GROUP BUILD - Top Flite Giant Scale F4U Corsair
#6252
TX
RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair
Thanks Bob,
Already started making a new center section. I'm laminating 1/16 balsa with two outer sheets of 1/32 ply for strength. Also using 4 hinge points instead of three. I won't use the new laminated piece for the whole center section, but will taper it down to half-way down the shaped LE.
#6253
My Feedback: (51)
Gents,
I happy to report we put a maiden flight on my TF corsair tonight. Everytihng went really well. Plane flew great. Need to make some minor post maiden adjustments but no big deal. All in all I'm really happy.
Plane weighed in at 28lbs5ozs dry.
CG was set right on the mark per the plans.
I forgot to bring the camera to the field tonight so I'll get some pics this weekend.
I'm excited to get some flying time in now.
#6255
My Feedback: (9)
WA
Congratulations on your successful maiden! Great to hear about these success stories. Please do take some pix and maybe video you can share with us.
Sam
Sam
#6256
Can I ask if 28lbs is around the weight this model comes out at ? reason being, I have just got hold of a kit and am in the process of reading this long thread. So from here on I shall be watching want you guys are up to.
So the question remains....is 28lbs about normal?
Allan
Allan
#6258
Scott
I don't venture away from home mutch as I have arteritus in my hands, which ltmits my flying ability flights are normaly under 6 min and most of the time cramps in the thumbs make landings a hazard so I have a buddy with me that I can hand off the xmitter to when it it gets to bad
Cheers Bob T
#6262
My Feedback: (14)
TX
Todd, glad to hear your maiden was a success. Please accept my apology for not getting back to you on the question you pm me about a few weeks ago. I just now realize I never did answer you. Good to know the recommended CG on the plan worked for you also.
GaryM
GaryM
#6264
My Feedback: (51)
Gary, No worries. I'm just really glad it all turned out well.
Thanks all for the nice responses and all the help in the thread everyone.
If you're local (WI, IA, MN, ILL, IND) or wherever you are from you may wnat to stop by FonDuLac for the Midwest Warbirds and Classics event August 14-16. It's an awesome event and there are over 100 pre-registered pilots, some international. It's a really good time!
web site www.midwestwarbirds.com
#6267
I have been wondering how to glue the center sections LE onto the ribs and the dowel plate. I don't like the idea of only gluing the four R-1 & 2 ribs and ley it dry. If I do that how do I glue the dowel plate in place. It is slightly uneven and I was going to use triangular stock on th outside of each side and then glue and clamp it so the slight uneveness is corrected. I was planning on doing it last after everything else is glued so it doesn't twist the wing. Right now with it set in the center of the ribs each side is the same height from the table and it indicates it's level at the dowel plate. What would you do in my situation?
Please help,
Barry
Please help,
Barry
#6268
Barry
If I understand your question, you have glued ribbs 1 & 2 each side and they are dry. now to glue the L/E to the dowel plate and the remaining ribbs, hear is one of the places I use good old tite-bond (water proff) I just flexed the L/E enough to get a piece of 3/32 ply in between smeard in the glue and clamped it, once this is dry just glue the ribbs (Don't try to do to much at a time hear) or just follow the book page 15 steps 13 thru 21
Cheers Bob T
#6269
IN
Hey everyone, I am in the last stages of completing my Corsair, and I just want to ask a few questions just give me some last minute ideas.
1. What is the best way to position a Futaba Faast reciever in order to have the best antenna placement? I am using Faast receivers in my heli's, but this is my first time in a big bird like this, so I do not want to take any chances with signal interference or problems.
2. I am using a Zenoah G-62. What oil and mixture you using for the fuel?
3. From experience, what throws are you using for the elev, ail, rudder, and how much flap throw for landing?
Simple questions, but I sometimes second guess myself when I have put in several hours of work trying to complete a project, I just like to get second opinions to make sure I haven't forgotten something.
Thanks!
Duane
Thanks!
Duane
#6270
Duane
Glad your getting your bird finished[sm=thumbs_up.gif]
On your first ? have not switched over to 2.4 as yet so cant be of any help there.
? #2 only becouse I hate the smell of auto gas I go to my local small airport and get lo/lead 100 and using Klotz brand model lub @ 50:1
? #3 I set my bird up per the manaul except for the flaps at full flap I get 40 deg's
Hope this helps
Cheers Bob T
Corsair brotherhood #5
#6271
My Feedback: (9)
WA
Duane, Mine has not flown yet, but here are some answers from my experience:
For mounting the 2.4 rx, I will either put it behind the pilot's head rest or where the plans show the air tank ( I moved mine to behind the wing mounting). In either case I'll use the fixture I made out of white plastic tubing to hold the antenna at 90 degrees to each other. I don't want them blocked by the engine.
For my two strokes I start them on Pennzoil for Aircooled Engines (now "Multipurpose Outdoor for Aircooled"), at 32:1, for a gallon and then go to 40:1. After a five or so gallons I'll switch to a semi-synthetic (Husqvarna HP is what I'm using but any good oil will do there is always a lively debate in the gas engine forum but too many folks like Pennzoil at 32:1 for it not to be good) at 50:1.
For the throws I'm going to go for about an inch and a half up and down on the elevator with about 50 % Expo (high rate) and then low rate will be about 3/4". The ailerons I've maxed my throw at about 1.25" up and down. Rudder as much as I can get. Flaps: Mine are between 40 and 50 degrees at full deflection.
I'll know more after my maiden but I feel sure that these throws will be in the ballpark.
Sam
Sam
#6273
My Feedback: (14)
TX
I know you guys gotta be tired of me posting pics of bird. So how about this !!!!!!! How about a pic of your Corsair and you with it. I ve been on this thread for at least 18 months and only have two or three faces to go with all of that good info we exchange. I met Twistawrecka a few months ago, sold DaddySam an aerobat 6 or 7 years ago and Frisconick and I are in the same club. So here goes for a starter, a pic of my ugly mug with the Grey Corsair. Lets see some faces to go with all of those post.
And for any of you guys that are worried about your Corsair tipping the scales a little to hard, Mine is 31 lbs and still handles awesome even in 100 + heat.
GaryM
GaryM
#6275
IN
Thanks for the replies. Now I can get my together again and finish this thing. Here is a pic of the one I built last year and totaled on the maiden flight. Will post pics of my new one (Same paint scheme and everything):
