New Hangar 9 B-25
#727
RE: New Hangar 9 B-25
ORIGINAL: testfly
How about some pictures BigGuy.
#728
Mine did as well and then 2 T's failed after takeoff. I had no air to put them back down.
Tip: If it happens. Just Belly it in and don't worry to much if you have a grass strip to land ON.
All I did was knock off the radar dome when I came in with the gear up.
#730
Guys
I need help
Got the stock Eflite motors they recomend..with Castle 75 ice lites.....Looking at hobby king for batts I know I need 4 S 14.8 V 4200 mah What C rating am I looking for? The LHS recommended hyperion but they are 110 bucks each. I figured hobby king I could get more than 2 for 200 bucks
Thoughts?
I need help
Thoughts?
#731
I run 5 cells in my setup and at least a 30C rating.
http://hobbyking.com/hobbyking/store...idProduct=8589
The higher the C rating the more you can pull out of the battery at once without hurting the battery.
#732
thanks testfly
Do you think running them in parallel the best bet whats the benefit?. I get conflicting reports on each way. I still have a ways to go but I like to plan ahead. I did run into an issue with the fake motor fronts...You pretty much have to get rid of most of the plastic to have the motor fit. Did you find this as well.? Please be advised I'm a rookie flyer...Just got my OK from new club flying my p-51 PTS ....This B-25 wont leave the ground till I'm 100% sure I can handle it
SILLY question. I got 4 round pieces of ply that look like what the motors would mount too. But, in the manual I show no use for them I got 2 lefts and 2 rights of the same i.e GP and EP Please tell me these are not to be used anyplace?
you can see them here with the nacelle
http://www.hangar-9.com/Products/Def...ProdID=HAN4455
BTW, your bird is awesome
Joe
Joe
#733
ORIGINAL: lablover
thanks testfly
Joe
thanks testfly
Joe
I had the same problem with the dummy radials. For right now I'm not using any. I think I will eventually go with the E-Flite AT-6 radials as the look decent and are cheap. My wife did a great job of painting one up for me. I'm running 5s 4900 20 c rhinos. I'm pulling 54 amps a piece on the bench so they are more than worthy. I don't have them paralled, just one for each of the E-Flite pro 60's and Power 46's.
#734
The plates are mounting templates. GP = Glow Power EP = Electric Power I used The EP plates to move the motor out. I made stand offs from hardwood (1/2" X 1 1/8" X 2 3/8")
The 80 amp Turnigy ESC mounts on a plywood plate just in front of the muffler pocket in the nacelle. I will post a image soon. And I did not use the dummy engines.
As for your wiring question... It is a crap shoot. I fly a C 130 that I have 4 seperate batteries. On the B-25 I wired both batteries together for 10,000 mah running both ESCs.
The good thing is that both ESCs see the same voltage all the time. The bad thing is that if one motor shorts it COULD take out the other. Could, but not likely. I had it happen to me
and the other ESC ran fine. ALL THE WAY DOWN!!! Lost but not forgotten. In fact I have another B-25 on the bench right now moving things from #1 to #2.
Everything will fly but the motors and ESCs.
NOTE: I fly a 9303 and we have 2 club members that have lost models because of radio issues not to long ago.
So I though I was having radio issues as well. "NOT" I learned that if you have a airplane in the air. CONTROL OR NOT... FLY IT ALL THE WAY TO THE GROUND AND NEVER GIVE UP ON YOUR RADIO.
I knew better but because 2 friends had issues I too thought I had the same problem they did.
B-25 Crash Report
March 14, 2010
Weather:
Clear and Windy 20 to 30 mph gust.
After the candy drop was completed and the runway re-opened. The B-25 took off to complete the cycle on the flight batteries.
The model traveling west (downwind) made a 90 degree turn to the north and just before a planned 90 degree turn to the east
the model seamed to fail to respond to control inputs given.
After many hours of review of the aircraft and a complete test of the radio system (Range check, battery levels, Amp draw of the servos and load testing of the complete system) it has been determined that the crash was a result of "PILOT ERROR".
The pilot (ME) failed to maintain control of the aircraft when traveling north. Just before a planned turn to the east the left motor lost power at the point input was given to turn right.
