H9 Spitfire Build
#1476
RE: H9 Spitfire Build
Looks cool - but I think oil from the exhaust might find its way into that hatch sooner or later (remember, we are talking about the Keleo exhaust here).
#1477
ORIGINAL: kahloq
Why not make a hatch and hide the switches?
This is bigger then you need, but I can access everything inside the fuse without taking the wing off. I now have a small piano hinge on it. Stays closed from the other side with magnets
I saw your hatch, it is great, but as perreback asked do you think it will be good with the keleo muffler?
#1478
Why wouldn't the plane be good with a keleo muffler? It makes for a nicer install.....no fat muffler sticking out somewhere. I have a keleo on a saito 125 in my TF .60 p-51. Sounds better then the stock muffler, however, I've found one of those saito flex exhaust pipes cut down to about 4" sounds deeper and too me, more aggressive.
#1479
No, the plane *is* good with a Keleo muffler - the question is whether a hatch such as the one you're suggesting is "oil tight" or not.
#1480
Hi guys, I like the idea of a discete push/pull switch . I've seen it done on a lot of scale birds and it looks neat .I like the Keleo muffler IMHO it brings it closer to true scale and removes one continual problem . I have the Saito 125 as well and its biggest problem has always been the manufacturers muffler comimg loose or even breaking of from the 90 degree knuck attached to the engine . I don't know about installing a hatch IMHO it can create some unneeded problems..e.g extra weight to strengthen around the hatch and subsitute for loss of fuselage strenght , possible exhaust oil waste leaking in side and the aircraft becomes oil socked, also the hatch risk comming off in mid flight .... Great to see the Hangar 9 spit still going strong..
cheers Mav'
cheers Mav'
#1481
Kahlog,
I did an electric convert on this bird a few years back (page 40 this thread) I have never been able to get a cg to a point anywhere close to what the manual says and it not feel and fly like it's tail heavy (I heard you talking about in in your video). I had to replace the wing a year back cause I bounced it so hard pushing the gear up through the wing, I would be very interested to know where you ending up placing the the CG. I would like to fly this plan a lot more than I do but it's more uncomfortable dealing with it than it is enjoy able. I have asked a couple of times but folks seem to be all over the place with the CG. I was concerned about the weight but your setup is heavier than mine. I need to buy new batts for this thing before this coming season so I think I'll step up a notch. Batts at 1/2 what they were when I built this model.
thanks
Joel Hughen
thanks
Joel Hughen
#1482
ORIGINAL: jdhughen
Kahlog,
thanks
Joel Hughen
Kahlog,
thanks
Joel Hughen
#1483
ORIGINAL: perreback
No, the plane *is* good with a Keleo muffler - the question is whether a hatch such as the one you're suggesting is ''oil tight'' or not.
#1484
G'day kahloq, Sorry to disagree but the Keleo muffler exhausts on both sides of the cowl ( not the bottom), thats why it looks real to scale,hence the original question where do i place the on/off switch on the fuselage . The top of the fuselage will be covered in oil( and definitely the sides). At present the bottom of my Spit fuselage from the rear of the muffler back with my stanard saito muffler is always covered in oil when in use.
#1485
That is not the type of keleo exhaust I was referring to. On my saito 125, I have a keleo, but not the version that has the "scale" exhaust" stacks. That is was I was talking about. Regarding using the type from keleo that functions in the scale exhaust area, the hatch might have to be made smaller so not as WIDE so the exhaust residue doesn't get to the hatch lines. As I said about mine, there is a piano hinge on one side of the hatch. This would aid in sealing that side. On the other side, a simple rubber lining between hatch and fuse meet would seal that off.
All that being said, if your plane is getting oil and gunk on the top of the nose and on the sides, then maybe a hatch up front wouldnt be a good idea. However, a small hatch for on/off switches fuel fill etc could be done behind the cowl under the nose behind the firewall. You could use a miracle switch with fuel dot and not take up much space and have it hidden really well.
If using a separate battery for onboard glow, then a two switch version with fuel dot would be the ticket
http://www.troybuiltmodels.com/items...HDOTBLACK.html
#1486
G'day Kahloq , I suppose we should have determined which Keleo muffler nirtza79 was purchasing to go on his new Spit, I assumed it was the scale exhaust keleo stack mufler because i couldn't fathom why any one would replace the original Saito unless you were going for a more scale appearance,,, my ignorance I'm sorry..
