Reload this Page >
GROUP BUILD - Top Flite Giant Scale F4U Corsair
Old 01-16-2014, 07:54 AM
  #9001
rt3232
+1 for 30 years my first ca was from estman kodack
Cheers Bob T
Old 01-16-2014, 10:38 AM
  #9002
picard1
Originally Posted by acdii
I have a 100cc Extra 330 and I feel the same way, haven't flown it yet and going on two years having it. Of course trashing the prop with doing taxi tests isnt a good omen.
I have had several giant scale planes(Extra, Edge 540) and my first sat in the trailer for over six months before I had the nerve to fly it. But once in the air it flew and landed nicer than any .60 size trainer I had flown....Get her in the air and enjoy!!!!
Mike
Old 01-16-2014, 02:02 PM
  #9003
acdii
Mike
I will this year after I fix the tail wheel that caused me to snip the tips off my $100 CF prop. I still need to locate long enough springs to attach it to the rudder so I can turn it on grass. It never dawned on me until it was too late that castoring only really works on very short grass or pavement, otherwise I would have waited to get the tail wheel springs connected.
Going to be a busy flying season, I hope the weather is better with not so strong southwest winds. I have at least 4 planes that will be ready to maiden, not including the Extra 330 and my 4 already flying planes. The year before I had done twice as much flying than last year, only because the corn was way too high and the crazy strong winds last year. I dont mind flying in wind, except when it is out of the south, because of buildings by the field it creates some nasty vortices that toss the planes around and makes it very hard to land. There were times I had to crab the planes in where the nose was nearly pointed south while coming in from the east, then just as it gets past the building have to quickly correct the yaw to line it up to land. There were times that I just gave up and landed downwind, and risked running off the end. Good thing I practiced a lot of carrier landings and can drop the plane on the numbers from 10' up.
Todd
Corsair Brotherhood # 86
Old 01-16-2014, 02:16 PM
  #9004
stevegauth30
stevegauth30's Avatar
Yeah, that sounds a bit tough. I used to land in almost identical conditions flying full scale. Quite a few white knuckle landings.
Old 01-16-2014, 07:27 PM
  #9005
ctflyboy
NEW BROTHER ALERT
LETS ALL WELCOME " DAVE " (GIV DRIVER) TO THE BROTHERHOOD DAVE YOUR # 89 WELCOME ABOARD
GEORGE
CORSAIR Brotherhood # 1
Old 01-17-2014, 01:52 AM
  #9006
stevegauth30
Welcome Dave.
Old 01-20-2014, 08:49 PM
  #9007
ctflyboy
All,
Is there a way to print out a private message????
George
Old 01-22-2014, 12:15 PM
  #9008
drube
drube's Avatar
Hi guys,
I'm trying to do a little research before I pull the trigger to buy.
Has this kit stayed the same through the years or has there been any updates by Top Flite? I really would like to get one to put on the shelf until I finish my up coming Bates F8F Bearcat build. I've been reading through this thread for a while now and the Flaps build section has me concerned. Seems like that part of the build for me would be the hardest part. I've never built flaps before. lol How does this plane fly, does it come in fast on landings? Does it feel like it will fall out of the sky when slowed down? I would definitely be glassing/ painting and would power it with a G62. Not sure about the retracts though.
Thanks.
Old 01-22-2014, 12:24 PM
  #9009
COL J
Originally Posted by drube
Hi guys,
Thanks.
Hello,
I have the RF GS Corsair Gold Edition kit. I was going to build it in the winters in NE WA. But we have started snow birding to AZ for the winters. I likely will not build it here. I was getting ready to put it on Ebay for $265. It also comes with the TF Cockpit kit and a semi open cowl flaps cowl for this kit. Regards John
Old 01-22-2014, 12:39 PM
  #9010
predman
My Feedback: (7)
Don't worry just buy and build! This was may first ever build 3 yrs ago, really easy just follow instructions. I have. Dle 55 in mine, landings are super slow. One of my easiest flying warbirds ever!
Old 01-22-2014, 12:45 PM
  #9011
drube
drube's Avatar
Thanks predman, did you have to add a lot of weight to the nose with the DLE 55?
Old 01-22-2014, 01:22 PM
  #9012
Fly2XS
My Feedback: (65)
Fly2XS's Avatar
I would expect 4# to 6# depending on how heavy you build behind the CG.
Old 01-22-2014, 01:45 PM
  #9013
drube
drube's Avatar
4 to 6lbs? Is that normal for this plane? Also, I notice where the wing tips join the the center section, it doesn't look like there's a lot holding it on. Has anyone ever had a wing tip fold on them?
Old 01-22-2014, 01:57 PM
  #9014
stevegauth30
The tips to the outer wing panels? Solid as a rock.
Old 01-22-2014, 02:00 PM
  #9015
drube
drube's Avatar
Where the center section joins the outer wing panels.
Old 01-22-2014, 02:56 PM
  #9016
stevegauth30
Nah, you don't need to worry at all. The whole wing in my opinion is solid as a rock. As for the flaps, if you can read and follow the instructions then you got it licked.. If you are concerned about where the wing joins then you can put a through bolt into a t-nut top and bottom and never give it another thought. This is a well designed airplane and a pleasure to build. I say go for it. You can always modify it to suit your likings. Steve.
Old 01-22-2014, 02:59 PM
  #9017
drube
drube's Avatar
Thanks Steve.
Old 01-22-2014, 03:38 PM
  #9018
stevegauth30
No prob. If I can't help with something there are plenty who can. Especially Ctflyboy. Corsair brother #1.
Old 01-22-2014, 03:45 PM
  #9019
drube
drube's Avatar
Good to know thanks. This is a great thread! I was just reading how Ctflyboy did his rivets.
Old 01-22-2014, 03:50 PM
  #9020
stevegauth30
He's a fart smeller that George. I mean, smart feller.
Old 01-22-2014, 03:52 PM
  #9021
Remaking
My Feedback: (15)
@ Drube. Flaps are very straight forward and work well, though I didn't use the internal wood control horn, I just put an external standard style horn on them set up just like the ailerons, and it works great. Plane slows way down on landing, so much so that it tends to stop flying if you don't watch it. When it does stall, it tip stalls to the left however, unlike the TF P51 that stalls straight ahead.
Mine is glassed and weights 28lbs with a Saito 300 twin and I only needed to add 27 oz. of weight over the engine, and filling the spinner with lead. The twin sounds great, with a big 24" prop and everyone thinks it's a radial. I like the way if flys that I'm now in the middle of a 1/4 scale build.
ID:	1960904   Click image for larger version
Old 01-22-2014, 04:04 PM
  #9022
Remaking
My Feedback: (15)
Oh, and I used the Robart electric retracts running off of a sub C cell 3900mh pack that powers the receiver too. I would recommend them HIGHLY! So easy at the field, no air pumps, checking pressure, refilling after every flight. And the sight of a low and slow full flaps gear pass with the wheels slowly coming down is a crowd pleaser. I just need to add the gear doors now.
  #9023
drube
drube's Avatar
Thanks for your input, I may have to pick one up sooner than I planned. Sounds good! I may have to put the Bearcat on hold.. I'll need to ponder this... lol
Old 01-22-2014, 04:16 PM
  #9024
stevegauth30
Do it, do it! Hey remaking, do you have a build thread for the 1/4 ?
Old 01-22-2014, 04:30 PM
  #9025
drube
drube's Avatar
Originally Posted by COL J
Hello,
Check your PMs.
