Reload this Page >
COMP ARF 110" F4U ARF WITH FOLDING WING ASSEMBLY
Old 01-14-2012, 09:35 AM
  #1201
samparfitt
My Feedback: (43)
Default RE: COMP ARF 110
I don't think you can get any more secure on a wing lock as the screw drive will hold the wing in position.
Old 01-14-2012, 11:47 AM
  #1202
ram3500-RCU
My Feedback: (221)
ram3500-RCU's Avatar
ORIGINAL: samparfitt
We agree Sam. For the first time since working with these, I really do feel confident in the wing lock to lower them as we taxi out and go. I would never have done that with the hydraulic system.
Old 01-16-2012, 01:51 PM
  #1203
iflytailies
My Feedback: (82)
I now have instrument panel kits for the CARF Corsair in stock, item# 3026; and gun sight# 2029-5 :
http://www.iflytailies.com/store/ins...cale-warbirds/
Seat, control stick, pedals, harness, pilots also available
ID:	1715028   Click image for larger version
ID:	1715029   Click image for larger version
ID:	1715030   Click image for larger version
ID:	1715031   Click image for larger version
Old 01-16-2012, 03:00 PM
  #1204
samparfitt
My Feedback: (43)
Impressive looking cockpit parts.
Old 01-16-2012, 03:22 PM
  #1205
77chickenhawk
77chickenhawk's Avatar
looks like Z-SPAN'S STUFF
Old 01-16-2012, 03:27 PM
  #1206
iflytailies
My Feedback: (82)
I am the US distributor for Aerocockpit / Propagteam
Old 02-10-2012, 02:06 PM
  #1207
samparfitt
My Feedback: (43)
Mods added to the main gear.
Got my gear back from Darrell.
He welded the fork to re-enforce it for any future hard landings.
He also added some new pins to my scissors as the oleos were turning and causing the wheels to have some small rotation which caused them to bind when I pulled the plane backwards. They are nice and tight, now.
Old 02-10-2012, 05:35 PM
  #1208
ram3500-RCU
My Feedback: (221)
Good upgrades.
Did you change your front wing hinges out with the new ones?
Old 02-10-2012, 06:21 PM
  #1209
samparfitt
My Feedback: (43)
Yep, did that before I painted her.
Old 02-10-2012, 06:35 PM
  #1210
ram3500-RCU
My Feedback: (221)
Another good improvement. She is getting better all the time, isn't she.
Old 03-24-2012, 06:13 AM
  #1211
JamF4U
We test flew today, not with out problems. Airframe is in good condition.
Thanks Dad, Pete. Job well done.
ID:	1742002   Click image for larger version
ID:	1742003   Click image for larger version
Old 03-24-2012, 12:17 PM
  #1212
MANFRED
My Feedback: (27)
What problems?
Old 03-26-2012, 01:05 AM
  #1213
JamF4U
ORIGINAL: MANFRED
What problems?
Engine overheating mainly.
Regards.
Old 03-26-2012, 01:08 AM
  #1214
JamF4U
Some more pictures.
ID:	1742980   Click image for larger version
ID:	1742981   Click image for larger version
ID:	1742982   Click image for larger version
ID:	1742983   Click image for larger version
ID:	1742984   Click image for larger version
ID:	1742985   Click image for larger version
Old 03-26-2012, 02:46 AM
  #1215
samparfitt
My Feedback: (43)
Jamf4u,
Looks like a very nice paint job.
Thanks for posting the pictures as I was wondering what those half circle arrows were for on my decals sheets that I got from Taylor made.
For the overheating, you'll probably going to need to add the functional cowl flaps and baffling won't hurt, either.
Old 03-26-2012, 05:01 AM
  #1216
JamF4U
Jamf4u,
Thinking about both at the moment.
Regards.
Jam.
Old 03-26-2012, 09:57 AM
  #1217
Lee Estingoy
First flight - Electric Comp Arf F4-U
Finally got this thing in the air. My goal was not to go nuts with scale, rather make a sport racer warbird with some nods to traditional Corsair markings. Many of you are familiar with the OLATHE NAS tag on the dove gray scheme. You may not realize that Castle is based in Olathe, which is a suburb of Kansas City.
I've set this up with a Neu 2220 1.5Y, with a 6.7 -1 gearbox. It spins a 30 x 16 prop at up to 4,000 rpm - so definitely in the range of the radials that I've seen posted here.
It's carrying 12S, 2P 8300 mAh cells. I flew for 7+ minutes yesterday and used less than half of that capacity, so I can likely get right at 15 minutes should I choose.
Balance was a non-issue, the batteries tuck up under that cowl and that's about all that's needed to keep the CG in a good place.
Still have a bit of art work to do and maybe a few upgrades here and there, but overall, I couldn't be happier with the first flight.
Pics to follow as soon as I figure it out.
Lee
ID:	1743125   Click image for larger version
ID:	1743126   Click image for larger version
ID:	1743127   Click image for larger version
ID:	1743128   Click image for larger version
ID:	1743129   Click image for larger version
ID:	1743130   Click image for larger version
ID:	1743131   Click image for larger version
ID:	1743133   Click image for larger version
ID:	1743134   Click image for larger version
ID:	1743135   Click image for larger version
Old 03-26-2012, 01:56 PM
  #1218
samparfitt
My Feedback: (43)
Lee,
That's the largest plane that I've seen, battery operated.
I like the cowl mod'.
Old 03-26-2012, 02:40 PM
  #1219
pappy 883
WOW Lee, electric ? I had no idea it was practical at that size . What is the cost ratio , electric Vs. Moki 250 radial ?
Are you planning any radial engine sound system ?
Old 03-26-2012, 04:05 PM
  #1220
Lee Estingoy
Ha, this is one of the few times I can come out on the top in one of these.
Moki 250 = $4k.
Electric Neu 2220 + gearbox = $1k
Controller - Castle 160ICE 2 HV = $300
Batteries = 3S x 8 packs @ 120 = $1k
Oh yeah, John Harrison's sound system = maybe $200 ?(I might be totally off on this one, although I have one coming soon)
So, for $2,500 you can swing a 30" 3 blade at 4,100 rpm for 15 minutes. No shake, shimmy, mufflers, gassy vehicle interior etc....
Now if the question were how does this compare to a more traditional motor, like a DA 100, 120, 150 DA all the way.
Old 03-26-2012, 04:38 PM
  #1221
Lee Estingoy
The COMP ARF Corsair looks huge, but it breaks down pretty well. I can haul it in my 'wagon pretty easily.
Old 03-27-2012, 11:44 AM
  #1222
harleydoberman
I also went with a sport scale version. The lucky gallon as shown below. Waiting for weather to break to maiden.
Tony
ID:	1743510   Click image for larger version
ID:	1743511   Click image for larger version
ID:	1743512   Click image for larger version
Old 03-27-2012, 01:10 PM
  #1223
jchorak
My Feedback: (9)
Tony,
What engine and prop combo are you using?
John
Old 03-27-2012, 01:31 PM
  #1224
Lee Estingoy
NICE!
I managed to stumble across Race 57 when she was on a sleepover at Chino.... I had enough trouble painting mine solid blue.
Lee
Old 03-27-2012, 03:32 PM
  #1225
harleydoberman
ORIGINAL: jchorak
Tony,
John
DA 120 and a 26 x 12 XOAR
