ARf - sea fury on E-Bay -
#126
RE: ARf - sea fury on E-Bay -
LDM did you use the supplied tail gear? I don't like the one that came with it. Also I'm going with different wheels these ones are 3 inch seem a little small and are fOAM [:'(].
Rich
Rich
#127
My Feedback: (15)
Rich , I resessed the tail wheel strut into the fin , then added support , otherwise the wheel strut puts way to much stress on the rudder .
It should have retaining washers taking the load as opposed to the rudder taking all the load .
I dont like the assembly at all but trying to make it work , I will show pics later this evening .
I used robart wheels , I think I will replace the tail wheel as well , its alreday flat from just sitting .
#129
My Feedback: (15)
Riph , did you try Kiwi aircraft images ??? It has a ton , perhaps its in there .
I am glas this is a sport scale project for me , this has been the most difficult bird to find images on close up .
Squadren signals book is discontinued , I purchase the warbird tech book buts its weak at best , so my choice has been the net .
Its tuff to get tail and fin details and rivit details ect , warbird teck does not show any of this area in detail
#130
LDM are you looking for images of a Sea Fury in general or are you looking for something in particular ? I am going to the War Heritage museum in Mount Hope (Hamilton) Ontario this next week, Firday or Saturday to take some pictures of there Spit. I believe they have a Sea Fury there also. If you need pics of a certain feature maybe I can be of some help. Nitor sells these planes Under the name CMP. There spit is the same one I have, same squadron marking.
rich
rich
#131
My Feedback: (15)
Thanks Rich , I was just looking for some basic detail like weathering in the tail area , does not seem to be many good shots of the tail ,
there are a few makes of the planes we have , willshobby , CMP=China Model products ,
Flymodels ect , so many copies
Lou
Lou
#134
CA
I have waited to being close to done to show mine off. But here is Riff Raff Race #99 about ready for decals. I will take some pictures of the landing gear and doors later. You are going to s**t when you see that.
#135
My Feedback: (15)
hey Rare Bear , that looks sweet !!!!!! , Mine is done just waiting for a clear cote , I was side tracked with work and then trying to get this thing to balance , because I had to modify my wing to hold retracts (version one -first release) I ended up adding 12oz to the firewall to get her to balance .
I used the instructions from Top Flight Gold edition to balance the plane .
Please let me know how your cg comes out ,
thanks
Lou
thanks
Lou
#136
CA
ORIGINAL: LDM
thanks
Lou
thanks
Lou
#137
My Feedback: (15)
You should be ok , dont know if your version came with the retracts or not , mine was a major wing bash , had to cut out the fixed gear rails and rebuild the wing , looks like you alos split the flaps like me .
I should be able to maiden by mid june , to busy with work to get this thing trimmed , taped and sealed .
Dont wont the fule eating up at my weathering
#138
CA
Well I have about four flights on it now. This is the best $100 ARF I have ever owned. Hauls the mail, but slows waaaaaaaay down with full flaps. Make sure you keep the pressusre back on the stick on rollout. Those airfoiled horz stabs keep flying pretty late. Just like a full sized Fury it also comes in with a nose down attitude. Once it's on the ground you are by no means done flying. It tracks perfect, but the tail just doesn't come down until it's going very slow.
#141
My Feedback: (15)
Rusty , thats a difficult guess , when you vistit there home site they show two seafury with differant item numbers but they do not show why the planes are differant . I know from my talk with wills , they are very very difficult to get straight answers .
You should ask them , because I know they are still selling two versions
#142
LDM, Unfortunately, they don't response to my message so until that happens it means no sale although the price lately is hard to pass up even if I don't have an answer. Nonetheless, thanks for the response.
Rusty
Rusty
ORIGINAL: LDM
#143
My Feedback: (15)
I agree with you , trust me the plane is great overall but , the bash to get the retracts in was major , and based on my work , the retracts end up on and behind the CG when retracted .
This adds to my tail heavey problem . I have never build a warbird ever that was tail heavy to the point of this model . I know the top flight seafury can be tail heavy but with careful planning that can be advoided in the building stateges .
I moved everything as far forward as I could , added a giant battery to the front end and still need 12pz of dead weight to get her balance . To me adding almost a pound is totally disappointing because it detract from the performace while adding nothing !!!!!
The overall quality of te cowl , fuse and wings was very good , instructions suck , I refferanced the Top Flight manuals for CG because they are very explicit on wheer to measure from based on the plastic radiator scoops that extend from the wing
#144
AL
You could try e-mailing them over and over and over..
My version is retract ready.. I just need to get around to doing something with it.. Maybe soon..
#146
I noticed some crew on here looking for images of the Seafury.
warbird depot dot com
they have some ok shots. Tho you have probably seen them.
I will be doing this ARF soon.
Where did everyone go and how did these planes fly?
#147
If your in Australia don't by the "YH Models" 66" 90 4 stroke Sea Fury on ebay
Got mine today. Total piece of crap.
Soft fuse. Wing saddle is out of whack, blind nuts for the wing bolts are out of alignment, the horizontal stabiliser wooden dowels are installed on an angle so you cant install the stab, fuel tank exit on the firewall is out of alignment, tail gear collars dont fit the shaft.
I havent looked at anything else. Was scared what else I would find.
Another thing that surprised me is they supply aluminum fuel pipes for the tank. As far as I am aware Glow fuel will eventually eat aluminum? I know methanol will eat aluminum eventually.
49 of them currently for sale on ebay. Avoid like the plague.
I may have gotten a bad one having said all that. But sounds like these are the dodgy Willhobby? ones that were for sale in the U.S.
May not be the sellers fault either. He may have thought he scored buying 50 of these planes cheap from either China or wherever.
I emailed the company and will post back here when/if they contact me.
#148
Banned
ORIGINAL: crasharama
Hi Richard L,
This 1 came & stayed over at the airport I work at about 6 months ago. He came back over for a beatup at about 200ft. Sounded awesome !!!!!
Tony.
Hi Richard L,
Tony.
same scheme as my 90" Vailly SeaFury
