Reload this Page >
COMP ARF 110" F4U ARF WITH FOLDING WING ASSEMBLY
Old 03-27-2012, 03:41 PM
  #1226
harleydoberman
Default RE: COMP ARF 110
Thank you
I guy named Cris Finck Did the assembly and paint. My time to build
went bye bye when I made my hobby my vocation. LOL
Old 03-27-2012, 05:26 PM
  #1227
Thunderbolt47
My Feedback: (8)
Thunderbolt47's Avatar
Nice looking plane. However that engine needs a baffle of some kind around it. It will run hot or run hotter than normal.
Old 04-28-2012, 09:22 AM
  #1228
samparfitt
My Feedback: (43)
Wing conversion.
I just got my wing gear back from Mitch at Down-n-lock.
I dropped them off when I was at Toledo.
First time that I've met Mitch: a real nice guy and explains all the changes needed.
In this case, all the changes are done to the outside wing arm: besides an electric motor, a new mount is welded on plus a stop stud. Also included is a control box and instructions.
This will be nice as it eliminates the oil and should be much more secure as a threaded rod should be much more rugged in keeping the wing in its proper location.
Not sure when I'll get to the conversion as I, presently, want to finish up my Bates B-26.
Old 04-30-2012, 10:30 PM
  #1229
ram3500-RCU
My Feedback: (221)
ram3500-RCU's Avatar
Nice Sam. We are here at Top Gun with ours. Hope to showcase what Down & locked can do for us. In our case, electric gear, electric wing, and electric canopy.
ID:	1757315   Click image for larger version
Old 05-01-2012, 01:57 AM
  #1230
samparfitt
My Feedback: (43)
Gary,
After seeing the F4U at Toledo, it is a very impressive plane.
With Dino flying and all the outstanding work and mod's that you and your brother have done to the plane I'm sure the team will do very well.
Old 05-01-2012, 08:44 PM
  #1231
ram3500-RCU
My Feedback: (221)
ORIGINAL: samparfitt
Gary,
Thank you Sam.
The maiden went great. On the second flight, Dino was practicing his maneuvers already.
The team after the maiden.
Old 05-02-2012, 09:05 AM
  #1232
harleydoberman
The first flight of the Lucky Gallon corsair.
http://www.youtube.com/watch?v=MOYb1536Mxw
Old 05-02-2012, 09:19 AM
  #1233
docgboy
Harley,
Plane looks and flys fantastic. It must have been a very talented pilot who flew that for you. It landed like a butterfly with sore feet
Scott
Old 05-02-2012, 10:45 AM
  #1234
samparfitt
My Feedback: (43)
Nice video and flight.
What engine and prop size did you use?
Old 05-02-2012, 03:25 PM
  #1235
harleydoberman
He is also very modest to!!!!
Old 05-02-2012, 03:27 PM
  #1236
harleydoberman
DA 120 with a 26X12 Three blade.
Tony
Old 05-03-2012, 08:03 AM
  #1237
AnthonyW
AnthonyW's Avatar
Any photos or updates from top Gun?
Old 05-22-2012, 06:03 AM
  #1238
samparfitt
My Feedback: (43)
Wing conversion to electric
The wing folding mechanism was converted by Down-and-lock.
I'm figuring that the electric should be more reliable and also safer than the hydraulic system (also less messy!).
9-12 volts are needed so I added a regular extension connector to one of my 8 cell transmitter battery packs (1500 ma at 9.6 volts ).
Mitch gives clear instructions for wiring to the control unit.
There are two outlets for each wing.
Mitch provides a double male extension to connect the control unit to the receiver.
I'm using auxiliary power so the 8 cell pack goes to another on/off switch and then into the control unit.
The motor unit is a screw type drive: a new mount was added to the wing mechanism to secure the motor as well as a 'stop' piece of aluminum along one edge of the wing mechanism to stop the wing in the UP position.
Before installation, a test run was set up on the bench. It works great.
Bench test video:
http://www.youtube.com/watch?v=6S_qX...ature=youtu.be
ID:	1765026   Click image for larger version
ID:	1765027   Click image for larger version
ID:	1765028   Click image for larger version
ID:	1765029   Click image for larger version
Old 05-22-2012, 06:35 AM
  #1239
ram3500-RCU
My Feedback: (221)
Bench test video:
The receiver pack is a great idea Sam. Should give it an extra boost of speed. One note, smooth operation is critical. We found that lubing the pivot area, and not overtightening the bolts through the carbon fiber spar help. Also, if you try to taxi while folding the wings, and you hit a bump, one or both may stop from the added load (the control box will "think" they are up)(we experienced this at Top Gun). If this happens, simply hit the switch again, and they will continue to cycle up. Going down is no problem while moving.
Also, we now have total confidence in the positive lock the electric conversion has over the hydraulic system. It is our opinion that, although we would NEVER fly the hydraulic system without some sort of secondary locking mechanism in place, the electric version is totally reliable all on it's own. IMO, this alone makes it a very practical and worthwhile expense for this Corsair.
