KMP / YT FW-190 Build Thread
#2501
RE: KMP / YT FW-190 Build Thread
Per my calculations 3 in is too small and 4.5 in is too big. The correct scale spinner should be around 3.5in (90mm).
Any way, I also bought the SD spinner and will use it. The other alternative is to make a custom one ($$$).
#2502
ORIGINAL: Arruda
#2504
ORIGINAL: bigtim
I bought the skyshark D-9 spinner which is just about the right size, its only cut for a 2 blade prop so I also purchased the spinner from ESM it has a little different shape but comes uncut so I will trim that one for a 3 blade prop
#2505
My Feedback: (13)
ORIGINAL: STICK MODE
hey Tim is that the same one as the YT one if so thats the same as i use mine looked like it would be out of balance as the back plate was out but it worked out well
ORIGINAL: bigtim
#2506
yes thats pretty much what i did with mine i was surprised how well it balanced due to that lip on the back plate
#2507
ORIGINAL: bigtim
If you want to make sure you have spinners for this plane and are ok with 2 blade, Id suggest getting a spare...whether its from Skyshark or one of those from SD since we also dont know how long SD will offer them.
#2508
My Feedback: (45)
ORIGINAL: Arruda
...and the bolt that comes with it is short and do not reach the threads on the engine axis.
Also, has anyone ever checked to see that the cowl on the model is the exact circumference in whatever scale this plane is as compared the the full scale? I'm willing to bet it's a bit off, like my spinner.
#2509
ORIGINAL: Mpizpilot
I can go to my local hardware store, get a bolt and send it to you if you would like
ORIGINAL: Arruda
#2511
My Feedback: (45)
If anyone is looking for a good retract valve, check this one out. Replace the ESM junk one with this. Left air in the system for 4 days. No leaks and works great. Just have to file the end flat where the clevis connects.
http://www.sdshobby.net/Air-Valve-3-nozzle-p-2976.html
#2512
ORIGINAL: Mpizpilot
#2513
My Feedback: (77)
KY
yes, you can insert reducers in the lines, combined with the adjustment on the valves. You can make them come up slow, and go down slow. It's not perfect, but pretty good. I am using the sierras with a robart tank.
8 bucks for 4 of them form robart
http://www.robart.com/products/air-line-restrictors
billrad
billrad
#2514
ORIGINAL: Bill Rademacher
billrad
billrad
#2516
ORIGINAL: Mpizpilot
You can also just install wheel collars
#2517
ORIGINAL: DougB1
Those have got to help. The valve I have now SLAMS the retracts up, sure would not want my fingers in there when these babies goes up. [:@]
billrad
billrad
Doug replace that air valve with the red robart one its ajustable and your retracts are well on there way over there mate
#2518
ORIGINAL: DougB1
billrad
billrad
#2519
My Feedback: (77)
KY
All, here are photos of my PTE-36R installation, replacing the DLE-30, for what it's worth. Mounting pattern is practically the same. Bolt pattern for the prop is the same. Gray on the cowl is my repair work enclosing the motor, waiting for paint.
billrad
billrad
#2520
Bill,
Nice house of toys. BTW, do you have any good pics of the release system you set up for the drop mechanism on the drop tank? I have the Ty's ETC501 shroud but I'm trying to figure our a good way to hook it up with a servo and what kind of hook etc. for the tank.
Jason
Jason
#2522
Thanks Bill,
I see the green piece from the Hobby King Part (I have one too). Does the push rod connect to a rocker lever that is attached to the green link? The linkage is what has me stumped.
Jason
Jason
#2524
My Feedback: (77)
KY
yes, the servo just connects to a link attached to the green retainer base. It slides back and forth under the wooden plate. The white servo arm part that sticks out and protrudes into the bomb keeps the bomb from sliding when the green retainers are moved by the servo.
hope this helps. I have only used it to release the tank before a flight. I have not flown with it yet, but I hope to this spring.
billrad
billrad
