I need help with Byron P-51 landing gear
I got it now thank you, Next question, The gear down mode (stock Byron gear) I see that one is not at the right angle. Befor I take it apart can I adjust this somehow?
FL
Your measuring the wrong thing. You need to measure the diameter of cylinder thru the exhaust port to tell which engine you have. The measurments you have are correct for the size engine your trying to I.D. Regards Greg
Retracts for Byron P-51 question
Is there something I can put into the airlines (to lube O-ring's) that won't attack the rubber? or is it a simple replacement part (parts) I can get somewere?