So kahloq you must have 2 hangar nine spits, one electric powered and one with the Saito125 upfront.. . What's your verdict doing a comparison flying each.?
#1487
No....the saito 125 with keleo PITTS style dual tube exhaust is installed in my TF .60 p-51. Same size plane more or less. The P-51 has a 15x8 prop while the electric spitfire has a 16x10. I think they both fly about the same speed, but the spitfire will land a hell of a lot slower and doesn't weigh as much. The TF plane is just heavy for its size. Overbuilt is what Id say about it, but, that can be a good thing.
I do have other spitfires......a kyosho 90 size. It originally had the saito 125 with the keleo muffler setup, right now it has an OS 120, but not hooked up yet.
And finally, I also have a giant scale 89" Spitfire from Hobbyking. This one has a 50cc turnigy gas. Not finished yet though.
#1488
Sorry for resurrecting a year old thread but I just bought this plane and a Saito 125 to go with it.
My question is however about the retracts (like 90% of this thread...). I plan on replacing the H9 wire with a stiffer piece but I wonder why everyone seems to be using music wire. I understand it is probably a higher quality and stiffer than the factory wire, but people are saying it still tends to bend. Why has no one tried to use some high carbon steel rods from a home improvement store? They sell rods for welding/fabrication that would surely be more rigid than music wire which has to bend/vibrate in order to make music.
I plan on trying the home improvement wire with the Robart struts unless someone can quantify a reason not to...
Thanks, -McCrazy
Thanks, -McCrazy
#1489
My Feedback: (17)
Thanks, -McCrazy
Thanks, -McCrazy
#1490
I checked it out yesterday at Lowe's. They sell 3/16" cold rolled steel (harder than hot rolled) for welding/fabrication. Was 3 feet in length for about $2.50. Seemed rather stout as I tried to flex it, but I didn't have a piece of music wire to compare it to.
Musical instruments need to vibrate in order to make music, but in fabrication you generally want rigidity. This makes me think that while music wire may be a higher grade of steel, it is not necessarily better suited to this task as a structural element.
Will test it out when my plane arrives and report back.
#1492
I think that the wire SHOULD bend a little on landing otherwise on a not so soft landing you will break the gear mount instead of just bending the gear wire. Just my opinion though..
#1493
I agree and the steel did have some give to it which would absorb the impact forces. The question is will it also be able to resist permanent bending with the forces applied to it.
#1494
Anyway you will love this plane it is great!!!! I have had it for two, going into the third season, great plane!
#1495
Not to snipe here but I have flown of a grass field for many seasons with my Spitty. I have never had an issue with the wire bending. Maybe your landing technique could stand some attention. I generally attempt the slowest tail low touchdown I can, The issue I have is that there is so much slop in the landing gear when landing (rarely) on hard surface the wiggling sloppy gear really makes the plane ground loopy. I should think replacing your H9 supplied gear with the normal Music wire found in hobby shops would be an improvement over the Chinese metal gear who most likely is not tempered correctly for our application. I dont think you will be able to bend a tight radius in Cold or hot rolled steel with out it weaken the metal or it might even break.
Sparky
Sparky
#1497
My Feedback: (10)
I have a pair that I have modified with Robo Struts, Scale Robarts Wheels/Tires, Gear doors attached; you would have to modify the wheel wells to accomadate the gear, make them deeper. if interested I can send you some pictures
#1498
I experimented with the stock mechanicals, struts and Robart Air up spring down...wish I'd gone all air or waited for electric, the wing is a pain with retracts extended! Anyway I have a set of stock mechanicals in my gear somewhere, yours for the asking if you get me a prepaid envelope to send them in...I will hunt them up if you contact me.
#1499
I will be posting over on the want adds in a few days.
I have a Keleo Exhaust new never even mounted (Saito 1.00) and a uncut H9 cowl for sale about $175 new but I will send it to you for $120 plus postage.
Also a used wing with retracts, flaps, no servos. Some hangar rash it came off in flight and fluttered to the ground I know what caused this so don't worry about that. $50 plus postage.
I live near Bloomington, Ind (47468) and can drive a reasonable distance to meet if you want the wing as package and shipment might be too much.
Sparky
Sparky
