get away with. Eash paint gun is different.
Good Luck
Good Luck
ON, CANADA
Read Roy's article? I'd be surprised if you haven't but in any case: Roy Vaillancourt
My Feedback: (90)
THANKS to ALL that have replied, all my questions have been answered.
GREAT article, I'm going to print it out and keep. Very informative, and again: answered all my questions and more.
Thanks again to everyone, I LOVE THIS SITE!
ORIGINAL: voyager_663rd
My Feedback: (13)
IN
Jack,
Chuck here from the MichianaSkyraiders, here his my P-40E and My Hurricane, both painted with Behr brand paints. I didn't use the flotal (sic) contioner but I did use the windsheild wiper solvent as the conditioner. I have tried other brands of latex and nothing can compare the the Behr brand. I'm hooked. See you at the Fly-ins this summer.
Chuck
Chuck
MD
Make sure your wiper fluid is colorless, it will effect the color ! The blue stuff will turn yellow a nice pea green......
I have been using windex clear with good results too.
I have used the behr interior latex flat on my birds.
The only problem I have and still am experiencing is fisheyes. Now it's not from grease or oil on the plane and it's not moisture as I run two traps. I think there is some kind of seperation going on in the mix of flotrol, wiper/windex and the paint, or possibly condensation at the tip of the air gun. Very strange......let it dry and the second coat will get rid of it.
Maybe it's due to using interior flat instead of exterior flat ?
The plane looks fine when done but it does slow you down and annoy the s##t out of you.
S1
S1
MD
You'd be real surprised how rock solid interior becomes after an afternoon in the sun. Durability is not a problem, and like I said, the fisheye will disappear with a second coat. It's not a major problem, just a hinderance.
I'm hoping someone has had the same problem and has found a solution.
In addition, I have noticed that warming the paint and gun before I spray helps a bit and that the fisheyes seem to appear right at the start of spraying. But no real pattern to be able to put a finger on the cause. My best guess is condensation at the spray tip. Once the water dries, it's easily covered with the next coat.
I have used the same paint on 13' span UAV's with no problem at all. The paint is mixed rather crudely, sprayed on without much worry for detail and overspray. I do not recall fisheyes on any of the 30+ I built and others I worked on.
Of course, painting a scale model is on a smaller scale and more emphasis is put into making it look real nice. The UAVs looked real good but not scale quality, although they are in fact scale 'warbirds' serving as we chat....
S1
S1
My Feedback: (90)
ORIGINAL: Ham639
Jack,
Chuck
Jack,
Chuck
My Feedback: (24)
By the way, Frank Tiano sells a [link=http://www.franktiano.com/COLORCHIP.htm]Color Chip Book[/link] that contains WWII and US 1946-99 color chips. You can just bring a page to Home Depot and have them scan in a color chip, and in about 10 minutes, you have a pint of matching color paint. You can also order [link=http://www.gardco.com/fedcolor_book.html]Federal Standards Color Fan Deck[/link].
I've got that book Richard mentioned and have gone to Home Depot and Lowes. This works great, just remember to tell them not to get ANY paint on the book. The guy wanted to brush a dab on the color chip to make sure it matched. I went ballistic and he quickly pulled back. Too expensive and valuable to have someone do that to it. I highly recommend getting one, well worth it.
Edwin
Edwin
My Feedback: (90)
OK guys, I DO already have the book already. And yes, at around $40 (I forget the exact price), much too valuable to have anything happen to it. This book is a MUST for anyone considering scale warbirds. Nothing lasts forever, so I suggest everyone get one while they can.
I did notice that the colors seem a little darker than pictures and paintings of warbirds indicate. According to Luke, this is because the paints became a little washed out from exposure to Sun and elements. Thus, he applies a very thinned out white wash on top of his true scale colors.
I'll be making the trip to Home Depot this coming Sunday (Feb 6), and hope to apply 1st coats the following day.
ON, CANADA
ORIGINAL: CorsairJock
Go to LHS and just buy a bottle (at a buck or so) of the correct paint (Testors, MM, Humbrol, etc all put the FS# on their product--there are also publications that list the equivalent product from other manufacturers for example olive drab from tamiya is xf62, from Humbrol 66 and Testors is 1711). Then just brush/spray some on a piece of paper, wood, etc and take that to the paint store for computer match.
Isn't that a way to go? Plus, you have the paint left over to paint the Tamiya model you bought so that you get get all the scale details correct at the same time.
My Feedback: (90)
Just an update:
Thanks so much for all of the terrific advice. I air-brushed (with my trusty old Miller airbrush outfit) custom mixed Behr exterior semi-gloss, thinned with windshield washer and Floetrol mix.
Here is the result, winner of 2005 Terre Haute, Indiana THRCC 15th annual Warbird Fly-In "BEST FINISH" plaque.
Thanks again,.................Jim
Banned
fisheyes,
While i have not sprayed latex i have spayed many other typs of paints over the years and when painting restored cars years ago after sanding the primer with siloncarbide wet/dry paper fisheyes were are problem for everyone and there was an additive to be used to eliminate them,unfortunately that was with enamels/laquers and i do not rememmber what it was called.the othe possibility is a lack of filter/water/oil seperator in your air line.this will keep oil/water out of your air hose even on humid days and prevent them from messing up your project.
Fisheyes
I had the same problem with fisheyes when I painted my Balsa USA Stearman. I used Benjamin moore paint from Ace Hardware. I thought it was great that they could mix it to a fed standard number without matching it to a color chip. In any case I got a terrible case of fisheyes. The more paint I used the worse it got. The wings are chrome yellow and I used white base coat first because the yellow doesn't cover too well so there was lots of paint on it. Roy Vaillancourt is in my club and I asked him about it. He gave me some good advice to use a piece of clear glass and clean it with alcohol then see if I still get fisheyes on it. It was the same so I first tried eliminating the flotrol, At the end I found that I was still getting fisheyes with just paint smeared on the glass when it was thinned with distilled water. To make a long story short I ran out of paint and Ace could not reproduce the color for again some reason. I went to Home Depot and had them match it to my BM paint. I had to wait two weeks for it to dry and then sanded down the wing. The Behr premium exterior latex enamel went on beautiful. Absolutely no fisheyes and nice coverage. I used flotrol and water. My thought on windshield wiper fluid is that the flotrol will slow the drying time down and the wiper fluid will speed it up. I use a heat gun to accelerate the drying time if necessary and no wiper fluid.
The top coat was with Minwax Helmsman Spar Urethane (semi-gloss) with no reduction after it dried for a month. The minerial based clear coat will affect the base coat if it is not completey dry. It is UV rated and give a nice hard but still flexable finishe that is designed for boats.
I flew it for the first time a few weeks ago. You can see a video at: [link=http://liarsrc.com/video2/Flight%20of%20the%20Stearman%20(Web).wmv]Flight of the Stearman[/link]
Lou
Lou
