Reload this Page >
Meister 1/5 scale P-47
Old 12-16-2014, 09:15 AM
  #1751
Caveira80
Caveira80's Avatar
Originally Posted by ram3500-RCU
Still using the 150s Mirce. We use a 26 X 16 on them. I would think that the 180 will be about the same. Maybe an inch larger.
The prop range is the same for 150 and 180. youŽll probably get some RPMs more...
Old 12-16-2014, 09:45 AM
  #1752
ram3500-RCU
My Feedback: (221)
ram3500-RCU's Avatar
Makes sense.
Old 12-17-2014, 10:06 AM
  #1753
Caveira80
Caveira80's Avatar
Guys, one question:
ItŽs my first moki and IŽve heard that "overheating" is an issue with this machine.
IŽm planning to baffle it but I do have some questions regarding installing an dummy engine.
do u feel it might be an issue??
thanks for helping me!
Fernando
Old 12-17-2014, 11:48 AM
  #1754
Greg Wright
Greg Wright's Avatar
Why would you want to install a dummy engine?
Old 12-17-2014, 11:50 AM
  #1755
mirce
In front Moki???? Noooooooooo........
Old 12-17-2014, 12:43 PM
  #1756
ram3500-RCU
My Feedback: (221)
The judges at Top Gun accept the Moki and don't downgrade you. No dummy needed or wanted. As for baffling, I usually do. However, on the Meister P-47 I do not. I make the cowl flaps operational so I can open them farther, and block off the bottom of the cowl. This gives me an even temp across the cylinders with no cheater hole in the bottom of the cowl. I'll be installing this in this new build on the next couple days and posting pictures. rightBeen running mine two years like this and those who have seen her fly will attest to the performance. Dino has flown her as well and gave her two thumbs up.
Old 12-17-2014, 01:46 PM
  #1757
ccostant
My Feedback: (38)
ccostant's Avatar
I saw Gary's Meister fly at Warbirds Over Delaware last summer. Just one word to describe it, Swweeeeetttt!! The Meister P-47/Moki 150 is the perfect power combo. Plenty of power. Now if I could just get started on my build. Got all the parts including a Moki 180 but no time to build right now.
Old 12-17-2014, 02:27 PM
  #1758
ram3500-RCU
My Feedback: (221)
Thanks for the compliment. I really enjoyed that event. I plan on being a regular. :-)
The all radial flight I had not seen before and it was a privilege to fly in it. Even the announcer said "I'll be quiet so we can just listen to these wonderful engines". Very cool.
Old 12-17-2014, 07:37 PM
  #1759
jeff naul
My Feedback: (16)
Gary, did you crash your or just building a new 47?
Old 12-17-2014, 08:21 PM
  #1760
ram3500-RCU
My Feedback: (221)
Zombie is alive and well Jeff. I'm planning to return to Top Gun in 2015 with her. This latest build is for my friend Johnny Z, who also plans to be at Top Gun with this P-47. If ever I can get it to him. We plan to spot for each other, flying the same maneuvers.
Here is are some pictures of Zombie at this years full scale Cleveland Air Show. I consider it a privilege to be invited to fly there and my brother and I have a great time. Couldn't do it without Brian's crew chief support. Giant scale war birds need constant attention, especially with radials, just like there full scale counterparts.
ID:	2055956   Click image for larger version
ID:	2055963   Click image for larger version
Old 12-17-2014, 08:39 PM
  #1761
ram3500-RCU
My Feedback: (221)
The cowl with the flaps cut off. always leave them together until they are glued to the hinges. This keeps everything straight.
Old 12-17-2014, 08:47 PM
  #1762
ram3500-RCU
My Feedback: (221)
A shot of one of the cowl plates with the new cowl mounts laid out on it. These little mounts will be glued to the cowl in front of the plate, and will be all that is on the cowl itself, so you can get it over the radial.
Old 12-17-2014, 08:50 PM
  #1763
ram3500-RCU
My Feedback: (221)
One of my grandsons visiting PaPa's shop after a sunday was consumed. Evidence can be seen on his adorable face.
