Hangar 9 P-40 Warhawk
#951
WA
I bought a used Hanger 9 P40 about two years ago from a fellow club member. It has an OS91 4Stoke for power and a really cool Kelough exhaust. I removes the aft servos and moved them to the more usual spot in the center of the plane. I also had severe nose-over problems on take off and landing. They both got much better when I moved the CG aft to 3.5 inches. The plane flys great with much improved ground handling. I have 4 Hanger 9 warbirds and believe that Hanger 9 made a mistake on this plane when they called for a CG of 3 inches.
In the two years that I have had the plane, I have had nothing but problems with the retracts. I do not like the additional weight and complications of air retracts so I have been waiting for a good set of electrics. I have followed an ongoing forum on Wingspan retracts for this plane and have very reluctantly installed them in place of the originals. They are not very powerful and may have excessive slop in them. The plane is ready to fly, just waiting for some good weather.
Whatever you do with this plane, do yourself a favor and move your CG back to 3.5 inches. You will be glad that you did.
#953
Dear Ford,
Yes the retracts are pretty bad on this model...After restoring mine after 3 months of it being in a bean field and full of mice...I had added some very thin plywood sheeting to the elevator and rudder control surfaces to beef them up which of course made me have to add some weight to the nose section...All in all it balanced just fine at the 3 inch mark with the retracts up in the wing....I agree that it is touchy on the take off run but I have finally got use to flying it off of the runway lifting the back end up and holding it in place till the model get's up to speed...I have an O.S. 75 A.X. in mine pushing a 14 x 6 Top Flight Power Point prop on it........It glides forever on the landing approach but if I do get it on the paved runway and pull the elevator back it is ok...Yes, if it goes in the grass it does tip over...
I might try moving it back to 3 and 1/4 inches..It could stand a reduction in weight.....Don't have any answers at this point about the retract problem....Not much area to mount anything in there that is heavy duty.....
#956
My Feedback: (13)
Magnum RC used to be the US rep but they gave up selling them I think now you have to buy them from the French Company the one thing I like about them is there well built and were a easy install I posted photos of mine way back in this thread I also made balsa wheel wells to replace the plastic units.
#957
Still going strong
Greetings from Finland
Just sake of curiosity. Is there still these splendid planes in flying condition? I just had couple of flights today and she flies as well as first time.
I have crashed her at least three times twice for stupidity and once with radio failure.
She looks little sorry for herself now after repairs. I am wondering if I should restore her once more.
Old Erkki
Old Erkki
