Reload this Page >
KMP / YT FW-190 Build Thread
Old 12-20-2011, 07:19 PM
  #2451
Mpizpilot
My Feedback: (45)
Default RE: KMP / YT FW-190 Build Thread
Maybe Santa will bring me a better camera for christmas this year. Here he is in the office. I think I'm gonna have to remove the seat pack to get some more head room. He looks a bit squished.
ID:	1702828   Click image for larger version
Old 12-20-2011, 08:19 PM
  #2452
STICK MODE
STICK MODE's Avatar
Well after being grounded for a year world wide due to prop failure (they lost one of the coast of Spain ) they fly again (huge rebuild) 50 hours will be required before air certificate is issued sorry about the quality of the video it does not do it justest amazing sound and boy does that camouflage work it would be on you before you see it my mate has spent a year working on this aircraft the pilot Frank Pearce owns a p40 and as he said nice gentle flying stall test also where done yesterday yep she drops her right wing in a flash just like our models she also gives no indication of stalling just drops that right wing very nasty looking plane both in the air and on the ground ( LOVE IT ) got a few quick videos of her with my camera hope to drag out the video and get better ones enjoy
http://www.youtube.com/user/storchnuts
Have a great Xmas guys and a safe one
ID:	1702856   Click image for larger version
ID:	1702857   Click image for larger version
ID:	1702858   Click image for larger version
Old 12-20-2011, 08:33 PM
  #2453
Mpizpilot
My Feedback: (45)
Are these restorations or replicas?
Old 12-20-2011, 09:34 PM
  #2454
STICK MODE
STICK MODE's Avatar
ORIGINAL: Mpizpilot
That’s a hard one most of these contain a fair amount of original German gear this one is the first built by Yes - it's from FlugWerk New-build using some genuine components collected and stored from the original Marienburg factory. This is the first one they built powered by the Asch82T To follow the Focke Wulf nomenclature, this aircraft was typed Fw190 A8 / N, the "N" stands for reproduction. This is indeed a N The replica agrees in its dimensions 100% with the original. By saving the armour and armament, the plane is almost 800Kg lighter than the original. Coupled with the Russian 14-cylinder radial engine (2.000hp) = a fantastic performance plus reliability.
Unlike BMW801 original motor>>> which where plagued with problems the Asch82T does not have a coupled flywheel (about twice the engine speed which supplied the unit with fresh air), the so called “Ringkühler†(coolers in circle) German for fan will not work in the Asch cowling. the owner wants to have a perfect and reliable high performance aircraft also flying here are corsair’s mustang’s spitfires a hurricane p40 Catalina and a few other rare old golden oldies the FW will be based here in NZ full time Of the approximately 17,000 aircraft produced, only a handful of planes are in museums displayed. Airworthy original examples of the FW190A8 (flying) do not exist to the best of my knowledge
Old 12-20-2011, 10:11 PM
  #2455
bigtim
My Feedback: (13)
ORIGINAL: richiepingi3
Hi,
I have had this KMP Focke-Wulf FW 190 (70'' wing span ) sitting in my hobby room for 2 years half finished. I have decided to finish it and hopefully someone can help me out? I don't like the stock tail wheel assembly... is there one that is a more realistic I can purchase that will fit?
Rich
I used several parts from the Dubro unit to make a TW had to do a bit of modifications to the plastic parts to get them just right,and fit into the small space that the rear compartment has
to make it steerable I shortened the control arm and used a flexible light weight push-rod coupled with the rudder servo for steering,I also dumped the pull-pull for the rudder and went with a pushrod there as well,I did use the P/P for the elevator though.
I also made a mounting plate and with some trial and error fitting I managed to get it to fit under the fuse cover
here is some pics of the set up I have, I am not 100% in love with it but for now its fine and at least is in a semi-scale position
ID:	1702941   Click image for larger version
ID:	1702942   Click image for larger version
ID:	1702943   Click image for larger version
ID:	1702944   Click image for larger version
Old 12-21-2011, 04:22 PM
  #2456
richiepingi3
Thanks a bunch!
Any other hints on this plane?
Old 12-23-2011, 11:16 AM
  #2457
richiepingi3
Thanks for the pics this will help!
Old 12-30-2011, 06:27 PM
  #2458
Mpizpilot
My Feedback: (45)
So my bird is complete minus the retract valve. Besides having to fix the numerous blemishes and overall less then stellar build quality it was not a hard build at all. The wings were perfect though. Mine balanced right at 139mm with both batteries on the firewall and a dle 30. My retracts seem to be quite stout, I've cycled them close to 100 times and left them for over 24 hours and they still held air. Like everyone says, chuck the valve and hoses. Only thing left to do is some light weathering.
On another note, I received the ESM BF-110 for Christmas and the build quality on that one is light years ahead of my FW, I can't find a thing I do not like with that plane. Can't wait to start on it soon.
Old 12-30-2011, 06:38 PM
  #2459
Dowmer
Dowmer's Avatar
Mpizpilot,
Glad to hear that the build is complete. It really isn't a hard build like you said. It depends on what kind of "upgrades"you want to add. Post some pics after you are finished weathering and adding details and give us an update whenever you have the chance to maiden. I've heard that the quality for the FW-190 D9 is better also. Not sure why the quality is lower with the A8. I wish they would update it and fix the scale outline errors and quality. The FW is a popular plane if you want to go to the dark side.