Old 12-18-2014, 05:43 AM
  #1764
Caveira80
Caveira80's Avatar
Thanks RAM!
IŽm worried about the static evaluation about TG as Im going in Expert category and there is static evaluation. that makes me more confortable!!! = )
Mirce,
I know it will be a shame to hide the Moki behind the dummy !! dont blame me... LOL!
thanks!!!
Old 12-20-2014, 01:04 PM
  #1765
ram3500-RCU
My Feedback: (221)
Originally Posted by Caveira80
Thanks RAM!
Mirce,
thanks!!!
I know first hand. I ran a CARF Corsair through static equipped with a Moki 250. They liked the fact it was a real radial.
You'll be fine. Just don't provide any close up pictures in your docs of the engine. Make sure you do document your detail work. They rely on your docs for comparison to the plane. If it isn't as perfect as you can make it, don't show any pictures of it and make sure your three views match the plane. You probably are fully aware of all this, but i'm just reliving my experience with the static judges right now.
Old 12-21-2014, 07:43 PM
  #1766
ram3500-RCU
My Feedback: (221)
Wing tip lights and a picture of the full scale counterpart.
ID:	2056859   Click image for larger version
Old 12-21-2014, 07:49 PM
  #1767
ram3500-RCU
My Feedback: (221)
Wing guns. All aluminum and made in two sections. The base gets glued in and the main barrel screws into it. Being removable makes for much easier transport.
ID:	2056861   Click image for larger version
ID:	2056862   Click image for larger version
ID:	2056863   Click image for larger version
Old 12-26-2014, 11:51 PM
  #1768
ram3500-RCU
My Feedback: (221)
continued work on the cowl flaps. The new cowl mounts installed with their blind nuts.
Old 12-27-2014, 12:00 AM
  #1769
ram3500-RCU
My Feedback: (221)
At this point I glue the two flap rings together. The tapers facing each other. Meister provides locating pin holes laser cut that make it very easy to keep the two plates perfectly lined up. I use wooden dowels in these holes during the initial steps.
ID:	2057982   Click image for larger version
ID:	2057983   Click image for larger version
ID:	2057984   Click image for larger version
Old 12-27-2014, 12:03 AM
  #1770
ram3500-RCU
My Feedback: (221)
Once the flap plates are made and bolted to the cowl, I can tape the flaps in place.
ID:	2057986   Click image for larger version
Old 12-27-2014, 12:14 AM
  #1771
ram3500-RCU
My Feedback: (221)
Now I'm ready to begin installing hinges. I added another layer to the side that will be against the flap, allowing it to rest flat against the flap for good adhesion. The other side hangs over the back plate so the hinge point is not a problem. I cut the hinges around the top three mounting washers. The bottom two will go over top of the hinges. Glue the hinges to the flaps first. This is important to make it easy to keep the flaps and cowl flush. Very easy to move the flaps in and out as you glue the hinge to the wood plate.
ID:	2057988   Click image for larger version
ID:	2057990   Click image for larger version
ID:	2057991   Click image for larger version
ID:	2057993   Click image for larger version
Old 12-27-2014, 12:18 AM
  #1772
ram3500-RCU
My Feedback: (221)
Now I can remove the tape. They are nicely lined up with the cowl. Next I unbolt the cowl and cut the air holes in the plates.
ID:	2057998   Click image for larger version
ID:	2057999   Click image for larger version
ID:	2058001   Click image for larger version
Old 12-27-2014, 12:22 AM
  #1773
ram3500-RCU
My Feedback: (221)
Here are some pictures to show why the taper in the plates is necessary. They create a nice pocket for the leading edge of the flaps to retract into when opened.
ID:	2058003   Click image for larger version
ID:	2058005   Click image for larger version
Old 12-27-2014, 12:26 AM
  #1774
ram3500-RCU
My Feedback: (221)
Note that, to this point, the flaps have still not been cut apart. I'll add the guides for the cable, using the cable to keep them in line. Then I can finally cut the flaps apart, before adding the 1/64 webbing.
Old 12-27-2014, 09:05 PM
  #1775
ram3500-RCU
My Feedback: (221)
Here are those cable guides glued in place.