While "holding in" full input for the right turn was not enough to turn the model, it was enough to keep the model from turning over due to the loss of the left engine and right engine thrust.
When the input to turn right was relaxed, the thrust from the right engine pulled the model left. This resulted in the pilot thinking he had no control when in fact there was never enough
control surface movement given to over come the high wind and right engine thrust from the 70% power setting used during the flight. But, was enough to maintain level flight with a heading slightly to the left.
When I held up the radio to show my spotter I had NO control the right stick was moved in all directions including the one that caused the spin and crash.
When the stick went left it allowed the model to turn into the failed engine which resulted in the right engine thrust spinning the aircraft to the left at which point it dropped behind the tree line with the nose pointing down at a 140 degree angle. When the model started to spin power was cut. At that point there is no recovery so it best not power it into the ground.
Once we got to the model. ( It was standing on the tail leaning on some vines and both 3 blade props were undamaged and clear of the vines. ) I added a little throttle and the right motor started spinning but, nothing from the left motor. I also had control surface movement and was able to lower the gear.
A close look at the props and spinners showed no strike of any kind which made it clear that the left motor had failed in the air.
The model could be repaired. But, due to time issues it was better for me to buy another kit and move everything over to it. I have already moved the right engine (the good one) over to a Skybolt I converted to electric and now with over 20 flights on it. The motor and ESC are doing well.
[I should note that there was a guy about 50' behind me reving up a big gas motor so I was not able to hear my model. And yes, I can hear my model if there is no background noise and I would have heard the engine fail]
When I fly a new model, the first 30 flights or so are done when my plane is the only thing in the air. The main reason being that if your going to have a problem chances are it is going to be within the first few flights.
Sorry for the long post.... Troy
B-25 Crash Report
March 14, 2010
Weather:
#735
Testfly
For the life of me I can't picture how you mounted your ESC..Is the plywood plate mounted to the motor standoffs?
Any good 3 blade props work well with the eflite elec motors
#737
No need to be sorry. The H9 is a really nice airplane and I got about 180 flights before the last one. It is also worth the time and $$$ to own another one.
I won't do anything different with the second one. Though I may fly it less when there are loud airplanes getting ready to fly. :-)
#738
Hey Big guy
Did you say the at6 radials from eflite fit? I'd like to see that painted up one your wife did. I decided to machine down the alum standoffs 1/2" shorter so the motor does not stick out so much. John Redman did the same thing I saw on another post.
Joe
Joe
#739
YUP
The 1/2 makes all the diff in the world. The Prop is not so far away from the cowls now. However, I need new dummy radials cause I cut them for the first try of the motor fit...Darn...Still looks great
BIG PAIN IN THE FANNY ...Do get em cut just right..Thank god for Brother in law machinist
#741
My Feedback: (38)
CT
There is a set of Robart retracts for the Hangar 9 B-25 for sale in the Buy and Sell section of RCU, but they don't look exactly like the retracts advertised on Hangar 9's website. The strut look the same, but the retract mechanism doesn't seem to match. Can anyone tell me if these are the correct ones for this plane before I put in a bid for them.
#743
ORIGINAL: miklos
#746
Quick question for the guys running Elec.
The cables from my ESC for the batt (Castle) are about 6 inches long. They are 10 ga wire. Looks like I will need to make these longer I was thinking of using castle bullet connectors? I assume this is a better idea then making the leads from the batt longer. Looks like I need to go all the way from the Nacelle to the center of the fuse....Any rules on the safe length of the extension I use to go from the esc?
Hi lab,
In the fuselage I have two Male Deans on one end and 2 Female Deans on the other end of a 12ga wire.
In each wing half I solder 12ga wire to the controller and brought it out the end of the wing about 2" and put a Male Deans on the end.
See image.
I have had no issues with this setup.
See image.
#748
ORIGINAL: lablover
Bigguy
I may just do that..I think I still need to extend the esc cables to the batt however right? HEck, I can always cut em My Baby is almost done...wooohooooo
#750
Hey Testfly
Do you know where one could get the inside canopy image you have in your B-25..Thats a pretty slick idea. I cant seem to find a image however
Joe
Joe