Jason
Old 12-30-2011, 07:46 PM
  #2460
STICK MODE
STICK MODE's Avatar
ORIGINAL: Mpizpilot
for the 110 i hope you go to the dark side ive had a few twins (dark side is the only way to go )nice plane heps of really great camos on them would look great as a night fighter
Old 12-30-2011, 08:05 PM
  #2461
Mpizpilot
My Feedback: (45)
What is this dark side you speak of? Electric?
Old 12-30-2011, 08:20 PM
  #2462
Dowmer
Dowmer's Avatar
Mpizpilot,
Well, some consider Electric the dark side, but in this case I think we are referring to staying Luftwaffe (axis) aircraft.
Old 12-30-2011, 08:24 PM
  #2463
Mpizpilot
My Feedback: (45)
Lol,gotcha. Funny thing is, without even realizing I'm already kind of on the dark side. I've got two fw's, the BF and am thinking about adding a meister fw and the 50cc ESM 109. I do have one allied fighter, a TF p-51.
Old 12-30-2011, 10:53 PM
  #2464
STICK MODE
STICK MODE's Avatar
No im referring to electric as the dark side any thing Luftwaffe (axis) is the right side lol with twins if you lose one motor 98.99999 % she will dump and go in my one and only allied plane my 104’’Lancaster has had a fair few flights on it and it’s a dark side plane never had a problem but my other twins with glow ended up in the end doing the death spiral after losing a motor [:-] on the news front my FWD9 is slowly coming together I had to do some changes to the sierra retracts to shorten them by 10 mm so not to cut out the area in the middle of the wing where your retract wells come together if any one is thinking of this kit I have made a mould to make a new top gun cover ( it will break like tissue paper) im more than happy to make you one if the need arises 3/16 canopy rails are ordered wings and stab stripped filled and glassed had to split and open the cowl due to fitting the twin and not wanting bubbles over the sparkplug caps so sneaked another 12mm on the circumference over all im happy with the kit but most of it has been trashed and up graded I did receive a set of Glennis wheels 5/14 inch which I can only describe as mouth watering
ID:	1707519   Click image for larger version
ID:	1707520   Click image for larger version
Old 12-31-2011, 11:28 AM
  #2465
Mpizpilot
My Feedback: (45)
Those wheels are too nice, but cha-ching!
Old 01-04-2012, 11:28 AM
  #2466
Ramstein44
My Feedback: (157)
Ramstein44's Avatar
I ended up getting another one of these to do a sliding canopy option detail. Then I'll paint it to black 8 and hang her up until the spring.
Old 01-04-2012, 12:03 PM
  #2467
STICK MODE
STICK MODE's Avatar
Ram Hope you and family had a good new year mate Black 8 would be a nice build
Old 01-04-2012, 12:13 PM
  #2468
Ramstein44
My Feedback: (157)
Ramstein44's Avatar
It was very calm which for once was a nice thing Hope yours was well. I've most of the components for this bird but I've little time and as you know, I'm still tinkering with the ME109G.
Old 01-04-2012, 01:03 PM
  #2469
Mpizpilot
My Feedback: (45)
ORIGINAL: Ramstein44
I think you may have been. Luftwaffe pilot in another life, lol. I hope you post pics of the canopy detail
Old 01-04-2012, 05:03 PM
  #2470
STICK MODE
STICK MODE's Avatar
what,s the 109 kit like. have a 40 evo motor here that needs a home think she would fly it was thinking of after the fwd9 (*thou shall not buy more planes Frank yes doctor lol[:-] )
Old 01-04-2012, 06:10 PM
  #2471
Ramstein44
My Feedback: (157)
Ramstein44's Avatar
ORIGINAL: Mpizpilot
Lol, yeah.. You never know..
Old 01-04-2012, 06:14 PM
  #2472
Ramstein44
My Feedback: (157)
Ramstein44's Avatar
It's 50cc and it has a two piece wing. There's a build thread on site on it. Really cool bird.
  #2473
DougB1
Got ready to mount the G-38 in the FW190 and found out the prop shaft sticks out 7/8 of an inch too far [:@] I looked at every web site that handled Zenoah motors and called to see if anyone made a shorter prop shaft, NOT !!! So I did the next best thing and a friend of mine in our club has a machine shop so I took the motor to him and he is going to make me a new prop shaft 7/8" shorter THIS THING OUTTA HAUL BUTT [sm=spinnyeyes.gif] Has anyone else put a G-38 in a FW 190 ???
Old 01-05-2012, 03:37 PM
  #2474
kahloq
kahloq's Avatar
LOL Someone I know put a 50cc gas motor in theirs. G38? pffft !!! Heheh It will though, fly with authority
Old 01-05-2012, 03:43 PM
  #2475
DougB1
ORIGINAL: kahloq
And Guys in my club thought I was going over kill on the motor. [sm=spinnyeyes.gif] Couple of them was trying to talk me into trading my G-38 for a G-26 [:@]