Have fun.
Gary
Old 05-22-2012, 06:52 AM
  #1240
samparfitt
My Feedback: (43)
Thanks for the tips, Gary.
When I, initially, installed the mechanism to the wing spar, I added epoxy/micro balls as a 'filler' and only snug fit the bolts until the 'filler' dried. The 'filler' made the spar the exact same width as the wing mechanism and eliminates any binding.
Keep up the excellent work on your build threads.
Old 05-22-2012, 07:00 AM
  #1241
ram3500-RCU
My Feedback: (221)
Thanks Sam. You a tough act to follow.
We did the same thing on the install of the mechanism, but found that it was still possible to over tighten the unit after the conversion. We had a tendency to over do it not wanting the wings to fall off. Snug is all that is necessary.
One more note for those converting. We always like our wiring to be neat and well secure. In this case, the wire to the motors MUST be loose so they can move in and out as the motor moves up and down the outside arm. They look precarious, but it has to be. I made this mistake and Brian caught it before it caused a problem. One fold is all it would take and you would have damage, for what it is worth.
Old 05-23-2012, 04:05 PM
  #1242
samparfitt
My Feedback: (43)
Wing conversion to electric (cont)
I had my neighbor help me turn this monster on it's back and took the wing off.
I've got about a 3' extension of wires and air lines to make removing the wing easier.
The 'before' picture.
Hydraulic system removed from the center wing.
ID:	1765275   Click image for larger version
ID:	1765276   Click image for larger version
ID:	1765277   Click image for larger version
Old 05-23-2012, 04:21 PM
  #1243
ram3500-RCU
My Feedback: (221)
Now to get rid of those nasty old air tanks.
Old 05-24-2012, 06:52 AM
  #1244
samparfitt
My Feedback: (43)
I had an extra set of wing retracts so the originals stayed on the plane while the second pair was converted to electric. I opted to keep the original center wing mechanism as it has some 'grinding' that was done on one edge to allow the outer wing to freely move. The outer wing mechanism has all the changes to it for the electric so that portion was used.
Prep:
Before disassembly, I marked all main parts as right/left side and also taped the motor to the frame to insure it doesn't rotate (and be out of alignment with the other motor).
New holes to attach wing to new mechanism.
I clamped the original and converted mechanism together and transferred the attaching wing holes via a metal scribe and center punched them. A pilot hole was drilled and then the needed drill used so I could tap the hole for a 10X32 bolt.
Great planes has a nice set of drills/taps for both American(standard) and metric.
I used a file to soften the edges of the mechanism to allow the wing to easier slide onto the mechanism.
Before disassembly, I also tick marked the end of the motor screw to the sliding T pin to insure I got the assembly back to it's original place. There is a set screw inside the T pin that must be loosened as well as tighten to remove the two parts. The end of the motor screw should be flush with the edge of the T pin.
Also, before disassembly, I had to run the mechanism to get it slightly from full up position so I could remove the main rotation brass pin (releasing the force on it from the motor screw).
One side done.
I only did one side at a time, in case I had questions on part placement, I could reference the other side.
The control unit and battery was installed in the center wing.
ID:	1765408   Click image for larger version
ID:	1765409   Click image for larger version
ID:	1765410   Click image for larger version
ID:	1765411   Click image for larger version
ID:	1765412   Click image for larger version
ID:	1765413   Click image for larger version
ID:	1765414   Click image for larger version
ID:	1765416   Click image for larger version
ID:	1765417   Click image for larger version
Old 06-01-2012, 02:55 AM
  #1245
P. Richards
P. Richards's Avatar
Nice Video no music version will be uploaded later today enjoy.
P. Richards aka SwatTeam
http://youtu.be/Rk70TcwcDfo
Old 06-01-2012, 07:03 AM
  #1246
Ken-h
Ken-h's Avatar
Ah...Battlefield! Very nice work.
Old 06-01-2012, 03:23 PM
  #1247
P. Richards
The non Music version F4U Corsair with Folding Wings
http://youtu.be/TFQuVm-xPfU
Old 06-15-2012, 07:23 AM
  #1248
[email protected]
New Wing System never used 400.00 907-232-2118
Old 06-21-2012, 02:55 AM
  #1249
samparfitt
My Feedback: (43)
Mitch at Down-and-lock has put out a two part video on installation of the folding wing mechanism, after conversion to electric.
part I:
http://www.youtube.com/watch?v=D5hdIoxvkAM
Part II:
http://www.youtube.com/watch?feature...zgokHfKPQ&NR=1
Old 06-21-2012, 05:21 AM
  #1250
ram3500-RCU
My Feedback: (221)
part I:
Part II:
This is very cool Sam. Thanks for the heads up. This will be very helpful to many builders I suspect, and give even more confidence to those still undecided on the conversion.
looks like we really started something,
Gary
